Tilikum Turbo's Avatar
930 Acronym help
Greetings all.
Many of you have been a big help in questions on my car, as it has morphed from an SC too it's present 3.3L Turbo(especially Brian of Rarely L8)
I have read so many acronyms that most of it I don't follow it. Did find out last night WUR is 'warm-up regulator'
Anyone have a list that they could help me with, so when I read others questions and replys, I am more in tune.
Thank you!
1983 911 3.3L Turbo(YES, I know the turbo badge is on the right...had to be different!)
1996 Toyota Corolla(der 'clapper')
Old 09-14-2010, 11:16 AM
mark houghton's Avatar
No such list exists, AFAIK. Don't feel stupid by just asking (we've all been there at one time).
Here are a few off the top of my head. Feel free to correct and/or add to the list.
WUR - warmup regulator, otherwise known as the control pressure regulator
LSD - a magical elixir brewed by Timothy Leary back in the 60's. Or, if you prefer, Limited Slip Differential
AAV - auxilary air valve
AAR - auxilary air regulator
TTS - thermotime switch
CDI - capacitive discharge ignition
OB - generally used in discussion, referring to Over Boosting
MSD - aftermarket ignition
ATDC - after top dead center
BTDC - before top dead center
EBC - electronic boost control(er)
WG - wastegate
PP - pressure plate
TB - throttle body
TOB - throwout bearing
IC - intercooler
BOV - blowoff valve
BL - Brian Leask (maker of adjustable WUR's)
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, stock everything else. The result of a massive Pelicanite good will fire recovery effort. Truely an open book, ready for the slippery slopes to modification.
Old 09-14-2010, 12:36 PM
good list Mark
fwiw,
MSD is short for multiple spark discharge... or multiple spark capacitive discharge ignition to explain it.
Old 09-14-2010, 01:30 PM
full quack's Avatar
Send a message via Yahoo to full quack
This thread could go south in a real hurry, so to help keep it clean, I'm going to stop writing right now!
Mark
Old 09-15-2010, 12:14 PM
After the next project
x98boardwell's Avatar
Forgot one
Should we tell him what DSL stands for.... Just kidding. Great list Mark.
Bryan
Current cars: 2012 Cayenne TT, 1997 993TT, 1987 911 Carrera, 94' 928 GTS, 1912 Buick Model 34, VW GTI
Old 09-15-2010, 12:33 PM
WG - wastegate
PP - pressure plate
TB - throttle body
IC - intercooler
BOV - blowoff valve
Thanks much!
Old 09-15-2010, 02:42 PM
Tinkering Pays!!
mooney265's Avatar
TB could also be Torsion Bar[s]
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 09-15-2010, 03:20 PM
esotoracing's Avatar
WEGO Wideband Exhaust Gas Oxygen. . . . sensor. or WB02
and if you go standlaone fuel/ign controler youll need the following
TPS throttle position sensor
MAP manifold absolute pressure.......sensor
MAF mass air flow.......sensor
ECU engine control unit also known as PCM powertrain control module or EEC Electronic engine control
IAT intake air temp....sensor
WOT wide open throttle
CKP crankshaft or cam position sensor
FRP fuel rail pressure
theres more but i dont want to mess up your head
theres nothing like the rear end squatdown of a turbo
Old 09-15-2010, 03:55 PM
Tinkering Pays!!
mooney265's Avatar
Yeah, I really struggled with "WOT" when for the first couple of months on this forum - - Just couldn't figure it out
Old 09-15-2010, 04:34 PM
Large Member
krasuskyp's Avatar
nothing to add, with exception you are advised to avoid any of my posts... known to typically require Paulie-to-Engrish secret decoder ring.
GL!
8-)
Paul... CT | '87 930 | '08 M3 6gang vert |
past:
| '07 S6 | '98 M3 vert | '01 M5 | '96 993 C2 cab | '05 S600 Sport - biturbo V12@Just Not Right 495rwhp / 612rwtq |
| '58 TR3A | '01 S8 | '95 S6 6gang | '88 M5 | '87 190E 2.3-16 |
Old 09-15-2010, 06:15 PM
WG - wastegate
PP - pressure plate
TB - throttle body
IC - intercooler
BOV - blowoff valve
WEGO - Wideband Exhaust Gas Oxygen. . . . sensor. or WB02
TPS - throttle position sensor
MAP - manifold absolute pressure.......sensor
MAF - mass air flow.......sensor
ECU - engine control unit also known as PCM powertrain control module or EEC Electronic engine control
IAT - intake air temp....sensor
WOT - wide open throttle
CKP - crankshaft or cam position sensor
FRP - fuel rail pressure
AFR - air to fuel ratio
Man, we're smokin' now!!! Added everyone's input to-date. WTF AFAIK there aren't too many acronyms left. Hey, this could almost be a new sticky!
Old 09-15-2010, 06:43 PM
boostfix's Avatar
Was just reading through 911st's Advanced CIS Turbo Tuning Discussion Thread and noticed the use of MP for metering plate.
good thread
Dan
88 930 blk/gry
Old 09-15-2010, 09:21 PM
Chain fence eating turbo
IIRC and AFAIK, there are a lot more IMO
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, soon to be 993SS cams and GSXR 750 ITB's fed by 964 intake, Borg-Warner S366 turbo @ 1.4 bar, Treadstone full bay IC, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MegaSquirt 2 (v3.57 board) w/EDIS, Tramont wheels (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 09-15-2010, 10:07 PM
WTF what the *&%$. . . .youll get this one alot working on your own car.
and after your all finished call your buddies up with a
BYOB gathering ASAP
Old 09-15-2010, 10:08 PM
Groovie Ghoulie's Avatar
DP = Both a German aftermarket parts manufacturer, and an advanced technique used in the adult film industry.
Old 09-15-2010, 11:25 PM
