how to tqke out the clock?
How do you take the factory clock out?
Old 03-16-2008, 01:52 PM
e p slick's Avatar
clock
Clock is held in place by thick rubber surround O ring like rubber gasket thing. Merely grip clock bezel/edges with fingers and wriggle it loose and out. All other gauges in you 79 are secured in similar fashion. EPS - Tucson
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 03-16-2008, 01:57 PM
wcc wcc is offline
wcc's Avatar
I used a stiff putty knife to get under it and slowly and gently worked around the bottom of it and it eventually loosened up enough to pull it out. Good Luck.
Bill
997.2
Old 03-16-2008, 02:05 PM
Adrenaline Junkie
Hayabusa's Avatar
You might want to coat that edge with a little tape, and also tape around the area, so that in case you slip it will protect against an unsightly scratch.
Old 03-16-2008, 02:14 PM
Got it out, thanks. Now to route the vaccum like up there.
Old 03-16-2008, 02:46 PM
Now I am having trouble running this line, there seems to be no openings between the gauge cluster and underneath the dash, is there some trick to this too?
Old 03-16-2008, 04:01 PM
e p slick's Avatar
line
Cutting torch or big auger.
Old 03-16-2008, 04:30 PM
