Inlet Overrun Valve Modification? (BOV, lag)
........ Dose anyone have a factory digram of the Inlet-Overrun Valve?
Over the years I have read several times about some European tuners modifying the Inlet Over Run Valve on 930's to increase throttle response. The most recent was in Total 911, The Porsche Magazine -- March 2008 Issue 34. Dose anyone know how this is done? I once modified my C2 turbo so the BOV would stay open at idle and cruse to allowed the turbo to be spinning in reserve. When I accelerated and manifold vac went away, the BOV would instantly close. The result was faster boost response off idle and cruse. I saw an instance .2-3 bar off idle and .5 bar off cruse with this strategy so I truly believe there is opportunity here for 930's. It would be great if we could find out or figure out how to accomplish this. If anyone has any diagrams or pictures to post of the Overrun Valve it would be helpful. Thx. Last edited by 911st; 11-21-2009 at 07:56 AM.. |
The artical noted above that the mods were by John Greasley / Dage Sport.
Based in Aylesbury, Buchkinghamshire in England. Could not find them on the internet but it sounds like there company name was changed to G Force Motorsport. Also of Blue Coral racing fame I believe. I was going to try to email to see if they would share info on the mod but could not find contact info on the net. I guess my hope being someone here might have some contact with them and might find out how the mod is done for the common good. ![]() |
Certifiable
I'm interested! I'll do some looking!
Sean D. 1987 930 India Red/Beige/Black; Mahle 3.4L; Kokeln IC; K27 7200; GHL Headers; Borla Stainless Muffler; SC cams; Sachs Aluminum Clutch; Aluminum flywheel; Bilstein Sport Shocks; Adjustable Rear Sway Bar; Weltmeister Shock Tower Brace; Lowered and Corner Balanced; MOMO RSGT Seats... |
Infidel
GForce got taken over by DS Automotives The Company - DS Automotives
Don't think you'll get much from them now as they mainly specialize in Jap stuff and the old Porsche chaps aren't there anymore, it's in the same location but that's about it
Jonathan. 87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines..... Old 540 BMW, XB12S Modified, for being a total hooligan ![]() |
Metal Guru
(1) The compressor discharge is not a nozzle like the turbine inlet is so any reverse flow would most likely have little to no effect. (2) The turbo spinning in reverse, even if it could, would not yield instant boost. It would be quite the opposite, in fact, creating tremendous backpressure in the exhaust tract. (3) I'm not sure what effect the bov remaining open during steady-state cruise would have on the turbo speed but my instincts say it would be nil effect. On the 965 Le Mans Turbo, some fuel over and above what was required to idle the engine was injected to create more exhaust gases and keep the turbo spinning faster between shifts. However, Porsche did not believe this method to be practical for road cars due to the additional fuel consumption. It seems to me that, for snappier boost response, we would want the turbo to lose as little speed as possible between shifts. Garret has data to this effect when comparing their ball bearing turbo to the conventional mandrel bearing turbos like the KKK ones.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
Metal Guru
More food for thought from the air injection delete post.
Sparrot writes: Has anyone considering keeping the air injection for between shift anti-lag? My motorsports background is rallying. Many of Lancer Evo 5 & 6's (Toyota celica all-trac) had an air injection manifolds with a one way check valve connected to the dump valve. When the anti-lag was armed the ecu would use the dump valve connected to air injectors to dump all excess boost pressure to the hot of side of the turbo between shifts or throttle lift. The excess air would help burn excess fuel and keep the turbo spooled. Of course the rally car would also retard the ignition also so that unburned fuel would enter the manifold but just dumping the excess air works fairly well without destroying the exhaust like a full-on anti-lag does. I guess this might require EFI conversion, CIS may dump excess fuel.
Paul,
Thanks for the info. I think I said reserve, not reverse. I have read about the Rally anti-lag strategy in the past. Cool stuff. They basically turn the hot side into a little turbine jet motor when engaged at the start and between shifts. Kind of shortens the turbos life span I would think. --- If we vent the section after the compressor (and feed it back between the metering plate and the turbo intake) this reduces the pressure build up in the area outside the throttle body. This allows the turbo to spin faster at idle and at cruse. Then when we accelerate the turbo will be spinning faster (in reserve) then if we had not and we start off with a jump in boost when we accelerate. Again, I did it with my C2 turbo by flipping my adjustable BOV's orientation and adjusting the spring tension so it stayed open at idle from the turbo's pressure pushing the BOV open and the suction pulling on the top of the BOV's piston. Then when I accelerated the vacuum went away and the spring tension would start to close the BOV. With boost, the top of the BOV would fill w boost pressure. As the top had much more surface area the boost was sufficient to keep the BOV closed against the pressure from the turbo trying to push it open. Worked pretty well for me. However, not sure how we could mod the factory 930 overrun valve to operate that way or if it already may work that way. |
PS, I think I remember there was something I read here that noted that turbo lag was increased with the removal of the stock 930 air injection system. This might even be in the Porsche factory manuals some where. Make sense as it increases the pressure and volume in the exhaust manifold from the mechanical compression and from it helping any unburnt fuel to burn further in the exhaust with the addition of oxygen. The cost is about 5-10 hp in HP on boost per one point of referance I have read.
Metal Guru
The 965 air injection is directed to the exhaust ports for up to one minute after start-up; thereafter a diverter valve switches the flow over to the cat.
So for better spool-up on a 965, the simplest solution would be one of those nice Garrett ball bearing turbos. I'm planning on installing one in the future.
That works!
Sounds like an Anti-lag system like in rally cars would be more efficient for earlier boost. However this would require electronic timing control. Typically done by retarding timing by about 20 degrees. Destroys turbos but can idle at up to 1 bar, but typically less.
Dose any one have a digram of how the over-run-valve is set up and plumbed?
Again, it is not as sexy as turning ones turbo in to a jet but by releasing the pressure in the inter-cooler section of the plumbing when not accelerating it lets the turbo spin up faster because there is less drag on the compressor wheel. Then when one accelerate if the bypass is closed one gets some instant boost. On my car by manipulating the BOV I got an instant .2 to .3 bar boost off idle and .5 bar off cruse. This helped to wake up my car. There is a company that has figured this out to and makes a new style BOV that dose what I am describing. If one has an aftermarket IC that uses the C2 or TT turbo style BOV you can just use that. I believe others have done it on a normal 930 by modifying how the Inlet-Over Run-Valve which if we can figure it out would be a benefit for most of the Turbo owners here. ![]() |
[QUOTE]There is a company that has figured this out to and makes a new style BOV that dose what I am describing[QUOTE]
Which company?
Roland 930 Turbo '81 Too many modifications to list |
Ingenieur
For the early arrangement ('76 to '89) the compressor bypass is already open at idle isn't it? The piston is drawn back by intake vacuum, and this connects the upper manifold (including intercooler) to the compressor inlet.
Certified User
Normally, the BOV is installed upright, but as I understand it, when it is mounted sideways and if the spring is light enough, at idle and light throttle the vacuum on the top side of the piston will overcome the spring and hold the valve open. When there is manifold vacuum, this allows some air to by-pass the turbo compressor which reduces the load on the turbo and allows it to run at a higher speed off boost. As soon as any boost appears, the BOV is closed by boost pressure on the top side of the piston. The effectiveness of this arrangement will depend upon the strength of the spring. Don't assume that mounting the BOV sideways will automatically allow it to open at idle. The spring must be light enough to allow the valve to be opened by a moderate amount of vacuum, otherwise it will always remain closed until it gets a combined dose of full vacuum on the top side and boost on the bottom side (i.e. when lifting off throttle under boost). As far as I can figure, mounting the BOV sideways effectively switches the inlet and outlet ports and the pressure that each port is exposed to. Because the areas of the piston exposed at each port are different, the operating characteristics are changed accordingly. I am not convinced that my BOV is actually opening up under idle and I haven't figured out how to check it under operating conditions. I suspect that I might need a lighter spring, but haven't gotten around to following up on that yet. I hope this is of some help in understanding how the BOV can work as a by-pass valve at idle/cruise. ![]() ![]() ![]()
Bill 1988 Carrera - 3.6 engine with ITBs, COPs, MS3X 2024 Macan S Day job ... www.jesfab.com.au Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S |
Bill,
You your digram is great (correction) and shows the BOV fliped. That is exacly how I set mine up. When I did mine some 6 years ago, the spring tension was adjustable and I used a hand vac to calibrate it. I also flipped the BOV so boost was pushing on the bottom of the piston and vac was pulling on it. This ensured it was open on idle and boost. On boost the piston surface area ON TOP was about 3 times that of the piston the boost was pushing against. With this when the vac went away to spring tension would help close the piston but it was the boost entering the top of the BOV with three times the effort that closed it and kept is closed on boost. A second reason I flipped my BOV was I feared that side load might alow the piston to bind. With the change I thought there was less chance of this happening. There was twin turbo guy here that had there BOV stick and he sheared a Turbo Shaft. Again, w a K27-7200 I had an instant .2-.3 bar boost off idle and .5 off cruse with this arrangement. I added to the a way to lower control pressure at the WUR with acceleration. Thous two things together make a significant difference in my throttle response. This can be done with the D-WUR. Last edited by 911st; 11-13-2009 at 07:05 AM.. |
Roland,
Synapse makes the BOV that can act as an intake deverter. There is a link to a U tube video that showed it somewhere in this thread. Advanced CIS Turbo Tuning Discussion Thread. Ultimate? Speedy, I do not believe the stock overrun valve stays open at idle but not 100% sure. Wish we could get a factory digram and or description to verify. Again, from articles on 930 tuners over the years I have seen hints as to modifying the valve to achieve increased throttle response which suggests that it is only used as an anti stall valve between shifts, not a bypass valve under low load. Also, with Porsches redesign of the 3.3 CIS motor for the 91 turbos the Bosh BOV was designed to function as only a BOV I belive. |
Metal Guru
Wow, that could work.
Keith, what vacuum setting did you use to set up your bov. I have a Forge hybrid bov with an adjustable spring. If you remember, I'll set mine up that way tomorrow and report back with results. The Forge bov is half the price of the Synapse, by the way. Cool stuff.
It was 6 years ago so I am not 100%sure.
I think I measured the manifold vac at idle and cruse (via connection with my custom electronic-WUR's MAP sensor.) and used that as reference points. I used a hand vac on the BOV with it off the car where I could watch the piston. You want it open at the lowest vac you expect to see and to close when that drops as you start to accelerate. Probably comming in on the less spring tension the better. For this to work the BOV has to have larger surface area in the upper chamber that is hooked to the intake manifold for Vac-boost so it can push against the boost that will be trying to push it open from the pressurized / inter-cooler end. Before you do this please get a base line feeling for how fast your boost responds by watching your boost gage off curse and idle. Also try blipping your motor from idle to see how it responds. Then after the conversion you will have something to compare against. Good luck. |
Thread Tools | |
Rate This Thread | |
