930s rule the wasteland
Wish I had a scanner for this but anyway
Subject:Part -load surging Model 911 turbo group 25 part identifier 2587 number 77-03 engine surging at part throttle under load (similar to ignition misfiring) can be caused by a leaking intake minifold gasket.(total of 12 gaskets go above and below intermediate flange) replace gasket or gaskets as required part required:gasket part number 930 110 197 01 note: there are 12 identical gaskets-6 between intake manifold and intermediate flanges; 6 between intermidiate flanges and heads. any of these,if leaking ,could cause erratic engine performance. Hope this my problem! and hope this clears up your problems! Pete
1980 930 Turbo 1993 Corrado 1983 944 1984 944 2001 VW golf TDI |
Crotchety Old Bastard
Leaking phenolic blocks can cause a multitude of symptoms.
Check/tighten each injector block before going to the trouble of changing gaskets.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
do they crack or get warped?
I recently purchased a carrera 3.2 with a bad missfire and it turned out to be inlet manifold gaskets...
This could be your problem however as advised above i would try and re-torque first and maybe test for leaks at each one before you go ahead and strip down!! Link below is for 3.2 carrera engine.. Similar set up in the 930 apart from the injectors are located also in the blocks. I believe they can crack,,not so sure they would warp though. 1988 3.2 carrera engine bad missfire,HELP!!
SP Autobahn www.spautobahn.co.uk Porsche inspector for Peter Morgan UK http://www.porscheinspections.com/ "92" 964 turbo,Modified and recently rebuilt using all ARP hardware.. Purpose built fuel controller set up to acheive perfect fuel curve on CIS inj. Last edited by stup; 12-21-2008 at 05:53 AM.. |
had some small cracks but nothing real bad, the valves in these heads are huge. no gaskets wiped and manifold was tight
what is this nonsense, doesnt look stock
Maybe some ancient boost controler?
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
should i delete this stuff
Yes, the phenolic blocks regularly crack with age/heat. If they are not loose and you have to tear it down then inspect each block for cracks larger than the typical small spider viens.
they do have some fractures in like 3 of them will this cause a problem under low boost? I will send pics after I clean them up. manifold and fuel meter in trunk to take to work for clean up tommorrow.
Can someone trace his IP and ban him?
Thank you for your time, Last edited by NathanUK; 11-27-2009 at 11:46 PM.. Reason: Removed spam links |
Yeah you would possibly get a missfire on low boost,light throttle etc if the fractures are all the way through!
SP Autobahn www.spautobahn.co.uk Porsche inspector for Peter Morgan UK http://www.porscheinspections.com/ "92" 964 turbo,Modified and recently rebuilt using all ARP hardware.. Purpose built fuel controller set up to acheive perfect fuel curve on CIS inj. |
ok im gonna replace all blocks and gaskets . talked w/ a buddy of mine (retired porsche mechanic) and hes pretty good w/ 3.3turbos and said its probably in the fuel head . so its on its way to Jaytan not the other screwball w/ the additude. yah that guys post are annoying ,free advertisements for him.
A fellow Pelacanite
Please do not quote their links!
Banned him. His IP address is: 58.17.145.77
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
Forced Induction Junkie
Nathan,
Got a little time on your hands? ![]() I just noticed this thread is about a year old. Are the moderators going through the archives deleting spammers?
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
Good job Nathan,, and Dave is right,, the car must be away for the winter huh ? hahaha
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
A fellow Pelacanite
Chuck reported the spam so I deleted it.
I haven't driven my 911 carrera for over a week now ![]() Will have to try and get the 930 back together soon... Thanks for reporting it Chuck.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg Last edited by NathanUK; 11-29-2009 at 07:44 AM.. |
