Order Online or Call:
888-280-7799
HACKER SAFE certified sites prevent over 99.9% of hacker crime.
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Click Here To Add Your Car to Our Owner's Photo Gallery!!!
Chat with other Users in the Chat Room NOW!!!
banner
The Pelican Parts Forums salutes the memory of Warren Hall (Early S Man), 1950 - 2008.  You will be missed by all... [Click for more details]
spence88mph's Avatar
Ricks Stage 2 Carrera Turbo Build 485hp
I thought I'd post this in here.
Rick has been working on this for a while and has done a great job of it, decompressed to 8.5:1 with C2 turbo head gaskets and .5mm base gaskets.
Stage 2 is rated at 485crank at .85bar by Proto, should be quite a weapon in a narrow body, pretty much CTR specs! Very cool. You can also see some of Brian's handy work hanging off the back.
He;s still running it in but says the power is already pretty brutal.
Well done Rick!
here is more info on the build:
Rick's engine rebuild starts in Cleveland
'89 Carrera M491 with GT30R turbo, GOLF GTI, Aprilia RS250
spencer james
Old 11-16-2009, 03:29 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Crotchety Old Bastard
RarlyL8's Avatar
Wow, I hadn't seen pictures. That's gotta be a handful!
Brian B.
RarlyL8 Motorsports - 930 Turbos and Exhaust Systems
ph: (256)698-4992 Email: Brian@RarlyL8.com
Old 11-16-2009, 05:51 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
BReyes's Avatar
Very nicely detailed motor there, down under. Any tuning you have to do next? Or plug and play Protomotive reworked DME? And that's some hot rod targa to boot (I mean boost). Is the flame expected to propogate at all out the rear?
That is some spring time top down fun you are building there.
Cheers.
Bernard
Old 11-16-2009, 06:46 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Not mine buddy, it's Rick Chipa's he will chime in I'm sure.
I can say it looks like a Protomotive FPR which is very plug and play, I use one too, very easy!
Don't know about flames, here's for hoping though! I would doubt EFI would flame as much as CIS or MFI though, more precise fueling...
spencer james
Old 11-16-2009, 08:47 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
RarlyL8's Avatar
Just an observation but Rick is really testing the limits of that 3 wheel engine stand. I mounted my engine on a 750# stand just like that and once fully dressed it became very unstable. I now have a 1000# stand with 4 wheels.
When can we see some YouTube? I wanna watch that baby light 'em up!
Brian B.
Old 11-17-2009, 02:55 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
That is a lot through a 915 transmission???
What is the transmission plan?
Old 11-17-2009, 06:34 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Infidel
JBL930's Avatar
Looks like a beast!
Jonathan.
87 930, with a 993tt engine, so i suppose it's a 9930?
Old 540 BMW
CR450F SM for being a hooligan
XB12S Modified, for being a total hooligan
Old 11-17-2009, 07:12 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
Drive it like u stole it.
jonesb930's Avatar
+1 on the engine stand. I upgraded to a 4 wheeler as well. As Brain said, it gets a bit unstable fully dressed. It also allowed me to remove the engine with a jack instead of a crane.
____________________________
Bill Jones
Jupiter, FL
77 Euro 911 3.0 Wide Body - under construction
http://www.flickr.com/photos/rennsport/collections/72157618856489537/
Old 11-17-2009, 07:34 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
Gearbox has been rebuilt, upgraded clutch, should hold up if he treats it well, time will tell... Brian runs one with success but at a lower power level.
A shortened g50 would be sweet eventually, budget permitting.
spencer james
Old 11-17-2009, 02:23 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
Thanks for all the good comments. I have about 50 miles on it and got to 4000 rpm tonight. Still breaking it in. So far I am very satisfied with the build. A very streetable setup.
The gearbox is a weakspot. I am not into pulling holeshoots so hopefully it lasts.
I actually had no problems with the engine stand, it does look a little light, but I purchased it to work on my dads 429 ford marine engine and it held that fine too.
Thanks Again,
Rick
1985 911 Targa Protomotive Stage II 911 Turbo
2008 VW R32
2009 Chevy 2500HD
2010 Sabaru Outback
Old 11-17-2009, 05:43 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
RarlyL8's Avatar
The Carrera 915s are the strongest ones made. If you ever tear it down put in the WEVO bearing retainer and all should be good. You know not to beat on it and with that power you won't have to!
Brian B.
Old 11-17-2009, 07:37 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #11 (permalink)
very cool! glad i could help with it!
2008 VW R32
1995 Jeep Wrangler (YJ)
Old 11-18-2009, 05:43 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #12 (permalink)
Join us in Monterey for the Pelican Wine Tour & Canyon Run!  Click Here!
Hi Rick Chip:
I am going the same route as you did. Would like to know where did you find the 0.5 shims and C2T head gaskets? Through Pelican? Also, did you changed the fuel pump or used the stock Carrera? Different chip map than the stage one?
Thanks in advance,
Francisco Soto
Old 11-23-2009, 12:29 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #13 (permalink)
Hi Francisco,
All my engine part work was done by Walt at Competition Engineering in California and I got the shims and C2 turbo gaskets from there also. I am using the stock Carrera fuel pump so far, I have about 150 miles on it so far, and the chip came from Todd at Protomotive Engineering.Yes the chip is mapped differently from a stage one.
Thanks,
Rick
2008 VW R32
2009 Chevy 2500HD
2010 Sabaru Outback
Old 11-23-2009, 01:21 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #14 (permalink)
it's finally complete with newly installed turbo tail. a cell phone picture will have to do for now.
Rick
2008 VW R32
2009 Chevy 2500HD
2010 Sabaru Outback
Old 03-13-2010, 09:56 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #15 (permalink)
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.3.1
Garage Plus vBulletin Plugins by Drive Thru Online, Inc.
Copyright 2009 Pelican Parts - Posts may be archived for display on the Pelican Parts Website
One of the largest message boards on the web !
