A fellow Pelacanite
Two more shots of the CDI plug.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg |
A fellow Pelacanite
Here's a shot of behind the tach.
930porsche
Nathan,
Are those numbers measure while disconnected in OHM or Voltage? When you say coil primary meaning the CDI unit? And the coil secondary the actual coil? When you measure the brown to the white side do you touch and connect the BLk and RED connection of your tester? Explain. Thank you. I am starting to understand with those pictures. |
A fellow Pelacanite
The measurments are all disconnected so they are Ohms. By coil primary I mean the low voltage side of the coil which has the small tags on them and may well be marked '+' and '-'. By coil secondary I mean use one of the previous connections (+ or -) and the high voltage side of the coil which is where the HT lead goes. So to answer your question, just the coil.
I just read my earlier post and remembered there is no need to disconnect the low voltage side of the actual coil itself if you unplug the CDI. Simply remove the HT lead from the coil and place your meter across the brown and white wires in the disconnected CDI connector, put one probe on brown and the other on white (it doesn't matter which colour you use from your meter when checking resistances/Ohms). Please ensure your ignition is switched off before unplugging the CDI or anything else etc etc. Please feel free to ask if there is anything that is not clear.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg Last edited by NathanUK; 08-19-2009 at 02:20 PM.. |
Happiest when Tinkering
Did you get it working?
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
A fellow Pelacanite
It could be time to upgrade your CDI by replacing it with an MSD6AL or the newer more efficient one.
930porsche
Nathan,
I ask my mechanic and he cannot remember which wire he hooked up the BLK/PUR with. That is why I am educating myself to do all of these things myself and I appreciate your time and effort of explaining the process. I am starting to get it. It is just the verbage that I am trying to understand. I do not want to depend on my mechanic like all of you guys. If I understood correctly the primary is the CDI harness connector end? And the secondary is the + and - on the coil? Which one is the coax that you mentioned to test with the green wire? When I test on the CDI harness connector, on the brown and white I get fluctuation between 1.2 to 5 to 140. Is this normal? On my CDI harness connector I have 2 BLK/PUR wire from the exact same location, 1 is connected and the other one cut with bare wire showing. |
930porsche
Here are pictures of my 1978 930 as I see it in my car. I tested th 6 pin as Nathan told me and everything seems to register just fine. The coil also is reading on my tester fine. I guest we have to go by elimination and narrow it down. We will eventually get it. I need all of you guys to pitch in. I finally got all the pictures and diagrams but they are not helping me nailing this small problem. Here it goes:
The BLK/PUR Tach wire at the 6 pin is talking to the 14 pin, But where does it go from there? I thought it went to the ignition switch but I checked it and no purple wire, only reds and 1 white. Now there is a purple wire obviously behind the tach but where is it going? On my drawing to the left behind the fuel guage there is a small round yellowish harness which has 6 wires including a purple wire which goes to a square relay which is located behind the boost guage. Also there is a purple wire at the front fuse box. The purple wire behind the tach is not talking to any of them in the front or rear of the car then where is it going and what am I missing? I know there is an easy solution but where? Help me figure this out. |
930porsche
It is not taking any pictures and diagrams. They are all Jpeg. What am I doing wrong?
930porsche
Gsmith660, I will do the testing from the 14 pin female to the Tach. If nothing what is next?
If you dont get continuity from the 14 pin to the tach then your problem is solved the wire is open you can order more blk/purp wire from eagle day or just get some wire from the local auto parts store and run you a new wire from the 14 pin to the tach thru the tunnel use a wire fish it will help.
930porsche
Tach problem
Gsmith660,
I hope it is the case, I let you know. Thank you. |
930porsche
Gsmith660,
How do you test the 14 pin female if not connected to the 14 pin male, or do you test it while it is connected through the wire? Are we checking the voltage? |
Go ahead and plug the 14 pin back together and check continuity from the 6 pin to the tach you are checking the resistance of the wire it should read nearly 0 ohms as it is just a wire if it is open then the reading on your multimeter wont change or if you have a continuity checker use that. If it is an open wire then run a new wire.
A fellow Pelacanite
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG. Fitting - New service kit. Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head. 1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods. Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit. http://www.danasoft.com/sig/Iamnotanumber.jpg Last edited by NathanUK; 08-23-2009 at 06:48 AM.. |
A fellow Pelacanite
To add confusion to all of this Porsche used blk/purple for the wipers. This wire comes from the fusebox and goes to the wiper control stalk as well as other places. The blk/purple wire from the CDI on a pre '86 930 should only go to the tach. Actually, the factory call this wire black/violet to be exact.
930porsche
Tach Problem
I do get a reading of .18 Volt testing the tach, 6 pin and 14 pin while the engine is running. My strong suspicion is that the tach is dead. It has been mentioned earlier that there is a special tool to open the tach without damaging it. What is it and where can I buy one? Also where can I get the inside parts for the rebuilt?
930porsche
I believe 0 OHM.
Thread Tools | |
Rate This Thread | |
