R.I.P.
Unique sound / Custom 930 muffler
I'm always looking for the perfect exhaust note from my 930. I have dreamed up a muffler system, let me know if it's been done. Your thoughts are welcome
I'm not sure what this will accomplish as far as sound. I figure there will be a muffler on each pipe or possibly just on the shorter one. Then maybe I'm just tired and need to close paintshop
Crotchety Old Bastard
What is the sound you are looking for? I've tried a bunch of different designs.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
R.I.P.
Brian, Just something more exotic. I do like the deep rumble of the magnaflow but i want something raspier (sp?)
are you thinking raspy as in the sound when accelerating with the old Factory Twin pipe sport mufflers?
Tim 1986 930 Gone:71,2,4 914's, 70T, 71T(RS),77S |
What about chambered mufflers like on the old mid year vettes. Allan's pipes has some that I was looking at. They can be made in many lengths and materials. Not the quality SS that Brian does, but none the less maybe something worth looking at. You may have to go to single outlet though. It would be tight to split it off.
John- 78 Slick Top 930 "Illegitimi non carborundum" |
With a turbo you want to stay away from chambers if possible. If a specific sound is required then of course some compromise is a given.
One fairly "raspy" system uses the MagnaFlow X-pattern muffler body, Series 80 if I recall. It is not chambered but the flow is interupted by the X (or y in the case of the 1 in 2 out turbo application). A single out version of this setup would eleminate the turbo whine which I would think is not desirable if you want 911 style raspy.
Chain fence eating turbo
I have a straight through muffler 12 inches long that sounds like a 1000cc sportbike that has aftermarket exhaust. It has a 4" perforated pipe internally with packing. I love the way it sounds! Might be from Protomotive but I'm not sure.
Has a deep rumble off boost and a nice, somewhat raspy sound under boost. Last edited by Tippy; 07-18-2011 at 10:19 AM.. |
R.I.P.
I'm running a MagnaFlow Y style muffler now. It's got a somewhat deep tone but I am looking for something a bit raspy as timc put it.
I thought sticking with smaller diameter twin pipes would give a raspier tone than a single large pipe. Hell, it's only some tubing, a coupler mufflers and some welding. I've wasted more time on lesser things. I'll post my findings |
I'd leave raspy to the small bore high revving guys.
Mine sounds kind of like a big block at idle and a 934 at full throttle. Since this picture was taken I've replaced the 3.5" ID x 4.5" OD x 12" long muffler with a 3.5" ID x 6" OD x 17" long muffler to knock off the noise a little and it still sounds wicked!
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Exactly David - that is some serious hardware.
I will have one similar (used the flange you water jet cut for me) that is brand new for sale shortly. Ended up going Turbonetics and making a whole new V-band clamp setup rather than chop up my sweet KKK flanged muffler. |
R.I.P.
David, You wouldn't have a sound clip of the car would you?
No, it's on my to do list but then it has been since I forgot to film it on the dyno years ago.
Nobody worries about passing emissions? I don't see a cat anywhere although I do like David's set up.
C.H. Boost Addiction - honestly, I have it under control 1989 911 Turbo Cabriolet Mods include: Kokeln IC, GHL Headers, Hooligan muffler, Modified K27 7200, BL WUR, LC-1 & XD-16, Bilstein Sports (4), TRG sway bars, Oversize torsion bars, Strut brace |
beancounter
My car sounds kind of raspy compared to other 930s. I don't really know why. It sounded raspy with the original USA exhaust and still sounds raspy with the upgraded system (SSIs and rarlyl8 muffler). The only thing I can think of is that the primaries are smallish (both on the original set up and SSIs) compared to others I've seen.
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
And being 79s, they are older than the 25 year mark making them immune to emissions testing (at least in Georgia). Just saying I'd like to see a car with a cat, something for us "younger" cars to look at.
R.I.P.
jwasbury - that sounds great
I'm watching the DVD Moby and The Warehorse Gang right now and its shocking too me how close to 935s my 930 sounds... I have a K27 with one of Brian's single exit exhausts.
Rob Montgomery '88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running |
Nice note!
