930s rule the wasteland
Sending WUR out to Brian Leask and want to get my injectors redone. I want to start out fresh. Any1 recommend somebody to rebuild injectors so I can get Miss Piggy back in shape without getting slapped w/new injector prices.
1980 930 Turbo 1993 Corrado 1983 944 1984 944 2001 VW golf TDI |
Do a search there's a couple on cleaning injectors.. You can do a quick check on them by taking carb cleaner with the narrow straw on the can and checking the spray pattern..
Otherwise I'd say buy some used ones they are $25 from DC Automotive and other places.. Not sure anyone can actually "rebuild" them just clean them up
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
I could of swore i saw a blog about it on here, i have the bosch fuel/diesel injector tool at work, the 1 for checking the breaking pressure(cracking maybe). can i use this with some 44k to blow thru the injectors to clean them up.
might try the backflush method that i came across here.
Will program for food
How about
http://www.witchhunter.com
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee |
Will Witchhunter do a good job or will the backflush method be about the same?
Lots of threads about them on the 911 forum...
http://forums.pelicanparts.com/search.php?searchid=2814185 I have not used them yet, but I plan to...
thanks for the info ghnat
beancounter
FYI gents, I checked with witchhunter recently and he no longer offers cleaning services on CIS injectors. He says he will test them for you, but nothing else.
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
Me like track days
witchhunter is in my neighborhood -
FWIW, when he tests them he *uses the cleaning fluid to test* --- thus effectively cleaning them as much as possible. I'd defintiely recommend them, he is very thorough and accurate - did a great job/analysis on mine!
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
You could also try
http://www.rceng.com/index.aspx or http://www.allcarbs.com/parts/parts_fuelinj.html or EBS Maybe one of these folks will work on CIS...
One more to add...
http://www.cruzinperformance.com/
I used Marren Fuel injection in Connecticut when I rebuilt my 993 3.6 liter engine. They did a great job rebuilding my injectors. They also provided a full printout report including flow rates before and after the rebuild.
-Rich- 1984 911 Track 1985 911 Track/Autocross |
Thread Tools | |
Rate This Thread | |
