I took a little different approach on mine, as I wanted to always be able to return the console back to stock if needed.
My gauge mount slides into the hole in the center, and out, if access to the wire harnesses is needed or other service. then it secures to the console using the two existing screw holes from the plastic stopper that was at the back of the hole in the console from the cassette holder. I used Koso, AFR and EGT gauges, along with an Andial Intercooler before and after cooler gauge. The dial is for the Andial fuel enrichment system. I laid it out in CAD and lasered out several prototypes and bent them up on the press brake until I was able to get the bracket somewhat perfected. If anyone is interested in going this route, I have a few spare brackets, or could laser and bend up some more, if there is interest. I had the bracket satin powdercoated, so it just blends in with the console. Keep in mind the Koso AFR gauge had to have the Main harness to the O2 extended, due to the length to the rear of the car.. I ve got a VDO boost gauge for the clock position. Hope this gives you some other ideas too. Ben '79, 930 ![]() ![]()
Nicely done!
Lincoln Phillip 87 930 Motec EFI M600 G50/50 TurboKrafted Hell Hound. Jeep, Chrysler, Dodge, Ram, SRT & AEV Dealer pm me for your Mopar needs. "the 930 is THE CAR that started my PORSCHE love affair..." Magnus Walker |
Crotchety Old Bastard
That looks really nice!
I've been in contact with a few gage manufacturers in hopes of having a custom gage made for the dash as that is a better place for critical readings. Haven't had much luck. Who do you guys use for custom VDO style gages?
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
North Hollywood Speedo gets my vote.
Brian, IMO before you cut out the "old alarm crap" be sure you can reconnect back the "key" wires the right way. I tried to remove my UNGO box, and guess what? Could not figured out how to crank the car w/o it... had to put it back in, and it is still there.
Brando
![]() ![]() I added the egt and boost control. Not sure the boost control is in a good spot but it looks o good I have to just leave it
Turbo powa! 1977 911s. it's cool |
Brando
Sorry about the crooked neck.
Banned
How were you able to hang the car from the ceiling?!
Brando
new updated pic of console
Preferred pronoun:Maestro
I didn't want to cut my console and didn't want the hang-it-under-the-dash look like we had in the "olden" days (70s), so I opted, like many others, to put the boost gauge where the clock was and decided on the passenger's foot well carpeted kick-panel for the AFR gauge. It's actually easier to view than if was obscured by the shift lever/knob and steering wheel, and making a hole in the kick-panel carpeting disappear is pretty easy compared with one in the console.
[IMG] [/IMG]
When in doubt, use overwhelming force. Last edited by nkowi; 03-31-2013 at 06:18 PM.. |
I'm just finishing up my boost/AF gauge install, I took an AEM failsafe gauge and stuffed it into an OE gauge (Will replace my clock). I'll do a complete write up on it once I actually have everything wired and ready to go but you can get an idea of another way to incorporate a proper boost and AF gauge.
Brando
cool
Great idea. Please post on this thread when you open a new one describing the gauge change. Thanks.
War Vet
Try Aimsports.com if you really want something readable for tuning. Nice product line.
Sent you PM. Interested about your Failsafe installation. |
ddelano
![]() Pretty sure I have the same AJR center console as the one in the photo above. See my PIC with a cardboard mock up of the change I am planning and second photo with as it is now. Planning clock up top and 52mm AFR gauge below that. Open to ideas / suggestions on how to make this ideal. I plan to to recover the center portion with black vinyl to match the OEM gauge cluster look (where the black cardboard is). :-)
The large face plate laying on the bench in the 1st picture is a refresh for an AJR console.
RGruppe #180 So many cars.. so little time!! |
ddelano
Do you do restorations of these? I'm having a new aluminum plate made at a local fabrication shop and am planning to cover it myself with 'Porsche' vinyl with my new cutouts. Is that 'proper' for an AJR installation? It will be just like the original... Can you post a pic of the AJR you worked on? Were these special wishes ordered only?
ddelano
| Tags |
| console , guages |
