Happiest when Tinkering
cutting down a wastegate spring
Anybody got any guidence on how much I should cut down a .8 bar spring to get
.5 bar, is the spring rate linear so for example 1 ring on a 1 bar spring gets me .8 therefore 1 and half should get me .5 bar, am I in the ballpark.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
Cutting springs makes them harder. It also shortens the elastic region.
Thank you for your time, |
Me like track days
Yep, and get the correct spring.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Metal Guru
I think that if you are able to cut one down and grind in get the proper taper on the end that you cut, it could work out.
Do a search on wastegate springs. I posted the length of a .7 bar spring in one of those threads. With a little interpolation you could arrive at the length of an .5 bar spring. A shorter spring will exert less force when captured in the wastegate than a longer one. If you have a mechanical boost gage you can check your work. If you don't have one, time to install one before you experiment. Good luck and be sure to post your results for the naysayers
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
does anybody know at what pressure on the bottom of the diaphragm opens the wastegate should it be what ever boost pressure is?
Smart quod bastardus
You don;t want to cut the spring because like others said this increases spring rate. It will likely not reduce the preload much like you are attempting to control because the spring is compressed a huge amount in the housing, but because of the higher rate will actually make it worse. Why are you talking 0.5 bar anyway that is aweful low for a 930 engine? Unless you are planning on installing a boost controller to get back to 0.7-1.0bar with the 0.5bar spring. Don't mess around with this stuff unless you have a good understanding of how the wastegate works and how springs are designed. Take a step back and look at the design or do a little research on google to see how things work before making changes.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" Last edited by fredmeister; 02-20-2009 at 04:33 PM.. |
Gonna get a tial, my stock wastegate now for sale I just got it to acuate with 10 psi air.
please send pictures when you blow the engine up!! LOL
+1 on don't cut it!
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
gsmith660,
It's a curiosity to some that cutting a helical coil spring (such as the one in your wastegate) will indeed stiffen it. Any design textbook on springs (such as Machine Design by Deutschman or Mechanical Engineering Design by Shigley and Mischke) will confirm this. There are formulas that explain it, but they're too much work to enter here. To convince yourself, take any old spring from a hardware store and measure how much force it takes to deflect it a known amount. Then cut it in half and measure again. You'll find it's stiffer - that is, it takes more force to move the spring the same amount when the spring is shortened. Think of it this way: if you have a long torsion bar and a short torsion bar (of the same diameter), which one is stiffer? It will be the shorter one. A coil spring is essentially a coiled up torsion bar, so a shorter coil is stiffer. Convince yourself... |
I get the impression that I have worn out my welcome here your responses are getting terse I am only trying to learn and I thought that this was the right place to ask questions.
You've not worn out your welcome here, and nobody was getting terse ( go to OT if you want terse LOL), just alot of engineering types here with limited communications skills ( you guys know who you are
) . Around here if you ask for an opinion you'll get it , nobody is shy here either.. I think Rob's explaination summed it up pretty good..
Navin Johnson
There was a little misinformation regarding springs posted above Analogy to a spring... say you have a lever 4 feet long you are using to lift something.... If you cut that lever in half... so you now have a 2 foot lever... and it will take more force to lift that something.. A coil spring is just a big wound up lever.. cut a coil spring in half you have a shorter stiffer spring.... cut a coil of that same spring you still have a shorter stiffer spring of an unknown rate Keep your .8 bar spring... and get a boost controller...
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Actually Tim, if I understand boost controllers, you can never dial in less boost than your spring,, so he'll still need to solve the less than .8 bar issue as all a boost controller does is effectively squeeze down the atmosphere end of the waste gate..
Yeah I stay away from OT I have given up the idea of the stock wastegate and opted for a tial too bad the piece looks rough because I have had it on the shelf since 82 the 79 it came off of had very few miles when the owner torched it when he couldn't make payments the turbo is the same but got hot enough that i had a new core put in it back then. I dont intend to blow up the motor, alot of folks dont have faith in the 2.7 but mine has all the updates and has run flawlessly. the 2.7 I have on the shelf got overheated and it still made the trip from new orleans to missouri all I had to do was stop to fill up the oil and add a little gas. This is a test bed to learn and then i intend to put a 3.2 together and transfer it all over to it and bump up the hp.
Thats true that is why I am getting a 5 or 7 psi spring and adding a boost controler to dial in the desired boost using an accurate boost gauge.
Navin Johnson
Yes you can't get lower boost than the spring with a controller. Cutting a spring in half or cutting a coil off will only increase the minimum boost.. He the o/p should contact TIAL and see if they have low boost springs available.. they probably do
Metal Guru
Hooke's law states that a spring applies a force that is linearly proportional to the distance of it's equilibrium length. In other words, take two different lengths of springs made from the same steel and wire diameter. Compress the springs to an equal distance the longer spring applies a greater force than a shorter one.
That's why longer and longer springs with the same wire diameter are used in the stock wastegate to raise the pressure at which the wastegate opens. The longer spring is crammed into the chamber above the diaphragm. Since the longer spring has been displaced a greater amount than a shorter one, the force applied by the spring to the diaphragm is greater.
but I am still going to get the tial.
