The Old One could use some help !!!!
Can anyone help me with a some pics of the AC brackets on 79-85 Euro 930. I
have the brackets but can't seem to put together where and how they attach. I have searched and found nothing that helps. I have manuals and the Pet and still nothing helps. This is truley an instance where pictures would be worth a thousand words.
Thanks in advance !!!!!!
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 11-28-2010, 09:07 PM
Blackbird Pilot
Reaper930's Avatar
Sorry Cole, if I had AC I'd be more than happy to help ya...hope someone on the board can chime in soon for you!
Reaper | The Outlaw 930 Hotrod Gruppe Fünf Gruppen.com | The Baddest 934/5 Parts for the 911/930 D-Zug.us
Old 11-28-2010, 09:19 PM
beancounter
jwasbury's Avatar
Photos of my '79...its a US model, not Euro, but perhaps they are the same?
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 11-28-2010, 09:26 PM
Jacob
YOU DA MAN !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
THANKS !!!!!!
Cole
Gabe
Real men don't need no stinking AC, it slowes you down !!!!
I'm transforming the bracket to a 934 type mount for the CIS to shorten the
turbo intake runner.
Cole
Old 11-28-2010, 09:42 PM
MikeD930's Avatar
Looking fwd to see your CIS relocation. Oh BTW, isn't this forum great!?! That's the 1st time I saw metal bracket AC assembly. I thought all AC brackets were aluminum.
MikeD '87 930
Old 11-29-2010, 04:58 AM
Hey Mikie !!!!
Hope thing are going well buddy. The calender looks like it should be a big hit.
Great pics.
Gracie told me to tell you HI !!!!!!
Those old steel AC brackets are the reason the cars all leaned on the passenger side. I took the da-- thing off 20 years ago and could find nothing on
how it goes back on. I'm actually using the original to get mounting hole location
holes. I have a friend that's going to fab one out of ALU. I should have sent it to you and you could have taken it to work.
The best to you and the family my friend !!!!
Cole
Old 11-29-2010, 08:58 AM
beancounter
jwasbury's Avatar
Exaggerate much Cole?
If anything, the weight of the steel bracket (not much, really) may help to counteract the weight of the turbocharger, which as you know is on the driver's side
Jacob
Old 11-29-2010, 10:17 AM
Jacob,
Excellent point my friend. Ends up being a counterbalance, all this time it was just superb German Engineering.
Old 11-29-2010, 10:22 AM
Crotchety Old Bastard
RarlyL8's Avatar
These cars came with AC?
Cole, I relocated the CIS on a twin turbocharged engine a few years back. Made my own mounting brackets. The only requirement I used was that the air metering plate sit parallel to the ground when in the resting/closed position, and I'm not so sure that is mandatory.
Old 11-29-2010, 10:57 AM
Happiest when Tinkering
gsmith660's Avatar
I cant help much but looks intresting I would not think the metering plate be level because it is rarely level while driving the car. Good luck I would try some kind of trick billet mount.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 11-29-2010, 01:38 PM
jsveb's Avatar
I am asking this just for you to educate me, and maybe me understand the CIS a little better, So OT - sorry in advance...
If there was a difference in how the metering plate would react, that would mostly be because gravity now "influencing" the plate differently and the resistance in the travel, again due to gravity has changed. If this is the case, can't one not just adjust the WUR the regain the correct CP? etc.
Jesper
Old 11-29-2010, 01:54 PM
RarlyL8's Avatar
That's true but I was thinking about when the car is sitting and the fuel pressure bleeds off, a picky point.
Old 11-29-2010, 01:55 PM
jsveb's Avatar
OK, Just trying to learn.
Jesper
Old 11-29-2010, 02:22 PM
MikeD930's Avatar
Hey Cole!
Ya, will you give Gracie a dog treat and pat her head for me?!?
Thanks for your comments on the calendar.
About the weight of the AC balancing out the turbo...isn't your turbo going to be centered behind the engine??? I think so; therefore, disregard what others said about the car leaning!
Looking forward see your completed Old Sled and to cruise with ya to P2O next year (it's usually at the end of July).
MikeD '87 930
Old 11-29-2010, 02:34 PM
Mike:
I'll be ready in July !!!!!
Brian & Jesper:
This same CIS has been used on hundreds of different cars and in hundreds of different locations. I think as long as you keep it reasonably level and don't mount it upside down it will be fine. Besides that I have an edge, I'm also installing the "Magic Mystery Velocity Cone"
Cole
Old 11-29-2010, 05:29 PM
