cover's Avatar
Boost problem
Hi everyone
I just installed Rarly L8 headers and muffler on my otherwise stock 1976 930.
It is a very nice "plug and play" fit and it sounds great.
In the meantime I have another problem:
Appearently I have no boost and the car wonīt rev beyond 4000 rpm.
It runs nicely below 3000 rpm but it has a hard time reving from 3000 - 4000 rpm.
The engine has been on the floor for about 3 months while the car was repainted
and I have adjusted the valves, renewed the plugs and plug cables.
I did a compression test also and it showed nice compression.
I have tried following witout solving the problem:
- Checked that the turbo was spinning freely before I installed the muffler.
- Adjusted the ignition. (with wacumhose connected....is that a problem?)
- Checked and tightened all hoses.
- Checked for exhaust leakes (can see no carbon residues anywhere)
- Tried two different wastegates.
I did find a small hole between the cooling ribbons on both wastegates (is that a problem)
Ilse: 1976 Porsche 930, Black, w. Rarly L8 headers & muffler.
Daisy: 1963 Jaguar E-type FHC 3.8, Carmen red (sold)
Old 05-03-2011, 06:08 AM
Tinkering Pays!!
mooney265's Avatar
No, I have one, too - - and no problem with boost/rpm's...
Do you think you could be "overboosting," thus causing your overboost sensor to shut off the fuel pumps? Or, maybe your overboost switch is malfunctioning?
Or, maybe you're running on 1 fuel pump [instead of 2]?
LIVN80S - - Red '79 Porsche 930 Steel Slant Nose Conversion [in 1987] w. 46k miles 3.3L; 964 Cams; K27HF @ 1.0 BAR, with Garrettson Intercooler; Rarly Zork; CIS Flowtech Fuel Head & BL-WUR.
Old 05-03-2011, 06:15 AM
cover's Avatar
Both fuel pumps are running.
Overboost theory is worth checking........ but I feel no boost at all when driving.
There is no boost gauge in the car but shouldnīt I be able to register a signifigant boost before the sensor cuts off the fuel?
Are the overboost sensor supposed to shut off the fuel pumps completely causing the engine to stop, or will it prevent further reving only?
Old 05-03-2011, 06:24 AM
Non User
infraredcalvin's Avatar
Easy to test the over boost switch, take the lead off and ground it on the case, my 76 had an empty blade already installed close to the switch. You are correct though, if the switch is failing you'll get some boost then your face will hit the steering wheel...
Sounds more like a boost leak, check your plumbing for tight seals.
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
‘71 914-6 GT 3.4L twin plug track car
'75 914 GT clone project
'71 914 track car, fresh 2165 FAT motor (for sale soon)
Old 05-03-2011, 07:18 AM
cover's Avatar
Just trawled the forum for similar issues.
One guy talks about a frozen "shutter valve" causing a 1977 930 to be restricted below 4000 rpm.
Picture of the shutter valve:
http://forums.pelicanparts.com/uploads4/83turbo1101254334.jpg
here is the thread:
Porsche Turbo Problems
Is this maybe worth checking?
Old 05-03-2011, 07:36 AM
Cover,
I was just going to suggest checking the shuttle in the recirculation assy. That would cause exactly what you are experiencing. Easy fix, take a look at that thread,
Cole
Cole - 80 930 "The Old Sled"
Mods: TurboKraft Custom IC, 934 Headers, GSX 61, Zork, Port Work, SC Cams, Air Mod Fuel Dist Relocated, Water Meth Injection, BL WUR, MSD 6530, Greddy EBC, Synapse Bov, Short 2nd & 3rd with 8:37 R&P, Wevo Shifter, Coupling, and Mounts, MTX-L SSI-4, Big Brakes, Rebel Coilovers, Bilstein Sports.
Old 05-03-2011, 11:06 AM
Crotchety Old Bastard
RarlyL8's Avatar
Hey there, didn't know you were having troubles.
Things that can prevent rev/boost:
- Ignition/timing malfunction, verify timing advance.
- Exhaust occlusion, not the problem.
- Low fuel pressure/flow, check system pressure.
- BOV malfunction, shouldn't prevent reving so ???
- Intake occlusion, rag left in throttle body?
- Mechanical brake on engine such as tranny lock-up, odd but can happen such as e-brakes not releasing.
I can't think of anything else off the top and encourage others to chime in. Good to eliminate the possibilities from the list and narrow the search.
Old 05-03-2011, 11:15 AM
Got Boost?
IMONBOOST's Avatar
Since your engine was dropped for some time, were any of the vacuum lines disturbed or intercooler piping? You could be running extremely rich under boost, do you see black smoke coming out the back?
"The only motivation to make you go race after race, travel after travel, is winning. The possibility that you have for winning. If you don't have that, nothing else can make you work."
-Ayrton Senna-
Old 05-03-2011, 03:49 PM
I think you have your fuel lines crossed. Happen on my rebuilt and the car would choke itself on boost and run like crap over 3000 rpm.
Robert
1985 Euro Red Carrera Coupe."SOLD",1985 White Targa Carrera. "SOLD",1977 Yellow 930. "SOLD",1991 Black 964 C4. "SOLD",2002 Silver 996 C4 Cab "SOLD",
2001 Polar Silver 996 twin Turbo
Old 05-03-2011, 04:48 PM
dhg1337's Avatar
I had First hand experience with crossing the Fuel lines, vacuum leaks, and left a paper towel in the intake tube infront of the turbo. Any of those can cause it not to rev.
Old 05-03-2011, 04:59 PM
cover's Avatar
Thanks guys
I will start checking
Old 05-04-2011, 06:13 AM
cover's Avatar
So, Iīve been checking hoses, ignition, recirkulation valve etc......didnīt find any problem and the engine still didnīt rev very well.
Decided to run a tankfull of gasoline with "Bell Add nozzle cleaner" added.
I drove approx. 50 miles......and bang!!! Suddenly she came back from the dead.
Now she Boosts, howls and roars like never before. Donīt ask me why.
Brian Bodart :-) that exhaust delivers pure audio-porn. It sounds a bit like an old RSR when the boost kicks in and everything goes on full song.
Boost also kicks in a couple of hundred revs earlier, thanks to the exhaust.
LOVE IT LOVE IT LOVE IT :-)
I will run another tankfull of gas with cleaning additive and then put the car on a dyno to make sure everything is tuned in perfectly.
Old 05-25-2011, 07:21 AM
cover's Avatar
Exhausts
By the way...speaking of exhaust systems.
I visited "JP Group" in Denmark last week with the local Porsche Club/forum .
This is the company behind Dansk Exhausts.
Very impressive factory and the owner is a huge Porsche fan and a very nice guy.
The company now produce original specification 930 exhaust for 3.0 l as well as 3.3 l.
They look very nice and this is as original as it gets in 2011.
(Dansk is an OEM supplier to Porsche)
But I will tell you one thing though!!
The craftmanship of the original Porsche exhaust as well as the 2011 Dansk version can not be compared to what you get from Rarly L8.
Brians work is simply in a different (higher) league.
Marry me Brian ....ha ha
Old 05-25-2011, 07:52 AM
RarlyL8's Avatar
Glad you're happy and all but that's gonna be a little awkward for the kids ...
Old 05-25-2011, 09:36 AM
