You only need it if your state checks for it. Ask your mechanic.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Minne....Sota.
Don't need it...don't want it! Thanks. ______________ Steve 1989 930S Factory Slant |
Maybe someone has run tests to disprove this possiblity. Enjoy
That's very interesting, 'copbait.'
My Euro car didn't have the airpump system when I bought it, but I'd have thought that running the pump alone would rob about 5->10bhp from the engine in the same way the A/C system does? Also, for what car (US, Japan, RoW) is this graph? 190kW = 255BHP, so it's not a very powerful 911 turbo! |
Hi all got a few questions..
If I want to remove from the top of the engine what do I do so the gas from the head does not escape?do I leave the "valve with the vacuum line to it ?how do i cut the belt I do not see it. Thanks |
This would be much to close to the cylinder. This position is too hot for the sensor (lifespan) and you get more constant values more off the cylinder.
Roland 930 Turbo '81 Too many modifications to list |
You can moniter egt there .
..and along with that, wide band sensors are supposed to be mounted right side or wire end up between 10 and 2 o clock to keep the sensor element away from any possible settled condensation in the exhaust pipe caused by short drives in humid weather.
)With these 6 pre-cut holes, does seem a bit of a shame not to put them to some good use
