Chain fence eating turbo
Just google turbocharger systems and there's a plethora of websites explaining. Our systems works like the majority of systems out there that you'll read about. Other part is CIS. There's tons of info right here. Lastly, buy Wayne's engine overhaul book (own) and Zimmerman's 101 projects (don't own but it's helped many here) and that should cover just about everything. |
Banned
As to your second question, when the boost threshold is lowered, the WUR simply gets the signal sooner, and will then enrich at that point (1000-1200 RPM lower in your example above). How much it enriches is dependent on full enrichment fuel control pressure (the higher pressure = less fuel reaching the mechanical injectors = leaner mixture . . . the control pressure works against the piston in the fuel head). There is a provision for this adjustment built into the Brian Leask modified WUR. I also want to mention that you really can't make any useful adjustments unless you have an AFR meter installed, as otherwise, it's pretty much just guess work and will be very frustrating. Oh, and the best way to accomplish adjustments is to get your hands on a Leask adjustable WUR and the instruction booklet that originally came with it. Obviously, that is difficult to do at the moment since he stopped making them, but hopefully Brian (RarlyL8) will get something going in that department (maybe?). You would probably benefit from even just getting a copy of the instruction booklet as it is full of good information that helps make the whole WUR business make sense. I have one, and I suppose I could make you a copy and mail it to you. I don't think that would be considered appropriate if he was still in business, but maybe it is now? A note about the K-Jet video - the air flow meter described in it is what you would find on a non-turbo 911 (says how arm rises as air is drawn through it) but the one on the turbo is the opposite - the arm/disc lower as air is drawn over it. Last edited by Ronnie's.930; 02-16-2014 at 10:29 PM.. |
Metal Guru
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
Thank you for the links and suggestions Ronnie.
Really sorry but Ive now forgotten what we were discussing ,
![]() Are you all friggin happy now??? I do get frustrated as Nuen mentions and thx to quattro for keeping it cool and others for keeping on track ![]() But for the rest of you im going to meet in a pub one day, spike your drinks when your not looking and post your silly dancing on you tube ! Geez i need a beer!
Wheels Last row 1977 3.0 930 260hp built, still reassembling Row 1998 996 MK1 3.4 296hp new daily driver Last edited by Robbbyg; 02-17-2014 at 04:18 PM.. |
why dont you go back to the park and feed the pigeons before you spew anymore crud here
Wheels Last row 1977 3.0 930 260hp built, still reassembling Row 1998 996 MK1 3.4 296hp new daily driver |
