T77911S's Avatar
oil between intake and blocks
since i was half way there i decided to pull the intake manifold off. good and bad form it, well maybe bad and bad.
there was oil between the intake and the top of the injector blocks. inside the intake itself looks dirty but not oily like the top of the blocks.
the other bad was inevitable. a little dirt dell down in 2 of the ports. thankfully i was able to vacuum it out.
one of the studs on the heads had a good bit of white corrosion on it.
4 of the injector blocks had a tiny crack in the inside at the bottom. not a a crack that would let air in since it was on the inside.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 07-16-2013, 03:23 PM
T77911S's Avatar
i guess i am going to add 6 blocks to my order.
the tops and bottoms were deformed from the gaskets. i would have sanded them flat, but no need now
RACE CAR:: sold
Old 07-16-2013, 05:41 PM
Crotchety Old Bastard
RarlyL8's Avatar
If any oil gets into the intake from burp over or the turbo it will end up seeping between the blocks. The intake air will continuously push/suck oil into the cylinders so eventually will look clean again.
The phenolic blocks crack with age and can manifest tiny vacuum leaks that are really hard to find. Good to change them out now.
Old 07-16-2013, 06:59 PM
Brando
quattrorunner's Avatar
Interesting info
Turbo powa!
1977 911s. it's cool
Old 07-16-2013, 08:33 PM
T77911S's Avatar
if oil can get in there, can that be a source of an air leak? the cracks were small and on the inside of the ports.
just ordered 12 new blocks.
is there a gasket between the throttle body and intake? i did not find one on pelican. i did not find one for the AFM to intake either. i would like to remove both for cleaning.
i have my wur and FD in a box to send. i need to take it back out and remove the banjo fittings. still deciding about sending the injectors. been spending too much money.
RACE CAR:: sold
Old 07-17-2013, 03:55 AM
RarlyL8's Avatar
Only 6 blocks are needed.
There is an O-ring between the TB and in the intake.
Old 07-17-2013, 04:00 AM
T77911S's Avatar
i ordered 6, dont know why i typed 12.
is the Oring the same as the one on top of the TB that goes to the IC?
RACE CAR:: sold
Old 07-17-2013, 06:47 AM
