Happiest when Tinkering
gsmith660's Avatar
cutting down a wastegate spring
Anybody got any guidence on how much I should cut down a .8 bar spring to get
.5 bar, is the spring rate linear so for example 1 ring on a 1 bar spring gets me .8 therefore 1 and half should get me .5 bar, am I in the ballpark.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 02-20-2009, 05:14 AM
beepbeep's Avatar
Cutting springs makes them harder. It also shortens the elastic region.
Thank you for your time,
Old 02-20-2009, 05:18 AM
Me like track days
Craig 930 RS's Avatar
Yep, and get the correct spring.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 02-20-2009, 01:29 PM
Metal Guru
911nut's Avatar
I think that if you are able to cut one down and grind in get the proper taper on the end that you cut, it could work out.
Do a search on wastegate springs. I posted the length of a .7 bar spring in one of those threads. With a little interpolation you could arrive at the length of an .5 bar spring.
A shorter spring will exert less force when captured in the wastegate than a longer one. If you have a mechanical boost gage you can check your work. If you don't have one, time to install one before you experiment.
Good luck and be sure to post your results for the naysayers
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 02-20-2009, 02:13 PM
gsmith660's Avatar
does anybody know at what pressure on the bottom of the diaphragm opens the wastegate should it be what ever boost pressure is?
Old 02-20-2009, 04:23 PM
Smart quod bastardus
fredmeister's Avatar
Yes it sees the boost pressure. As long as the upper chamber remains vented to the atmosphere.
You don;t want to cut the spring because like others said this increases spring rate. It will likely not reduce the preload much like you are attempting to control because the spring is compressed a huge amount in the housing, but because of the higher rate will actually make it worse.
Why are you talking 0.5 bar anyway that is aweful low for a 930 engine? Unless you are planning on installing a boost controller to get back to 0.7-1.0bar with the 0.5bar spring.
Don't mess around with this stuff unless you have a good understanding of how the wastegate works and how springs are designed. Take a step back and look at the design or do a little research on google to see how things work before making changes.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 02-20-2009, 04:30 PM
gsmith660's Avatar
Its not a 930 engine its a science experiment with a 2.7 motor and just about the same number that say dont cut the spring also say cut the spring. It makes sense to me that if you reduce the overall length then the preload would also decrease if you can point me to a site that will refute that I am willing to look.
Old 02-20-2009, 04:45 PM
gsmith660's Avatar
Gonna get a tial, my stock wastegate now for sale I just got it to acuate with 10 psi air.
Old 02-20-2009, 05:33 PM
9dreizig's Avatar
Send a message via AIM to 9dreizig
please send pictures when you blow the engine up!! LOL
+1 on don't cut it!
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
gsmith660,
It's a curiosity to some that cutting a helical coil spring (such as the one in your wastegate) will indeed stiffen it. Any design textbook on springs (such as Machine Design by Deutschman or Mechanical Engineering Design by Shigley and Mischke) will confirm this. There are formulas that explain it, but they're too much work to enter here. To convince yourself, take any old spring from a hardware store and measure how much force it takes to deflect it a known amount. Then cut it in half and measure again. You'll find it's stiffer - that is, it takes more force to move the spring the same amount when the spring is shortened. Think of it this way: if you have a long torsion bar and a short torsion bar (of the same diameter), which one is stiffer? It will be the shorter one. A coil spring is essentially a coiled up torsion bar, so a shorter coil is stiffer. Convince yourself...
Old 02-20-2009, 05:51 PM
gsmith660's Avatar
I get the impression that I have worn out my welcome here your responses are getting terse I am only trying to learn and I thought that this was the right place to ask questions.
Old 02-20-2009, 06:01 PM
9dreizig's Avatar
You've not worn out your welcome here, and nobody was getting terse ( go to OT if you want terse LOL), just alot of engineering types here with limited communications skills ( you guys know who you are ) .
Around here if you ask for an opinion you'll get it , nobody is shy here either..
I think Rob's explaination summed it up pretty good..
"Todd"
Old 02-20-2009, 06:12 PM
Navin Johnson
TimT's Avatar
+1
There was a little misinformation regarding springs posted above
Analogy to a spring... say you have a lever 4 feet long you are using to lift something....
If you cut that lever in half... so you now have a 2 foot lever... and it will take more force to lift that something..
A coil spring is just a big wound up lever.. cut a coil spring in half you have a shorter stiffer spring.... cut a coil of that same spring you still have a shorter stiffer spring of an unknown rate
Keep your .8 bar spring... and get a boost controller...
'69 911 GT-5
'75 914 GT-3
and others
Old 02-20-2009, 06:22 PM
9dreizig's Avatar
Actually Tim, if I understand boost controllers, you can never dial in less boost than your spring,, so he'll still need to solve the less than .8 bar issue as all a boost controller does is effectively squeeze down the atmosphere end of the waste gate..
"Todd"
Old 02-20-2009, 06:27 PM
gsmith660's Avatar
Yeah I stay away from OT I have given up the idea of the stock wastegate and opted for a tial too bad the piece looks rough because I have had it on the shelf since 82 the 79 it came off of had very few miles when the owner torched it when he couldn't make payments the turbo is the same but got hot enough that i had a new core put in it back then. I dont intend to blow up the motor, alot of folks dont have faith in the 2.7 but mine has all the updates and has run flawlessly. the 2.7 I have on the shelf got overheated and it still made the trip from new orleans to missouri all I had to do was stop to fill up the oil and add a little gas. This is a test bed to learn and then i intend to put a 3.2 together and transfer it all over to it and bump up the hp.
gsmith660's Avatar
Thats true that is why I am getting a 5 or 7 psi spring and adding a boost controler to dial in the desired boost using an accurate boost gauge.
Old 02-20-2009, 06:30 PM
Navin Johnson
TimT's Avatar
Yes you can't get lower boost than the spring with a controller. Cutting a spring in half or cutting a coil off will only increase the minimum boost..
He the o/p should contact TIAL and see if they have low boost springs available.. they probably do
'69 911 GT-5
'75 914 GT-3
and others
Old 02-20-2009, 06:34 PM
Metal Guru
911nut's Avatar
Hooke's law states that a spring applies a force that is linearly proportional to the distance of it's equilibrium length. In other words, take two different lengths of springs made from the same steel and wire diameter. Compress the springs to an equal distance the longer spring applies a greater force than a shorter one.
That's why longer and longer springs with the same wire diameter are used in the stock wastegate to raise the pressure at which the wastegate opens. The longer spring is crammed into the chamber above the diaphragm. Since the longer spring has been displaced a greater amount than a shorter one, the force applied by the spring to the diaphragm is greater.
Paul B.
'91 964 3.3 Turbo
Old 02-20-2009, 08:27 PM
gsmith660's Avatar
That was kinda what I was thinking but didn't know where I had seen it, at one time in my life I had studied all that but it is ancient history (Navy nuclear power school) that is kinda obvious when you look at the 1 bar spring and the .8 bar spring together they are same dia. wire same number of coils but the 1 bar spring is a little bit taller.
Old 02-20-2009, 08:33 PM
gsmith660's Avatar
but I am still going to get the tial.
Old 02-20-2009, 08:34 PM
