Floating rotor replacement
I'm getting ready to replace the front rotors on my 79 930. I've done brake work on normal cars but not on 917 brakes. Are there any tricks involved or is it as simple a swap as it appears. I don't have the service manual and would appreciate some guidance.
Old 03-02-2011, 08:21 AM
Dog,
It's about as simple and straight forward as it gets !!!!
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 03-02-2011, 10:12 AM
David's Avatar
Pretty simple. Where are you getting the rotors?
Old 03-02-2011, 04:53 PM
try the tech info center tab at the top of the page. maybe there's instructions there.
Old 03-02-2011, 05:54 PM
Smart quod bastardus
fredmeister's Avatar
Its just a little more work than normal rotors because you have to remove them from the hats and then rebolt the new rotors to them with all those little nuts and washers. Make sure to clean the hat mounting tabs to remove any brake dust so the rotors float like intended when you are putting them together. rotors are big $$ for these cars unfortunately.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 03-03-2011, 02:52 PM
