About to readjust CO can i use a afr tool?
Hi guys getting mixed responses from my web search . I need to adjust my CC to 3%
Can i use a afr tool to do it using the conversion tables on the net?
Was told the numbers do not really correlate . Is this true?
Erick
Old 10-01-2012, 01:13 PM
Unusual inquiry having 374 posts in Pelican... lots of info in the turbo forum. Do a search here and you'll be amaze of the results.
Old 10-01-2012, 06:16 PM
9dreizig's Avatar
Send a message via AIM to 9dreizig
Miguel woke up on the wrong side of the bed today
but he's right do a search..
I do remember someone publishing a AFR to CO conversion chart ..
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 10-01-2012, 06:36 PM
mark houghton's Avatar
Adjusting to 3% is all fine and dandy, but if you're trying to pass an emissions test then that will be way too rich. It's not a "magic number", but rather dependent upon your car's build and general state of tune as to how well it will idle at 3%. Lacking any hard data (such as an emissions exhaust sniffer or an AFR gauge) then let your ear tell you how she's idling as you adjust the mixture screw.
I idle at about 13.8 to 14.0 which my car seems to like. Been a long time and many adjustments since I "sniffed" with my old Gunson Gas Tester, but I seem to remember something in the neighborhood of 2.0 to 2.5% CO works well for my car.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 10-01-2012, 06:43 PM
Old 10-01-2012, 06:44 PM
Crotchety Old Bastard
RarlyL8's Avatar
3%CO is a sweet spot for performance but can vary. Typically 13.5:AFR at idle is the same sweet spot.
Old 10-02-2012, 03:33 AM
totle's Avatar
Here is the table
Trond R.
1979 930: Garret GT35r turbo, EFI, carerra intake, Link EMS, custom GT2 cams, 98mm JE P/C, 964 crank (stroker), custom valves & ported (XtremeCylinderHeads) etc..etc..
1972 914-6 GT replica project
1986 944 Turbo
Old 10-02-2012, 10:25 AM
boosted 89's Avatar
Brian
Will setting your co level to 3% ish area affect WUR operation at higher boost levels. I only ask thinking that my WUR is in need of a rebuild because of the low AFR readings I'm getting at WOT(mid 9's). I'm not sure of the correlation between having the CO level set rich and the operation of the WUR under boost at WOT. I hope I don't sound like a dumba$$ but is the effect of setting the CO level high to have the car running a little richer under higher boost pressure? Would this be something you do even with an adjustable WUR?
Chris
Old 10-03-2012, 05:50 PM
