laughac's Avatar
Send a message via AIM to laughac
DWUR is not the worst idea... but which one?
Can anyone direct me to a good DWUR?
I've read about one, and only one, and now I can't even find it.
2000 Boxster S
2004 330ci convertible
1978 450 SLC
1924 Model T Ford touring
Fleet of Ford Buses, Sedans, SUVs and Limos
Old 02-21-2011, 08:12 PM
laughac's Avatar
By the way, yes, I searched and found the thread on DWUR with over 1,000 posts.
I'll read through it all eventually, but is there still only one company making a DWUR?
2000 Boxster S
1978 450 SLC
Old 02-21-2011, 08:29 PM
lite75's Avatar
I have a greddy controller with frequency valve for sale, same unit I sold stup.
Works excellent, $550.
Meter head flow adjustment question??
75 930, 76 930, 83 SC EFI turbo
Old 02-21-2011, 08:32 PM
laughac's Avatar
Doe the Greddy use wide band or narrow band 02 sensor?
2000 Boxster S
1978 450 SLC
Old 02-21-2011, 09:02 PM
lite75's Avatar
Its programmed using map, rpm and frequency valve settings, It doesn't use a 02 sensor for input.
I used a zeitronics data logger with a wide band 02 for the air fuel readings.
Old 02-21-2011, 09:20 PM
totle's Avatar
Thierry has written a nice way of controlling your system
ELECTRONIC CIS fueling & BOOST control
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 02-22-2011, 12:38 AM
Tinkering Pays!!
mooney265's Avatar
BTW: the DWUR doesn't use on o2 sensor, either...
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 02-22-2011, 04:17 PM
laughac's Avatar
Thanks, I'm learning.
Wondering what to do between now and EFI, and if I even want EFI.
I've been disappointed with the fuel curves of most EFI tunes so far.
There just seems to be no solid solution, and every system is a compromise.
2000 Boxster S
1978 450 SLC
Old 02-22-2011, 04:25 PM
Crotchety Old Bastard
RarlyL8's Avatar
I match the fuel head and WUR to each other and the needs of the engine. If you are pushing less than 375WHP the stock fuel head can remain unchanged, the WUR made adjustable and then tuned to the correct curve for your mods. It takes some time to dial it all in but the resulting curve is very close to EFI if not identical to most. There is also the option to have the WUR rebuilt with a custom curve, plug and play and forgetaboutit.
Personally I don't like the digiWUR due to the failure mode having the possibility of leaving you stranded or running dangerously lean. Mechanical WUR failure mode is typically a slow deterioration in performance of the device.
Old 02-23-2011, 05:15 AM
