Considering you don't like yellow zinc , can't wait to see the color. Something to match the Blue I'm sure
![]() Kozmo |
Started to fit the wiring harness, what a mess. Luckily I record the colors, so I can sort it out:
![]() ![]() It starts to look like a car inside slowly but truly: ![]() ![]() Also I finished and routed the pumps, fuel lines and oil lines: ![]() ![]() ![]() ![]() I could also remount the rear lights:
Roland 930 Turbo '81 Too many modifications to list |
Looking good , with a little more time you may be driving this summer
![]() Kozmo |
Man that is some awesome progress, is it safe to assume that you roll the car out to work on it or do you do most of the work where it sits...cause it looks like such a tight fit...
Rey....77 930 "the Mistress" |
![]() But as soon the front flares are mounted and the doors are ready to add, I will for sure
Slantnose from HELL
Beautiful work!
It changes from time to time..... |
Nice, Nice, Nice
That wiring harness looks a little fat, surely there are a few extra wires you can remove?........LOL
1986 911 Turbo 3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts. |
Somebody hide his drill! LOL
On my way, nothing is save
![]() Present horn, was lighter than stock too: ![]() New one, smaller and I made an aluminum bracket and spacer plus used an aluminum nut as well. Result: Saved another 126gr: ![]() For those who want to know how small, that small: ![]() BTW I have no idea how it sounds, but at least it's street legal and over 100dB loud
Turbofrog
Maybe I should downgrade mine too. I only have one now but it sounds like an T ford and people just laugh when I press it at anger : )
Maybe I should install the ductail to go with it for total humiliation. Did you search for the weight or just grab one that felt light? What did you do with the rear lights, the heavy anchors?
************************************************** ******************************* 10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg Last edited by smurfbus; 06-03-2014 at 09:55 PM.. |
Roland, you are ruthless, fascinating to follow. However, I can help wondering, are stainless oil and fuel lines not much heavier than later style "composite" hose?
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk |
Banned
![]() PS: Roland, nice touch with the Barbie-sized horn - sweet as always!!!
I hope you are using improved aero dynamics to keep this paperweight from blowing around. Oh...have you though about a lightweight bra's requirement for female passengers? Or better yet...no bra's allowed
. Your cars are road taxed by weight right? Do you get a chance to reassess the weight once done?
Rear lights are plastic now, look my earlier post about here: Another rust combat
Fuel lines are a bit heavier than the PVC ones in the tunnel, but they are not useable with my aluminum fittings and were very old. However I did not have any fitting from pump to pump / return to tank, so this save a bit weight at least. Further all fuel lines are Teflon/SS, so I suggest they are lighter than stock rubber. Aluminum fittings allover help to save weight too. Oil lines are SS/Rubber because they are "smoother" to route in that size, but of course, Teflons would be lighter. Finally I never saw AN-12 PTFE fittings and hoses...
![]() My girlfriend actually never wears a bra, seriously! And NO I will not show ![]() She weights only about 50kg, what she always is woried not to pass. So she fits my concepts very well ![]() Switzerland is very federalistic, every canton is different, in my area it's displacement mainly. Well even there is no goal I will weight once finished. Problem is, it will take a few years until I am finished, as I have thousands of ideas what to do next...
Roland 930 Turbo '81 Too many modifications to list Last edited by proffighter; 06-04-2014 at 04:38 AM.. |
![]() Sorry, but it's Ken's horn
Banned
Pics? I'm sure that Paul would like to see evidence of yer errrr, "big wing"!!!
![]() Quote:
![]() I didn't know that Ken even had a "horn" - really do learn something new every day!!!!
![]() See post one, not new but still big in my eyes Roland, you are one VERY fortunate man (and a real a-hole for refusing to post pics)!!! ![]() Yes I know, luck with girl - misfortune with car (sometimes) Pics? In your dreams ![]() I didn't know that Ken even had a "horn" - really do learn something new every day!!!! ![]() Please show me Barbie's then...
Aaaaaarghhhhhhh
I test fitted the rear bumper today, BUT it won't fit anymore
![]() Too wide (or body too small) now, further bolting points are not matching the flares and they did before project. If I mounte the 5 ones below reflector as before, none of the bolts on the flare can be mounted, holes not flushing. If I place the bumber best fit, the holes in the middle won't fit ![]() ![]() ![]() ![]() I seriously have to talk to the body shop. Fit was way better before!
