-   -   Another rust combat (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/634616-another-rust-combat.html)
proffighter 11-05-2022 12:36 PM
On bearing #1 there are some marks I don't guess they are results of wear. When checked with nail, they feel like outbreak, no signs around. I think just polish there to soften edges should be enought. Any thoughts/ideas where it come from?
http://forums.pelicanparts.com/uploa...1667676834.JPG
proffighter 12-05-2022 04:44 AM
Rebuilt starts
Cleaning and evaluation process of damages/needed or wanted parts/work almost completed. First I did is camshaft measuring and polishing bearing journals, went out quite nice while still within specs. Will do Plastigauge check when assembly
http://forums.pelicanparts.com/uploa...1670243920.JPG
Still there is an issue with getting parts. Regardless US or Europe, several shops says available, but when ordering, it's not (including our host!) I am a bit dissappointed, thought I can get some bigger movements between christmas and newyears eve, but it seems like it did not can be done...:(
However, will post step by step as soon there is some worth to show.
proffighter 12-20-2022 12:08 PM
Originally I wanted to start the crankcase assembly up to at least the cylinders during the Christmas holidays but because the case stud kit from ARP is not available anywhere since August when I wanted to buy. I cannot even put together the case halves.
What make me angry is the fact that a couple of shops listed them as stock, but on request they say a couple of weeks, then another few weeks and so on. Others are still telling 10 days while most indicates around March. At ehe and, no one can deliver for the next months...:mad:
They are made in the US they say, so I can not really comprehend why it takes so long apart from they us chinese steel...
However I still can do some other things like copy some plugs. While Oil pressure relief valve, Oil pressure regulator valve are 1:1 copies I made a blind hole in the cam housing plugs for weight reasons (no wonder) and finally the plug for the distributor delete. All high strength aluminum and anodized black
http://forums.pelicanparts.com/uploa...1671566540.JPG
gsmith660 12-21-2022 02:30 PM
Hey Roland Chris at Turbokraft has a mount that I bet would save you a few grams even from that beautiful bracket you made great work keep going
And some pics when mounted:
http://forums.pelicanparts.com/uploa...1430860278.jpg
proffighter 12-21-2022 02:37 PM
That's mine, but I guess I know which you mean. To be honest, I doubt it fixes the turbo good enough to avoid some movements. My RarlyL8 Headers are to nice to risk any cracks and a K27 is really heavy.
However thanks for input and kind words
Roland
gsmith660 12-21-2022 04:20 PM
Roland
Yes that is your bracket sorry for the misunderstanding Chris's bracket is very simple and easy to install and is basically a bolt and a small bracket but it holds my turbo very securely and is much lighter than the stock bracket
proffighter 12-22-2022 12:47 AM
This one you mean:
http://forums.pelicanparts.com/uploa...1671698104.jpg
Way to weak in my eyes. Not to bash the product, there may be some applications it will work, but regarding Turbo weight, only one bolt at one egde and a maybe 20x2mm metal strap is just not enough in my eyes to hold the turbo strongly. The original and my version are different for that reason. 1st there are 4 bolts more in the center of gravity from Turbo (vs one at the outer edge) and 2nd my (and OE) are about 3mm upright so the load which is mainly up and down is being carried over an area of 100mm or so (don't have the measurements exactly in my mind)
I would love to have a TK bracket to mount to proof what I suggest. Bet the headers are carry more load than the bracket.
gsmith660 12-22-2022 06:26 AM
https://parts.turbokraft.com/collections/exhaust/products/turbocharger-hanger-bracket-k-2x-series-and-t3-turbos
I have the second bracket shown and believe me I thought the same as you but after I installed it I changed my mind it supports the weight well and nothing moves
proffighter 01-04-2023 05:56 AM
I bought a set of new cylinder pistons. I wonder that there are no more groups for height (5 or 6 in a triangle), bore (0-1-2-3) and weight (-- - 0 + ++) as found normally and described in manual but this:
http://forums.pelicanparts.com/uploa...1672840373.JPG
Anyone seen this and know what is what? All I can see ist that all cylinders have an A and all pistons AB. So they are all the same specs and made more precise than those days the manual was printed?
66cal912 01-05-2023 12:13 AM
I imagine you can call up Mahle in North Carolina and ask for clarification.
MAHLE Motorsport can be reached at 1-888-255-1942 Monday - Friday 8am - 5pm EST.
motorsport@mahle.com
or:
MAHLE Industries, Incorporated
23030 MAHLE Drive
Farmington Hills, Michigan 48335 USA
Office hours: 7:30am - 4:00pm EST
Tech support: +1 800 223 9152
Headquarters phone: +1 248 305 8200
Contact:
proffighter 01-05-2023 03:32 AM
or:
23030 MAHLE Drive
Contact:
Thank you Ben
I contacted MAHLE in Germany (as I am from Switzerland, no local MAHLE here), but they did not answer... I will try this one now.
If anyone else has some info, you are welcomeSmileWavy
proffighter 01-19-2023 04:11 AM
Finally I get some answer from Mahle, short said (for Aftermarket):
-Only 2 groups of Cylinder diameter today, market on Cylinder: A and B
-No more height groups
-3 groups of Piston diameters: A, AB and C
-No more weight groups
-Aftermarktet only Pistons group AB delivered, they fit A and B cylinders
Conclusion: I have all cylinders A and all pistons AB -> Everything is fine :)
proffighter 01-19-2023 04:31 AM
Last week I started to mount the rods on the crankshaft. Remember (or did'nt I mentioned?) I bought some almost new Carrillo rods for a really reasonable price. The first three rods went without any problems as expected. But Number 4-6 (not cylinder numbers but bearing on crankshaft beginning at flywheel) did not wanted down to the seat, stuck before. After sorting out the possible issues (switch bearing shells, tried old ones etc.) it was clear: Inner diameter was out of spec (to little).
So I inspected the rods more detailed. I found that the surfaces on the 1-3 looks like cross-cut honing, but 4-6 just fine sanded. Seller told me about an engine failure after half an hour or so, but not exactly what happend. So It seems the shells turn and left some material on the rods. I went to an engine builder and he confirmed, looks like that issue, only was astonished the rod did not show any blue color.
However, he is optimistic he can solve this. Let's see...
proffighter 01-19-2023 04:37 AM
Iam still looking for an case stud kit ARP 504-9501
No one seems able to deliver, appointments are rescheduled almost every day. So if anyone here can help me to get them soon (means I received them, not what they announce on the webshop etc.) will gain 50USD via paypal as soon I have them. This offer is valid until the 30.01.2023
Thanks in advance
Roland
proffighter 01-19-2023 05:41 AM
Until I can proceed with the crankshaft I continued on the heads, valvetrain. There will be new bushes and shafts for rocker arms (worn).
Checked bolts etc. and found little axial play of ca. 1-2/10mm at the cups from valve adjustement screws. Is this normal or wear? Guess not but wonder if really worn or from new like this.
proffighter 01-21-2023 08:59 AM
Yesterday I got back my rods. Had to reworked, plane surfaces machined, rebored and honed. Now they fit nicely. Also they have been weight balanced (or how this is called in english, same weight adjusted at the rotating mass).
http://forums.pelicanparts.com/uploa...1674319874.JPG
Mounting by stretch method went easier than I thought.
proffighter 01-21-2023 09:07 AM
Another thing I tried is anodizing the intermediat shaft cover, just to see how good it come out. As it's an alloy with a high magnesium content it's not really possible to colorize and it get's darker through the anodizing process. I like the result and now I am thinking of making the chain house covers as well.
http://forums.pelicanparts.com/uploa...1674320601.JPG
proffighter 01-25-2023 04:15 AM
Miss the old times...
... it seems the days of lively discussions and exchanges are over. Well, that's the way it is.http://forums.pelicanparts.com/support/smileys/sad2.gif
That leaves more time for other things
LJ851 01-25-2023 05:10 AM
I don’t always comment but really enjoy this thread. I read all the posts, thank you for sharing.
I think the intermediate shaft cover color looks great. Have you been able to find an ARP case stud kit yet ?
-Lorin
proffighter 01-25-2023 06:28 AM
-Lorin
Hi Lorin
At least some are still aliveSmileWavy
Thanks, I like the look as well, hope I find time to go on with chain housing covers this weekend...
ARP? No, unfortunately not. Same thing everytime, e-shop says in stock, reply on mail says no... I cannot understand the problem at ARP, since almost a year they are really in trouble with availability, some shops say since over a year. I wonder as it's made in USA, not China. So what's the issue? No more steel in the US?
LJ851 01-25-2023 12:57 PM
The most common reply from USA manufacturers that I hear is “supply chain issues”
You would probably be fine if you wanted Small Block Chevy Main Studs.
A friend of mine ordered ARP wheel studs for the rear axle of his ‘68 Dodge Charger in August last year and they just showed up this week.
TurboKraft 01-25-2023 03:15 PM
Originally Posted by proffighter (Post 11905562)
Hi Lorin
They are saying another 3-4 weeks on through bolts.
Yes, 100% made in America.
Honestly, I'm just glad they are still making these parts for such a small, niche market.
proffighter 01-29-2023 11:56 PM
Hi Chris
Well, it may be true for trough bolts (even if I doubt you'll get them in time), but for the case bolt kit it's allover the shops and even ARP themself the fact that they move the date almost daily a couple of days forward and this happen since over half a year. If you can send me the item within 4 weeks I'll pay you another 100USD on top, but if you can't you give me a discount of 100USD :D
proffighter 02-02-2023 05:21 AM
Anyone any idea on this subject?
reclino 02-02-2023 07:42 AM
Play at the cups is normal, I lapped the end of each cup flat on my surface plate to remove any marks from previous wear.
proffighter 02-03-2023 12:23 PM
Today I started with workin on the piston pins, machined conical by 14° axial on the lathe to save some weight on the oscillating mass. Made this on the old pins as well without any issue. The weakest area is the piston there, not the pin.
http://forums.pelicanparts.com/uploa...1675455388.JPG
BTW What size of pics do you choose to upload here? With about 4Mb it's incredible slow...
reclino 02-03-2023 08:04 PM
So nice to have access to a lathe.
If I remember I crop pictures down to a couple meg. I am usually uploading from my phone and it's very slow. Almost as annoying as having few people respond to my posts.
proffighter 02-06-2023 12:55 PM
Hi David
yes, a lathe is a must when your doing much DIY in my eyes...
proffighter 02-06-2023 12:59 PM
Road & Race Inc.
Does anyone has expierence with them, page msroadrace in LA. Sent them a message with questions for a used 965 IC I found on there page and they sent me without any reply a Paypal request for about 15'000USD they have on ebay...??? Normal behavour or WTF?
Flieger 02-09-2023 10:57 PM
I've heard of them but not in a good way, however nothing concrete. Just odd stuff like that and high prices. I'd steer clear.
proffighter 02-12-2023 03:01 AM
Thank you. What I've found out as well.
MGB009 03-13-2023 04:36 PM
Super impressive work!
proffighter 03-14-2023 12:22 PM
Still waiting for ARP able to deliver... but in between I can do other things like:
I bought a 964 IC to replace my Blownsix IC (too big for my needs) and the intake air temp sensor from my SDS EFI does not fit. Id did not on the Blownsix where I fitted a threaded insert, but here I wanted to leave the IC as it is. So I made a sensor housing to "transplant" the sensor.
http://forums.pelicanparts.com/uploa...1678820983.JPG
LJ851 03-14-2023 01:55 PM
Great solution, well executed!
proffighter 03-14-2023 02:11 PM
Thank youSmileWavy
proffighter 03-14-2023 02:36 PM
Some additional info about the sensor above. Cylinder part is 0.1mm thicker than bore in the flange. Mounted with heath shrinking (Cold cylinder, hot flange). Anodized after. Sensor is also press fitted, but to be save as it's something like PA6GF I filled the groove with uv-activated glue. First time I used it, very cool stuff.
Another thing I am working is the fan housing cone (or what it's called). I guess it's not unusual that it have cracks or break completely.
Cut away generous
http://forums.pelicanparts.com/uploa...1678828993.JPG
Filled gap with fiber reinforced epoxy and drilled the hole circle
http://forums.pelicanparts.com/uploa...1678829513.JPG
proffighter 03-14-2023 02:46 PM
hmm pics lost...
http://forums.pelicanparts.com/uploa...1678829969.JPG
fourblades 03-14-2023 03:22 PM
You are doing really nice work! Your engine will be amazing when done.
I like the anodized pieces you did.
I have done a lot of zinc plating but not tried anodizing yet.
John
proffighter 03-15-2023 04:02 AM
John
Thank you!
...Then it's time to start:)
proffighter 03-19-2023 11:57 AM
Proceeded on the fan housing cone. Finish and painting done
http://forums.pelicanparts.com/uploa...1679251588.JPG
I made copies of the air guides out of fiberglas composite
http://forums.pelicanparts.com/uploa...1679251828.JPG
Weight saving of 126gr is quite nice:)
http://forums.pelicanparts.com/uploa...1679251977.JPG
and finally ready to mount
http://forums.pelicanparts.com/uploa...1679252185.JPG
