LinkBack Thread Tools Rating: Thread Rating: 12 votes, 4.25 average.
Kozmo930's Avatar
Considering you don't like yellow zinc , can't wait to see the color. Something to match the Blue I'm sure
Kozmo
Old 05-21-2014, 07:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #401 (permalink)
proffighter's Avatar
Started to fit the wiring harness, what a mess. Luckily I record the colors, so I can sort it out:
It starts to look like a car inside slowly but truly:
Also I finished and routed the pumps, fuel lines and oil lines:
I could also remount the rear lights:
Roland
930 Turbo '81 Too many modifications to list
Old 05-24-2014, 04:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #402 (permalink)
Kozmo930's Avatar
Looking good , with a little more time you may be driving this summer
Kozmo
Old 05-24-2014, 06:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #403 (permalink)
speednme1's Avatar
Man that is some awesome progress, is it safe to assume that you roll the car out to work on it or do you do most of the work where it sits...cause it looks like such a tight fit...
Rey....77 930 "the Mistress"
Old 05-24-2014, 07:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #404 (permalink)
If have the possibility to roll out the car, but until now, I did not
But as soon the front flares are mounted and the doors are ready to add, I will for sure
Roland
Old 05-24-2014, 08:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #405 (permalink)
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
Beautiful work!
It changes from time to time.....
Old 05-24-2014, 09:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #406 (permalink)
Nice, Nice, Nice
That wiring harness looks a little fat, surely there are a few extra wires you can remove?........LOL
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 05-24-2014, 09:37 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #407 (permalink)
6771911esses's Avatar
Somebody hide his drill! LOL
Old 05-25-2014, 03:35 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #408 (permalink)
On my way, nothing is save
Present horn, was lighter than stock too:
New one, smaller and I made an aluminum bracket and spacer plus used an aluminum nut as well. Result: Saved another 126gr:
For those who want to know how small, that small:
BTW I have no idea how it sounds, but at least it's street legal and over 100dB loud
Roland
Old 06-03-2014, 02:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #409 (permalink)
Turbofrog
smurfbus's Avatar
Maybe I should downgrade mine too. I only have one now but it sounds like an T ford and people just laugh when I press it at anger : )
Maybe I should install the ductail to go with it for total humiliation.
Did you search for the weight or just grab one that felt light?
What did you do with the rear lights, the heavy anchors?
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 06-03-2014, 09:51 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #410 (permalink)
jsveb's Avatar
Roland, you are ruthless, fascinating to follow. However, I can help wondering, are stainless oil and fuel lines not much heavier than later style "composite" hose?
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 06-03-2014, 10:07 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #411 (permalink)
Banned
No need for the composite versions when Ruthless Roland has his trusty drilling rig at his disposal - just Swiss cheese those bit@hes!!! Ohhhh what, then he would have to put catch pans everywhere, and if he drilled those, then . . . .
PS: Roland, nice touch with the Barbie-sized horn - sweet as always!!!
Old 06-03-2014, 10:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #412 (permalink)
I hope you are using improved aero dynamics to keep this paperweight from blowing around. Oh...have you though about a lightweight bra's requirement for female passengers? Or better yet...no bra's allowed . Your cars are road taxed by weight right? Do you get a chance to reassess the weight once done?
Old 06-04-2014, 02:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #413 (permalink)
I searched for smaller diameter and checked when available weight. At same size they are mostly similar weights, so diameter is all you need to know. Steel bracket is also a factor, so I made one myself
Rear lights are plastic now, look my earlier post about here:
Another rust combat
Roland
Old 06-04-2014, 04:14 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #414 (permalink)
Jesper
Fuel lines are a bit heavier than the PVC ones in the tunnel, but they are not useable with my aluminum fittings and were very old. However I did not have any fitting from pump to pump / return to tank, so this save a bit weight at least. Further all fuel lines are Teflon/SS, so I suggest they are lighter than stock rubber. Aluminum fittings allover help to save weight too.
Oil lines are SS/Rubber because they are "smoother" to route in that size, but of course, Teflons would be lighter. Finally I never saw AN-12 PTFE fittings and hoses...
Roland
Old 06-04-2014, 04:24 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #415 (permalink)
Big wing I have
My girlfriend actually never wears a bra, seriously! And NO I will not show
She weights only about 50kg, what she always is woried not to pass. So she fits my concepts very well
Switzerland is very federalistic, every canton is different, in my area it's displacement mainly.
Well even there is no goal I will weight once finished. Problem is, it will take a few years until I am finished, as I have thousands of ideas what to do next...
Roland
Old 06-04-2014, 04:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #416 (permalink)
...and refill every 10km
Sorry, but it's Ken's horn
Roland
Old 06-04-2014, 04:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #417 (permalink)
Banned
Originally Posted by proffighter View Post
Big wing I have
Pics? I'm sure that Paul would like to see evidence of yer errrr, "big wing"!!!
Roland, you are one VERY fortunate man (and a real a-hole for refusing to post pics)!!!
I didn't know that Ken even had a "horn" - really do learn something new every day!!!!
Old 06-04-2014, 09:44 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #418 (permalink)
See post one, not new but still big in my eyes
Yes I know, luck with girl - misfortune with car (sometimes)
Pics? In your dreams
Please show me Barbie's then...
Roland
Old 06-04-2014, 10:42 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #419 (permalink)
Aaaaaarghhhhhhh
I test fitted the rear bumper today, BUT it won't fit anymore
Too wide (or body too small) now, further bolting points are not matching the flares and they did before project. If I mounte the 5 ones below reflector as before, none of the bolts on the flare can be mounted, holes not flushing. If I place the bumber best fit, the holes in the middle won't fit
I seriously have to talk to the body shop. Fit was way better before!
Roland
Old 06-04-2014, 10:51 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #420 (permalink)
