Smart quod bastardus
fredmeister's Avatar
getting engine up on engine stand
How do most of you guys lift the engine onto the engine stand? I ask because I dont own a hoist.
Just have a floor jack and dont want to buy a hoist for 1 job.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 11-17-2010, 09:19 AM
A930Rocket's Avatar
I had some friends help me after installing the engine mount. Just lifted it up and inserted it into the stand. Of course, anything y ou can remove to lighten the load helps.
Next would be renting a hoist.
Old 11-17-2010, 10:20 AM
torresmd's Avatar
2 or 3 other guys and just bear hug it. It is not that bad.
1998 993 C2S Guards Red/Black
1990 964 C2 RWB project car
2016 GT3RS White Daily driver
2018 Lamborghini Performante Gegio Telesto
Old 11-17-2010, 12:48 PM
Oh that is easy. Just build a wooden blocks to support your jack or motorcycle jack which you used to rest the engine on. You can then raise it to the height of your engine stand, and slip the engine stand in between the blocks.
See attached picture on how I built mine. I raised heavy ass 964/993 engine like this by myself and in relatively safety.
Old 11-17-2010, 12:57 PM
