Porschaholic
Name this part and its function and win
Greetings all:
I'm fishing around the engine compartment and open the case on the left side towards the rear. Relay's and fuses seem to reside. Sitting there all by itself was a yellow relay with a ground wire attached... 91161511800 but not plugged into anything and no apparent home. The parts list call it a mass air flow boost something... what is it and where does it go? The winner gets a shinny new nickel. Last edited by martinb930; 03-16-2008 at 05:05 PM.. |
sudo apt-get purge 930
That is an over-boost protection relay. It cuts the fuel pumps when you over boost in a turbo car.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Porschaholic
Should be plugged in the panel in the engine compartment on the left.
Porschaholic
The wire attached to it is not long enough to reach the only socket that is in the vicinity... there is a red and black relay already occupying the sockets. The only available socket is towards the drivers seat (on the side panel) in front of the fuel pump and some vented electrical box (looks scary with warnings all over it) god I'm such a novice... so please pardon my ignorance.
The yellow relay is for later turbos, the early ones used the red relay.
Registered Abuser
They are very expensive.
MT 930 1987 930 - Gone but not forgotten A man with priorities so far out of whack doesn't deserve such a fine automobile. I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen американский |
Here is an early red relay:
![]() and here is a later yellow relay:
Porschaholic
My 930 is a 1986 (first year back to the states) are you suggesting that I remove the red relay and plug the yellow in?
Relay
I have an 86, and mine is yellow.
Tim 1986 930 Gone:71,2,4 914's, 70T, 71T(RS),77S |
Smart quod bastardus
I had heard that the yellow relay was to keep the CD box producing spark after the ignition was cut off for 30 seconds so that unburned fuel in the engine, manifold was combusted. Do you hear the ignition box humming for 30 seconds after the car is shut off?
Just guessing, but keep the nickel and use it towards a new relay they are expensive...... Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
Mark,
I just noticed something, but your engine is missing in the photos, you ogt bigger problems than just the yellow relay, ha,ha. Fred
Neither of those pics are my car. However, my engine is out of the car. Mine is a 1979 with a red relay. Sounds like maybe 1986 was the transition year.
Just kidding with ya, I wanted to add some comedy relief to the forums becaus ehtye get too serious sometimes.
So what is the diff in function between the yellow and red relay? Why can't you just run the cheaper one unless they add an extra function to the system?
I don't know the answer to that. I've heard different theories but nothing conclusive. Some say the yellow one is a quicker acting relay since it has a pcb thereby doing some of the work with IC. Some say there is a reduction in arcing on the contacts. Some claim other functionality. I have never had the opportunity to look at the guts of a yellow one (not that I would understand it anyway) so everthing you get from me is from what others say. As a result, everything I'm saying should be taken with a grain of salt.
Another point to conside ris that not many of us are the original owners of our cars, so yo really don;t know what mods were made to the electrical systems or any other parts of the car for that matter by previous owners.
Moral of the story is find out what is supposed to be the function of the parts for your system, determine what is missing or there in your car, and then decide on how to cost effectively fix it. The factory owners manual is a must read for do it yourselfers or have a good mechanic you trust tell you how to correct evreything.
Wayah Road Warrior
OK, Now you got me curious. 87 930 here. I have the yellow relay.
Mine swivels freely. Is it supposed to be locked into place somehow?
02 996tt White 87 930 GP White (Sold) 87 911 Targa Guards Red(Sold) Last edited by Shadetree930; 03-17-2008 at 01:39 PM.. |
craigerz
So what do we win here?
My '87 has the yellow one.
I tried a red one to see if it would work and the car woud not start. I took the yellow cover off and resoldered the solder joints and put it back. I worry it will leave me stranded on the side of the road someday.. I'd like to know which pins to jump on the relay socket to let the car run if it ever fails. Anyone know? |
