Where to get C2 elbow or alternative
Our host seems to sell these but it is a special order. Anyone know of an alternative elbow? I assume that I can get a silicone albow and then attach a BOV to the IC correct?
Here are photos of two alternatives for plumbing the BOV discharge into the turbo inlet ducting, one photo shows a factory elbow modified with a 1" aluminum flange and a short connector hose (places the valve in the stock C-2 turbo location), The other photo shows a steel 1" elbow bolted to the connector tube between the A/F meter elbow and the turbo inlet steel duct, Both work equally well.
Regards, Lou ![]()
E-85 sippin drunk
If you contact Kokeln directly, they sell an installation kit which inlcudes the 90* rubber elbow, the Al connection pipe, and the recirc valve.....
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
An elbow just sold on eBay for $30. I almost picked it up, just because, but I already figured out an alternate way to do the updated BOV without it.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
Doesn't the factory elbow go from say 4" to 3" and then the aluminum adapter takes it from 3" to 2 1/2" (or some similar numbers?).
You could probably get a 90* silicone elbow and have a muffler shop make a reducer for you. No idea if this is cost effective. |
SR-250-300-BK |
I have build this a while ago, machined from alumiunium.
It fits straight on the 930 elbows, bov can be connected easy. ![]() Falk
87 930 bblk/blk 88 3.6 white/blk |
forwheeler, the aluminum piece is optimized for flow.
There is no step inside, its a cone ( hopefully my english fits here ~) More, on the bigger side the edge was cutted with a nice radius. For flow, the part is fine, much better then the 930 original piece. Falk
Ah yes, very nice!
