Love it
Our '87 turbo cab had a G50/50 installed when I bought it 10 years ago. Works wonderful, I would highly suggest
Unfortunately I have a 5spd 930 trans in my 77 930. Not a big priority however I always wondered. Someday I will put it up on the hoist next to the stock 77 930 with a 4 spd and see what they did to make it fit as it is obviously a bit longer.
Anthony @ Voitureltd Bayside WI. |
Anthony,
I shouldn’t say it won’t work, but the amount of work needed for the early models is a bit more.
75 930, 76 930, 83 SC EFI turbo |
Ruf R30 5-speed
Photos of a Ruf R30 5-speed installed in a (former) Ruf conversion car in our workshop right now.
Yes, the bell housing is a short type like the 1976-77 Turbo 4-speed. When installed in a 1978-88 Turbo chassis, this shifts the transmission aft allowing the longer nose cone to clear. The axle angle is reduced and becomes more straight. The transmission mount is unchanged.
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
We've had the last several Ruf 5-speeds rebuilt. Some observations:
* gearing is remarkably similar to the 3.2 Carrera's G50 5-speed -- so very quick acceleration 1-2-3-4 * many parts are oddballs, with part numbers from 917s, 931s, etc. We have a parts catalog from Ruf and more than half the items has a handwritten "NML" next to it -- Nicht Mehr Lieferbar = No Longer Available * the release mechanism is a combination of factory 915 & 930 parts * the release cable is unique Ruf They're long out of production, and the cost of one makes a SBH G50 conversion look inexpensive.
![]() Ruf box below 79 long bell housing top. Recent upgraded Sachs pressure plate from Chris at TK. The clutch cable is unique other than that it fits like a glove, and I don’t mean one of those OJ Simpson “try-on” type of gloves either.
the911den.com Instagram / UberPorsche930 https://www.youtube.com/channel/UCg4ZbACRJsODXgnlMVZsjEg?view_as=subscriber |
I have a real rebuilt RUF BTR 5-speed box. shorter ratios.
but Im not parting with it for below 15k. |
Do all the 5 speeds have a shorter 1st gear? I find the stock 1st gear to be just fine for my engine. My Motec data shows a hair less than a second from onset of boost to redline in 1st. The gap to second is too big tho. The Albins gears at less than $1k each are tempting for a 2, 3, 4 change.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
I'm happy with the Andial 8:39 r&p and stock gearing in my '79. I find the 911 5 speed with the 8:31 in my bus with similar h.p. too short.
Harold '79 930/DP935 (sold) '68 VW 3.3 Turbo Crewcab |
Wevo did both transaxles. I think he calculated the top speed to be about the same, 140mph+.
MikeD '87 930 |
Brando
I really like 1-3 but the stock gap between 3-4 is big.
Turbo powa! 1977 911s. it's cool |
Yes...I changed 2nd & 3rd. 3rd gear is lower than stock. 2nd gear ratio is 1.444 and 3rd gear ratio is .928. Here's a snap shot of my gearing thrust (based on my rwhp dyno chart). The top is with stock gearing (note a big drop in thrust between 1st and 2nd) and the middle chart has lower 2nd & 3rd gearing (note less drop between 1st and 2nd) and the bottom chart is with previous short gearing (I loved it except for lack of gearing for highway cruising).
Stock gearing Re-geared 2nd & 3rd Short 2nd-4th gearing I'm surprised you like a big gap between 1-2...I suppose your engine is able to handle that gap.
MikeD '87 930 |
I've finally started my transmission project so of course I have to consult Pelican
![]() I was originally planning to change 2nd, 3rd and 4th to 1.444, .963, and .667 This would put my speed at 7,000 rpm in each gear at: 56, 88, 132, 190 vs stock of 56, 97, 142, 202 (of course the car won't go 202 or even 190) But now I'm leaning toward changing the R&P to 4.625 (8:37) and changing first gear to a 1.833 This would put speed at 7,000 rpm at 63, 89, 130, 185. So quite a bit taller 1st but right now I rev through 1st so fast that a bit taller should help and then a much tighter gap to 2nd so it should still be well into the boost after the 1-2 shift. RPM at 75 mph would increase from 2,590 to 2,835 but that seems bearable. Thoughts?
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) Last edited by David; 07-10-2025 at 07:08 AM.. |
Boost Freak
82 Porsche 930 Euro, black, 31K miles. Factory stock other than k27 turbo, B&B headers, GHL exhaust, Tial F40, 1 bar wastegate, MSD 6A ignition, 8" and 9" Fuch upgrade, H4 Xenon headlamps and a 930S steering wheel.
Hi Mike,
Thanks for all of the info. I am looking now at either a 1.444 (Albins) or 1.471 (Guard) 2nd and a .963 (Albins) 3rd. Just wondering how you picked the 1.444 2nd and .928 3rd and whether your are happy with them or have any regrets. Did you go with Guard, Albins, or other? Do you find the new gears any louder than OEM? Sorry if you've discussed elsewhere; I looked but couldn't find your comments on these items. Best, Josh Quote:
