Turbofrog
smurfbus's Avatar
Is it possible to remove the intake manifold with the CIS on top of it?
I'd like to check the condition of the wires below the intake mani and it looks like it might be doable to remove it in one piece with the CIS. I remember a thread where this was discussed but I could not find it anymore.
So who has done it with the engine still in the car and any tips on how to do it?
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 11-28-2011, 03:28 AM
b930's Avatar
When I just did this, I had the motor dropped. I am doing a full top end and re-ring leaving the block in the car. I doubt you will have enough clearance to lift the entire inlet/CIS assembly over the long studs without dropping the motor at least a few inches.
1988 930: 3.5L 100mm LN slipins, LN FFA rods, Supertec studs, GT3582R with T4 1.07A/R twin scroll housing, RarlyL8 equal length divided headers, dual Tial MVS 38mm WG's, Carrera 3.2 heads with 993 big valves. 964 Cams, full bay IC, KEP st1 clutch. PE3 sequential ECU with 750cc EV14 injectors, CoP twin plugs, J&S Safegaurd, Aquamist HSF3 water inj. Wavetrac LSD.
Old 11-28-2011, 03:42 AM
I'm sure it's possible, but it would probably take more time and effort than it's worth. When I stripped down a motor for a top end and re-ring I removed the CIS first. It was just easiest.
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 11-28-2011, 05:31 AM
proffighter's Avatar
That's what I think too, lower a few cm's is a good idea
Roland
930 Turbo '81 Too many modifications to list
Old 11-28-2011, 07:03 AM
The CIS is mounted to the intake maifold with three 13mm nuts on these rubber buffered 8mm studs Pelican Parts - Product Information: 999-703-263-00-M260
They're probably 32 years old and kinda dried out by now and they're not easy to find if you find one with the rubber part seperated from the stud. Good idea to replace them while it's off.
They're good for mounting oil coolers and stuff like that too.
It's alot easier to remove the CIS before removing the intake manifold in or out of the car.
Old 11-28-2011, 09:18 AM
