Boost Freak
Maxx1's Avatar
Unhappy My car won't go into reverse anymore
Luckily my cars always seem to break down in the garage. I was out last night and it reverse was fine. Today I go to back out of the garage and the shifter feels like it's hitting a stop. I double clutched and tried again, same thing. I put it in first and rolled forward then quickly went to reverse ..... no dice
I shifted through all four gears, sitting still, turned the car off, then back on .... same thing.
It's never been even slightly hard to get into reverse before ...... is this something that can happen in a 930 from time to time? Any clues for a fix?
82 Porsche 930 Euro, black, 31K miles.
Factory stock other than k27 turbo, B&B headers, GHL exhaust, Tial F40, 1 bar wastegate, MSD 6A ignition, 8" and 9" Fuch upgrade, H4 Xenon headlamps and a 930S steering wheel.
Old 04-19-2008, 10:42 AM
F350Lawman's Avatar
I am no expert,is there a Reverse lookout on our cars that is designed to help insure that you don't accidently shift into R that could have broken? Is there anything in there that is designed to make it harder to shift into R while moving that could now be totally blocking you? Just looking/hoping for cheaper $olutions.
1987 930 - K27 7200 / DAS Full Cage / Blownsix Intercooler / BB Headers / Zork Tube / Tial 46mm / Adjustable WUR / RPM Activated Solenoid / Open Element Air Intake / Smart Racing 27mm Sways / 24 and 33mm Torsion Bars / Adj. Spring Plates / Wevo Strut Brace / Monoballs / Tow Hooks / Oil Cooler Scoop / Brey Krauss Harness Truss / Race Seats / XD-16 AFR Guage/ 17" Kodiak Racing Whees and Nitto NT-01 255/315s
Old 04-19-2008, 11:12 AM
Macht Schnell
les_garten's Avatar
Not sounding good. You might want to try to adjust the shift coupler.
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 04-19-2008, 11:55 AM
I have a hard time getting in reverse when the Trans oil is low.
88' 930
03 Tacoma, 04 Duramax, 06 R350 Benz
If you are traveling at the speed of light & turn on your headlights, does anything happen?
Old 04-19-2008, 03:24 PM
A930Rocket's Avatar
Do you go from 1st to 2nd and then reverse? That what I do to set up the gears. Give it a try.
Old 04-19-2008, 05:44 PM
Boost Freak
Maxx1's Avatar
Angry
I've never before had a prob going into reverse, so I am totally surprised that this happened. I tried lots of different combinations such as shifting through all 4 gears and stabbing the clutch a few times trying to get it to go into reverse. I even rolled the car forward in 1st and tried quickly shifting into reverse as the car was moving.
The weird thing is, there was never any resistance or problem before .... it always went in reverse with no issue before ....I wonder what is going on now ?
Old 04-19-2008, 06:14 PM
Could simply be a matter of adjusting your shift coupler which is quite simple. I actually ran into a problem at the track last weekend where my car would pop out of 2nd under hard decel and was able to correct the problem in about 10 minutes.
Linkage is located under a cover plate on the center tunnel behind the front seats. Good idea to mark where it is currently set with a sharpy so that you can always return it to your original position. Adjusts back and forth as well as right and left.
BTW... where in OH are you?
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 04-20-2008, 04:11 PM
Have you changed out the shift coupler bushing?
The bushing in my '78 failed last year in almost the same manner. Great fun moving the car in the garage so I could open both doors to remove the seats for the R&R of the shift coupling. The seats are fixed Recaro Pole positions so, yes, they had to be removed for the project.
thomas
Old 04-21-2008, 08:21 AM
Smart quod bastardus
fredmeister's Avatar
You were on the right track with rolling forward in first, but do not try getting in reverse with the car still moving forward.
I occasionally cannot find reverse, but what I do is roll it forward slightly in first, STOP, clutch in, wait for a second or 2 then try reverse. Reverse gear is a straight cut idler set that if not perfectly aligned teeth will nto engage. By rolling forward a little you re-index them and this allows re-engagement.
Have you tried engaging reverse with the engine shut off and then restarting it?
Good luck, Porsche was really stubborn in terms of trannys, refusing to give up on the good Dr.s synchro design to go to the Borg Warner style, which is a better design, until the late 80's.
Other than that, make sure the clutch is not worn and you are getting full disengagement when you press the pedal.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 04-21-2008, 02:47 PM
930gt-40r's Avatar
I think it is a shift linkage as well- heres the good news- if at the end of the day worst case scenario and the trans has to come out- Reverse is right in the front of the trans nose.
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 04-21-2008, 08:25 PM
Boost Freak
Maxx1's Avatar
Thumbs up
Thanks,
I am in Akron. I have some time today and will take a look at it.
I tried all different combinations. The weird this is, it's always gone in easily before. I am about to take another look and will report back.
Thanks everybody!!
Old 04-27-2008, 07:03 AM
Boost Freak
Maxx1's Avatar
Thumbs up
It was the shift coupler set screw that came loose. You guys ROCK! Thanks a million!
Old 04-27-2008, 01:15 PM
