spence88mph's Avatar
Ricks Stage 2 Carrera Turbo Build 485hp
I thought I'd post this in here.
Rick has been working on this for a while and has done a great job of it, decompressed to 8.5:1 with C2 turbo head gaskets and .5mm base gaskets.
Stage 2 is rated at 485crank at .85bar by Proto, should be quite a weapon in a narrow body, pretty much CTR specs! Very cool. You can also see some of Brian's handy work hanging off the back.
He;s still running it in but says the power is already pretty brutal.
Well done Rick!
here is more info on the build:
Rick's engine rebuild starts in Cleveland
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 11-16-2009, 04:29 PM
Crotchety Old Bastard
RarlyL8's Avatar
Wow, I hadn't seen pictures. That's gotta be a handful!
Old 11-16-2009, 06:51 PM
BReyes's Avatar
Very nicely detailed motor there, down under. Any tuning you have to do next? Or plug and play Protomotive reworked DME? And that's some hot rod targa to boot (I mean boost). Is the flame expected to propogate at all out the rear?
That is some spring time top down fun you are building there.
Cheers.
Bernard
Old 11-16-2009, 07:46 PM
Not mine buddy, it's Rick Chipa's he will chime in I'm sure.
I can say it looks like a Protomotive FPR which is very plug and play, I use one too, very easy!
Don't know about flames, here's for hoping though! I would doubt EFI would flame as much as CIS or MFI though, more precise fueling...
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 11-16-2009, 09:47 PM
RarlyL8's Avatar
Just an observation but Rick is really testing the limits of that 3 wheel engine stand. I mounted my engine on a 750# stand just like that and once fully dressed it became very unstable. I now have a 1000# stand with 4 wheels.
When can we see some YouTube? I wanna watch that baby light 'em up!
Old 11-17-2009, 03:55 AM
That is a lot through a 915 transmission???
What is the transmission plan?
Old 11-17-2009, 07:34 AM
Infidel
JBL930's Avatar
Looks like a beast!
Jonathan.
87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines.....
Old 540 BMW, XB12S Modified, for being a total hooligan
Old 11-17-2009, 08:12 AM
Drive it like u stole it.
jonesb930's Avatar
+1 on the engine stand. I upgraded to a 4 wheeler as well. As Brain said, it gets a bit unstable fully dressed. It also allowed me to remove the engine with a jack instead of a crane.
____________________________
Bill Jones
Jupiter, FL
77 Euro 911 3.0 Wide Body - under construction
http://www.flickr.com/photos/rennsport/collections/72157618856489537/
Old 11-17-2009, 08:34 AM
Gearbox has been rebuilt, upgraded clutch, should hold up if he treats it well, time will tell... Brian runs one with success but at a lower power level.
A shortened g50 would be sweet eventually, budget permitting.
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 11-17-2009, 03:23 PM
Thanks for all the good comments. I have about 50 miles on it and got to 4000 rpm tonight. Still breaking it in. So far I am very satisfied with the build. A very streetable setup.
The gearbox is a weakspot. I am not into pulling holeshoots so hopefully it lasts.
I actually had no problems with the engine stand, it does look a little light, but I purchased it to work on my dads 429 ford marine engine and it held that fine too.
Thanks Again,
Rick
1985 911 Targa RarlyL8 center outlet muffler & waste gate dump,GT30R turbo,.9 bar spring,Canems programable DME, around 400 wheel hp SOLD BUT NO FORGOTTEN
Old 11-17-2009, 06:43 PM
RarlyL8's Avatar
The Carrera 915s are the strongest ones made. If you ever tear it down put in the WEVO bearing retainer and all should be good. You know not to beat on it and with that power you won't have to!
Old 11-17-2009, 08:37 PM
very cool! glad i could help with it!
2008 VW R32
1995 Jeep Wrangler (YJ)
Old 11-18-2009, 06:43 AM
Hi Rick Chip:
I am going the same route as you did. Would like to know where did you find the 0.5 shims and C2T head gaskets? Through Pelican? Also, did you changed the fuel pump or used the stock Carrera? Different chip map than the stage one?
Thanks in advance,
Francisco Soto
Old 11-23-2009, 01:29 PM
Hi Francisco,
All my engine part work was done by Walt at Competition Engineering in California and I got the shims and C2 turbo gaskets from there also. I am using the stock Carrera fuel pump so far, I have about 150 miles on it so far, and the chip came from Todd at Protomotive Engineering.Yes the chip is mapped differently from a stage one.
Thanks,
Rick
Old 11-23-2009, 02:21 PM
it's finally complete with newly installed turbo tail. a cell phone picture will have to do for now.
Rick
Old 03-13-2010, 10:56 AM
