newbie
Is this statement correct?
I have a stock CIS 930 and the AFR's on boost are high 10's and mid to late 14's on Cruise.
Would this statement be true for heat exchangers ( Not standard) causing fumes in the cabin? "On boost AFR should be 11.8 - 12.2 , 10s is way too rich, extra fuel burns in the header create extra heat. Extra heat makes the stainless steel weld bead weak and destroy the header." Is this the sign of poor welding and choice of material? or to be expected? Thanks |
Brando
False
newbie
This is what i am being told my the header supplier as to why a header has cracked.
Personally, i don't think this to be correct as normally a weld can be whole lot stronger than the base material being welded. It would be nice to have some good info to respond with. Thanks TIM |
Brando
Rich mixture makes the exhaust cooler. It also depends on timing but your fuel mix seems fine. A little rich but not going to hurt the welds unless the welds suck ad the material isn't made right or supported right.
Leaner mix makes really hot exhaust gasses. Glowing headers and even turbo hot side. Welds are not effected that much with 10/1 mix. That's safe still. Have you seen your headers glow it any other outward signs of heat? Last edited by quattrorunner; 09-06-2013 at 08:32 AM.. |
newbie
At night they glow but i put this down to the thin Stainless they are using.
Interesting, you are saying opposite to the supplier. Quite possibly poor material and substandard weld which could already have flaws in it. thanks for the feedback |
Brando
Who made them?
newbie
Going Super Fast ( GSF headers with Heat)
At the moment going super slow because i get poisoned |
Brando
I have the OBX which I have been told are made by the same company but can't confirm. Not with heat though. Mine have been in service for a year and are still holding up. But I had an OBX muffler and the welds and material didn't hold up. I had to reweld them in various spots three times. I'd chock it up to bad build quality. At least he should replace them with another set.
You get what you pay for. I had a set of those and then a set of schnell headers. both cracked after about a year. but i was driving the car every day and speed bumps in parking lots are very hard on headers. I didn't want to be spending several thousand dollars on something that was going to be bent up. Now that it's no longer a daily driver I'll be springing for something huge for the twin scroll turbo and efi i will be running.
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
newbie
Yep you definately get what you pay for, i just didn't expect the headers to leak internally. I still can't believe the fuel mixture is the cause, i think that is just a way of getting out of replacing them.
They ahave asked me to send them back and they will replace but by the time i have paid shipping and import duty its just not worth to have crap returned. I just don't like leaving it as if the reason for the failure is due to my car rather then them admitting a fault and just sending me another set. |
Crotchety Old Bastard
Exhaust system material requirements for turbo applications are much different than for normally aspirated. Standard 304 stainless is unacceptable for long term use in the turbo environment. Asian 304 has no quality standard so pot luck. Most manufacturers use 304 because it is cheap and they can afford to replace the sets that fall apart. Proper back purged welding is also mandatory for turbo applications. If not done slag will form that can break off and lunch your $2000 turbo.
The net is full of these examples as well as the properties of 321 stainless which is much more suited to the application. |
Brando
From what I understand, this is where you should look.
rarlyl8.com Also a cool setup is mode. MODE : Projects | Porsche and Motorsport Engineering B&B B&B Fabrication Parts And Accessories For Porsche Distributed By Patrick Motorsports
Turbo powa! 1977 911s. it's cool |
newbie
The B+B also appear to be 304 stainless.
Will have to do lots of saving to purchase a decent set of headers. Thanks for all the input. |
Preferred pronoun:Maestro
I ultimately bought a set of RarlyL8 headers. Clever and convenient design, super easy install, high-end materials and top-notch workmanship. More money? Yup, a lot more. And there's a reason for it. Best of luck on this.
When in doubt, use overwhelming force. Last edited by nkowi; 09-06-2013 at 02:24 PM.. Reason: typo |
I would suggest rarlyl8 eventhough I have not used them. My B&B had cracks at the Y collector. They did fix it under warranty and even redid the heater boxes, but the repair job didn't look that great. And there was a lot of down time.
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
Mode has oficially stopped making headers. Just got an e mail from them
looks like i got one of the last sets. wow i actually got lucky for once!!!!!
Any chance i could get you to e mail me a bunch of detailed pictures with some measurements of yours? Looks like i'll be making some.
I also like the little standoff bracket to the waste gate leg. Nice touch.
Ken 1986 930 2016 R1200RS |
Those Bob Holcomb headers are now collector items and just went up in value.
