66cal912's Avatar
Turbo Rebuild on 3LDZ that upgrades it to a K27, Anyone used this service?
Has any one used this service to upgrade a Stock 930 3LDZ turbo to a similar spec of a K27? I found this listing on Ebay offering the service and its definitely more cost friendly then slapping down the money for a K27-7200, given I am on a limited budget at this point? Any advice with this service or seller would be appreciated. The ad on Ebay looks pretty legit, and the turbo characteristic Chart, seems reasonable.
Please check it out:
Porsche 911 930 K27 3LDZ Fast Spool UPGRADED Turbo - eBay (item 170319204245 end time Apr-27-11 11:55:02 PDT)
thanks Ahead of Time! Ben
Old 04-01-2011, 03:35 PM
Looks like a reasonably priced rebuild / upgrade.
Shoot them a message and ask what their warranty is?
Looks good to me though
Old 04-01-2011, 07:30 PM
Tug68's Avatar
Tagging along, looks good.
Tim
87 930:G-50 5 Speed, Powerhaus Headers, K-27, Garretson Intercooler, RarlyL8 exhaust and 1 bar boost....
Gone: 85 911:Wevo shifter,full adjustable suspension,bigger torsion bars,Carbon fiber hood,930 brakes and rims.
Old 04-02-2011, 07:49 AM
Crotchety Old Bastard
RarlyL8's Avatar
I use them for the 3LDZ rebuilds and upgrades we offer.
The stock rebuilds are nice for restorations and preservation cars while the modified 3LDZ is a good option for spec racers and enthusiasts who want a 100% plug and play turbo.
The characteristics of the modified 3LDZ move it toward those of a K27-7200. Design constraints of course do not allow replication of the 7200's map. I haven't put one on a dyno yet as it must be the only change taking place. Often there are other changes made at the same time, such as the muffler, which would skew the results.
Old 04-02-2011, 08:06 AM
oilonly's Avatar
I purchased one from Brian and it absolutely spools up faster than my stock 3LDZ.
'87, Modified WUR, Billet valve, 965 downpipe, Kokeln intercooler, GHL headers, Garrett T04B K27 hybrid, Tial w/.8 bar, WEGO IV, RarlyL8 dual out, LSD
Old 04-02-2011, 01:46 PM
66cal912's Avatar
Thanks!
Guys,
Thanks for the input. Much appreciated. Brian I was wondering if these were the same guys doin your rebuilds so thats good to know. If I go this way that definitely gives me confidence in going this route.
Ben
Old 04-03-2011, 09:33 AM
66cal912's Avatar
Quick question, if I went with the high flow 3ldz turbo, would the stock intercooler and cis be adequate, or will I need additional fuel enrichment? Thx, Ben
Old 04-03-2011, 10:15 AM
oilonly's Avatar
Don't know if it is needed but I also installed a larger long neck intercooler. I didn't change anything on my CIS system.
Old 04-03-2011, 03:59 PM
RarlyL8's Avatar
No fueling mods are needed, however you should always verify your AFRs when making changes.
Stock intercooler is OK unless you are running more than stock boost, there should be no change in the heat load by adding this modified turbo for street use. In general bigger intercoolers are always a plus as anything that cools the intake charge is good.
Old 04-03-2011, 05:58 PM
surfpangea
Sam Matthews's Avatar
3ldz
The first one I have purchased from Bruce leaked in the center but i resealed it and it works very well
MB CL 600 6liter V12 daily driver
86 Corvette Stage 1 Nos (sold)
78 911sc Targa (sold)
77 930 stock 3.0 gsf header ,borla exhaust,gt30 BB turbo, V-band, full bay IC,WMI, 46 mm Adjustable waste-gate,Zeitronix wideband, Intergrated Car pc, Winlog interface Beta
Old 04-03-2011, 10:53 PM
p9eleven's Avatar
3LDZm
How did you reseal it?
I have same issue that oil leaking from center (v-Band).
Thanks.
Old 10-11-2011, 09:02 AM
66cal912's Avatar
Hello,
a few people emailed me on this topic some months back and I appoligize I have been so busy I never got back to you guys. I looked into the K26 rebuild / upgrade, but I decided to go with the 964 Turbo spec K27 KKK. Also this turbo as is will not fit the stock K26 brackets as most of you have or will find out. However there is an advantage of being in this business so long, and that is the fellows at Andial can help you out by machining the hot side turbo housing on a K27 to fit all the stock mount points / bracket and muffler if you desire. They still sell new in the box K27s and others if you need them. A little more then others, but the fact its drop in and their adapter is super cost affective, I would recomment them 100%, ask for Pete to help you, if you go this route.
Ben
Old 11-18-2011, 02:31 PM
