Starter wire on front fusepanel
Anyone know which fuse and position up/down the Yellow Starter wire connects to?
I ask because ive run out of test fuses as ive blown them all ![]()
Wheels Last row 1977 3.0 930 260hp built, still reassembling Row 1998 996 MK1 3.4 296hp new daily driver |
i did not think the start wire was fused.
your question is a bit confusing. you asked which fuse is for the start wire but you keep blowing fuses.........
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
The yellow starter wire should go from the body plug behind the ignition switch/behind the brake booster directly to the starter. I don't believe it goes through the front fuse panel.
Certified User
This wiring diagram shows the starter wiring (in red and yellow). There is no fuse in the circuit between the battery and the starter.
If you want a clear PDF version of this, PM me your email address. ![]()
Bill 1988 Carrera - 3.6 engine with ITBs, COPs, MS3X 2024 Macan S Day job ... www.jesfab.com.au Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S |
Thread Tools | |
Rate This Thread | |
