Metal Guru
911nut's Avatar
Fabspeed Headers - Anyone running them?
Was visiting Fabspeed's web site yesterday and saw they now are making headers. Has anyone seen them or bought them?
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 08-18-2008, 05:08 PM
resident samsquamch
sand_man's Avatar
Not I, but I did see a post several weeks ago on Rennlist about them. They look promising...
-jeff
Old 08-18-2008, 05:19 PM
Me like track days
Craig 930 RS's Avatar
If I were buying headers, I'd wait for some longer term results from other early adopters....
failed headers make a MESS out of a turbo.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 08-18-2008, 07:37 PM
Macht Schnell
les_garten's Avatar
I have their Muffler and their quality is second to none IMHO. I'll have to look over their headers...
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 08-18-2008, 09:25 PM
Metal Guru
911nut's Avatar
I'm waiting for someone to make headers that have durability approaching the OE heat exchangers. I can't bring myself to spend $2500 only to be scrapping headers in 5 years time due to extensive cracking.
Some manufacturer needs to make headers from 409 SS instead the 304 SS everyone is so fond of.
Paul B.
'91 964 3.3 Turbo
Old 08-19-2008, 05:55 AM
resident samsquamch
sand_man's Avatar
I'm sure I'll be flamed for being a cheap skate and taking the Chinese child labor approach, but my OBX are T321 stainless, fit perfect, cost $499 (including shipping) and are still holding up.
B&B Headers - got a god d@mn hole!
Perhaps I got lucky...
-jeff
Old 08-19-2008, 06:09 AM
resident samsquamch
sand_man's Avatar
FWIW, if you're looking to outlive the stockers, the SSI solution that RarlyL8 and M&K have worked out, appears to be the way to go.
-jeff
Old 08-19-2008, 06:10 AM
Crotchety Old Bastard
RarlyL8's Avatar
Well, your OBXs weren't exactly a perfect fit, but they are only $500.
I plan to do a second generation SSI setup soon which should resolve the remaining fitment issues for the different cars. I simply don't accept the alignment problems caused when combining aftermarket headers and turbos. My version of "bolt-on" apparently is not the same as others. Because of that I have turned down several sales.
Everything is made in China now. The QC is not in place and the metal is often not as represented. Chinese spec 304 is not the same as US spec 304. You will see failures in the years to come. At $500 a short life may be acceptable. At $2000+ it is not.
Old 08-19-2008, 07:42 AM
Cowtown10's Avatar
Im with Les, I have a Fabspeed muffler and happy with it. I will be checking out their headers for the rebuild in the fall. $2500 is certainly easier to swallow than $5-7K for Mode headers.
Q
1991 RRC
1995 993 C2
2002 996TT
1984 930 Turbo (gone and missed)
Old 08-19-2008, 07:50 AM
resident samsquamch
sand_man's Avatar
Perhaps "perfect" is a strong description. But for the most part, they were. Keeping in mind that I removed a set of B&Bs, the turbo still lined up perfectly, the home made passenger side Borla that I was running fit perfect (including the alignment of a custom muffler bracket that was welded to the back of the Borla when I was running the B&Bs), even the turbo support bracket fit just as it did with the B&Bs. The only fitment area that was suspect was the waste gate...and this was only evidenced by the custom wastegate exhaust pipe that I had exiting under the driver side bumper. This pipe was custom made when I was running the B&Bs. With the OBX, this pipe was now exiting lower than before, but still lined up in the same horizontal placement. I solved the aesthetics by cutting the wastegate exhaust pipe so that it exited under the car, and was no longer visible.
-jeff
Old 08-19-2008, 08:07 AM
