Bland
Can I change the turbo oil line without removing the intake?
It looks like changing the oil line is going to require removing the intake manifold... Is there any other way? Can I do this in the car?
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
I don't think it will come out from under the manifold. I could not even get mine out with a Carrera manifold. The braided flex line is what I now use. Philip
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
...i managed removing the stock hard line, but i rendered it useless in the process...it was faulty so i didn't care about bending it out...replaced with turbokraft braided unit...happy ever since...
Yes, there is way, but you have to go to a braided line with AN fittings. I recently did this in the fall with my 78. I had to manage the stock unit from beneath intake and simply fed the braided steel line back in. I preferred this over removing the entire upper intake. It took me about an hour to cut the braided SS line, fit the AN fittings, and R&I the oil feed line.
I believe Chris at Turbokraft offers a kit for this. I cobbled mine together, but I'm not sure off all the fittings part numbers. Here is the link for TK's kit. TurboKraft Inc : Turbocharger Oil Feed Line Set : 3K-Warner [930 CVS BWK TK] - $205.00 John
John- 78 Slick Top 930 "Illegitimi non carborundum" |
The stock oil supply pipe has a nice tidy routing but is a PITA to replace.
The do-it-with-the-engine-in-the-car-and-not-remove-the-intake-manifold method involves a good pair of compound cutters, like from Knipex. They short work of the stock oil supply pipe. Replace with our braided kit. Go back to driving.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Bland
Chris - email sent and called.
