What AFR guage to use
I am looking for a permanent guage to monitor AFR's but I also want to be able to log AFR's with RPM's. What are you using and why. looking at the LC-1 but want some real world advice. Also, not looking to spend $4-700.00.
thanks, Ben
1986 3.2 Carrera |
Ben,
I run a LM1 and LMA2 in my 930 at all times, I monitor and log AFRs, Boost, Vac, RPM, System Press, and Control Press. I have a Dyno Tune digital readout on the dash and am very pleased with the system. I bought all of the hardware either on the board or EvilBay. My total cost is just over $300.00 Innovate has been pushing the new LM-2 and the used LM-1's can be found very reasonably and most include the associated cables needed. All the software can be downloaded from their site and the support has been first rate. Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. |
I run with an LC-1 and G3 analog gauge, so it's limited to mapping primarily just AFRs. Honestly, I have yet to hook up my laptop to it because of serial cable differences. Overall as an on-board AFR monitor, I'm please with it.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
+1 on the lm-1
Wo ist die Rennstrecke?
I use the LC-1 with the XD-16 gauge. The LC-1 ties nicely into nearly any ECU as well. Inexpensive and great quality.
Jim,
Boost and Vac are done with a GM 3 bar MAP it requires a 5vdc power supply which I built with $6.00 of Radio Shack parts then ties into the LMA-2, easily plumed into manifold with vacuum hose. The pressure transducers for control and system pressure are MEAS and I got off Evil Bay used. They are 12vdc in and 5vdc out and again wire directly into the LMA-2. They have 1/8 male fittings on them and are easily plumbed into the fuel lines with a T. After I got them I looked on line www.meas-spec.com and got spec sheets for them. Cole
Innovate LC-1 with a DB gauge. It has been spot on when compared to the data from my dyno runs.
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
