Turbo 3.3 engine without intercooler
Hi
Is it possible to run the 930 3.3L (1980) turbo engine without the inter cooler? If so, how will the engine respond? I want to fit it in a 1973 carrera-look car without wing. thanks Jon Sigurdsen |
Infidel
I wouldn't run it without an intercooler, you should get a cooler fabbed up to fit under the tail you plan to fit, here are a few that have been done similar to what you may need, obviously some better than others
Jonathan. 87 930, 993 turbo engine, RS Tuning 520PS/515lbf-ft, Arrow Rods, ARP hardware, Solid lifters, G50-50, RS Flywheel, 890nm Sachs clutch, RSR coil overs all round, 993 C4 calipers front, 930 fronts on the rear, Ruf Speedlines..... Old 540 BMW, XB12S Modified, for being a total hooligan
The Carrera look you want is far out-weighted by the cost of melted pistons.
It has been done but not without some type of charge cooling. Cole
Cole - 80 930 "The Old Sled" Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports. |
beancounter
another option to consider is meth injection.
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
What's your time frame?
The custom intercooler on the white car (middle picture) in our handiwork. We're starting on another one for a car coming in July (1976 930 with Carrera ducktail and our EFI). We can make one for you, too, at the same time. Contact me for details and pricing.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Yes it can be done. Porsche did it with the 3.0 turbo with a little lower compression and .6 bar instead of .8 bar boost.
However, most that want a turbo want power and the differance between a good intercooler and none is probably a good 50hp for the intercooler alone and another 10% HP from the higher boost you can run. |
thanks, Ben
1986 3.2 Carrera |
Cooler air is denser therefore more power.
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
Yes it can be done. Porsche did it with the 3.0 turbo with a half point lower compression and .6 bar instead of .8 bar boost.
I am not an expert but I suspect if one ran a very efficient turbo and knew what they are doing and they did not run more than about .8 bar on a street car, rant good fuel, and with some tuning they might get away with it. I would be very careful with boost on a hot day. However, most that want a turbo want power and the difference between a good intercooler and none is probably a good 50hp for the intercooler alone and about another 10% HP from the higher boost you can run. That is a big differance. I think the guy that ownes that intercooler shown under the black deck lid was trying to sell it as he had his car up for sale. |
ahhhh.
1986 3.2 Carrera |
Here it is: TurboKraft Intercooler for sale
3 restos WIP = psycho
The methanol injection idea is a good one and there are lots of kits out there. The water/methanol mixture (a myriad of windshield wiper fluid works, just not the kind with glycol in it) acts as as an intercooler through evaporation in the intake tract and is actually more efficient than an air/air IC. Water also acts as a detonation reducer, while the methanol acts as an octane improver so you get a triple whammy benefit of being less knock prone from the water, being less knock prone from the octane bump and getting a cooler intake charge from evaporation. The big downside is adding another consumable liquid and the weight of the fluid/tank to the mix on top of gasoline. Also, if going this route you need a good kit with a failsafe, as you are a clogged sprayer away from a melted motor...the failsafe controls the wastegate in case of failure to reduce boost pressure so you can drive the car home, albeit under reduced power.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Of course, with a little plumbing work to hook up the CIS to the intake manifold, a person could run a 3.3 turbo engine without running any boost. Then, you would just have a dog low compression engine....but you could tell people "it's a turbo" (engine).
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
