-   -   My New 1979 930 - yes, another introduction... (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/820110-my-new-1979-930-yes-another-introduction.html)
gtc 11-07-2014 04:02 PM
Kenik, which rod bearings did you wind up using?
kenikh 11-07-2014 07:09 PM
Old stock Glycos. Got reeeeally lucky to find a solitary set.
heliolps2 11-08-2014 01:48 PM
great work, love the info
gtc 11-12-2014 04:58 PM
Any idea how old they were? I have a set that is a few years old, but who knows when the problems started...
kenikh 11-12-2014 06:34 PM
Old. Maybe 10 years old. Maybe more.
pu911 11-18-2014 08:41 PM
Kenik,
Great thread, what an awesome project. I'm going to put you to work sleuthing out paint details on my 77.
Phil
kenikh 12-04-2014 12:44 PM
Finally, time for an update!
Things have been plodding along for various reasons - mostly due to me being out of town for work and then vacation. The shop made as much progress as possible on motor assembly in my absence and the long block is finally together:
http://forums.pelicanparts.com/uploa...1417724223.jpg
http://forums.pelicanparts.com/uploa...1417724366.jpg
http://forums.pelicanparts.com/uploa...1417724383.jpg
http://forums.pelicanparts.com/uploa...1417724401.jpg
The ugly red pulley is going out for black anodizing this week.
The heat exchangers, as a reminder, are factory 3.2 Carrera units. This is important because the 3.2 Carrera design was identical to the SC and Euro/late 930 HEs with one important exception: They are 38mm in diameter! They bolt right up to the Euro/late 930 J-Pipe.
At $100 (thanks Pelican!), this turned out to be an affordable, good performing solution that allowed dwindling funds to be invested elsewhere. And yes, they are high heat coated to look puuurty.
With the long block ready, I've been the main blocker on further progress. I decided to save a few bucks by porting the manifold myself (I had a spare '86 manifold...the '79 manifold is going into a box). This led to some delays, given the aforementioned premium on my time.
Doing it myself proved penny-wise, pound-foolish. Ollie's would have done it for $100 extra, on top of the cost of porting my heads. As each hole took 30-45 minutes to port with a Dremel and high speed cutter...never again.
If you're curious how I did it or are a masochist and plan to do this yourself, here are some visuals.
The Fixtures:
http://forums.pelicanparts.com/uploa...1417724670.jpg
http://forums.pelicanparts.com/uploa...1417724815.jpg
The Set Up:
http://forums.pelicanparts.com/uploa...1417724842.jpg
http://forums.pelicanparts.com/uploa...1417724859.jpg
I scribed the cutter lines using a pick I bought from Harbor Freight:
http://forums.pelicanparts.com/uploa...1417724912.jpg
The final product @ 40mm:
http://forums.pelicanparts.com/uploa...1417725002.jpg
Now the final steps of assembly can begin, most importantly by fitting all of the sensors and building a harness for these sensors to interface with the ECU.
My mechanic and I are hopeful that this motor will finally inhale its first angry breaths sometime in January. Stay tuned.
krasuskyp 12-04-2014 04:29 PM
LOVE me the shot of the bare longblock from above w/ the shroud - pure sex IMO
great progress, keep pluggin away...
al lkosmal 12-04-2014 07:18 PM
bored
Kenik,
Recently i needed to port out some 911T MFI T'bodies to 38mm to match my 3.0 engine intakes. I ended up buying a BFD..............yes a big f**king drill. It seemed a bit like a klugey way to do it and I thought that I might end up destroying these old MFI bits, but i chocked the drill into my mill and bored those mothers out nicely with low drama and in no time...... a light cleanup afterwards....worked like a champ.
regards,
Al
http://forums.pelicanparts.com/uploa...1417749060.jpg
http://forums.pelicanparts.com/uploa...1417749340.jpg
kenikh 12-07-2014 09:42 PM
Al, your method works have been my first choice, but figured chocking up that manifold would have made me crazy without a mill's big table. I'll own a mill one day...
kenikh 12-30-2014 02:38 PM
Plodding along over the holidays - not much to report. But I did get ONE OF THESE: :)
http://forums.pelicanparts.com/uploa...1419979108.jpg
kenikh 02-19-2015 12:22 AM
Not much is an update, buy if anyone has a cheap BPV to offer up, I'm all ears. Here's mine:
http://forums.pelicanparts.com/uploa...1424334015.jpg
16Volt 02-19-2015 07:43 AM
My BPV has the same issue as do most of the used ones I have seen for sale. The threaded section is plug inside the cast material.
Pharris409 02-19-2015 02:53 PM
Where did you get your owners manual? I ordered one from dealership and they said it would be up to 6 months to reprint. See them on eBay for $600 to $1200.
kenikh 02-19-2015 03:09 PM
Got lucky - Ebay, a hundred bucks.
JacobS911 02-19-2015 06:17 PM
Enjoyed your thread.. great info!! Makes me look forward to taking delivery of my 79 930 turbo next week even more! :D
VZ935 02-19-2015 08:05 PM
Great project. FYI I built a very similar motor for one of my 930's and it was really a sweet package. I think you will enjoy it.
If that is Bernie B that is building your motor please tell him Van said hello. He used to work on one of my old 935's when Woody had it . ( I have it back now)
kenikh 02-19-2015 08:09 PM
^ Ha, I've sat in that car. I'll say hi tomorrow.
VZ935 02-19-2015 11:59 PM
Here is what that 935 looked like when we pulled it out of moth balls and took it to Daytona
http://img.photobucket.com/albums/v6...5/scan0001.jpg
Then we popped fresh bodywork out of our K3 molds and this is how it looked when you sat in it
http://img.photobucket.com/albums/v6...e/DSC00050.jpg
Really a solid great driving 935 but this is the money shot.. unloading at Daytona
http://img.photobucket.com/albums/v6.../intruckwt.jpg
Have fun with your 930 and thanks for saying hello to Bernie for me. He is a heck of a nice guy
kenikh 04-03-2015 10:41 AM
The saga has continued in fits and spurts. The motor build has been one that has been full of trials and tribulations, as these things usually go. And as with any non-stock build, has seen its share of unique challenges along the way.
While I may fill gaps in the timeline at a later date, I think it is far more satisfying to share a pic of the assembled motor, in all of its Zork-ey glory. Enjoy.
http://forums.pelicanparts.com/uploa...1428082832.jpg
al lkosmal 04-03-2015 11:19 AM
Nice Kenik....................you're getting me interested in building one of those motors.
regards,
al
kenikh 04-07-2015 12:18 PM
Things are really starting to come together. We almost have a runner! Just waiting for a few parts from Clewett and for the stock airbox to come back from the powder painter.
http://forums.pelicanparts.com/uploa...1428434274.jpg
http://forums.pelicanparts.com/uploa...1428434285.jpg
http://forums.pelicanparts.com/uploa...1428434295.jpg
http://forums.pelicanparts.com/uploa...1428434315.jpg
kenikh 04-24-2015 10:07 AM
Trans is coming together now, too. New LSD, new 1 and 2 synchros.
http://forums.pelicanparts.com/uploa...1429895202.jpg
http://forums.pelicanparts.com/uploa...1429895223.jpg
http://forums.pelicanparts.com/uploa...1429895242.jpg
kenikh 04-26-2015 04:19 PM
I just acquired a hard to find anti-performance part. I am indeed a truly schizophrenic 930 owner. :)
http://forums.pelicanparts.com/uploa...1430090354.jpg
IMR-Merlin 04-26-2015 04:21 PM
as long as you keep it exactly where it is, that is a perfect paperweight...
kenikh 04-26-2015 04:24 PM
It will go nicely with my Thermal Reactor logs...it certainly isn't in my immediate plans to put it on the car.
kenikh 06-18-2015 01:54 PM
Time keeps dragging on, and progress is slow and steady, as the pace of work fits the pace of my capacity for cash outflows.
We are almost ready to start talking about firing this bad boy up. The harness from the engine to the ECU and wiring are done, so the motor is ready and we are just waiting for a few items to come back from the platers. Can't wait.
Here are some current photos to whet appetites until then:
http://forums.pelicanparts.com/uploa...1434660674.jpg
http://forums.pelicanparts.com/uploa...1434660686.jpg
http://forums.pelicanparts.com/uploa...1434660694.jpg
http://forums.pelicanparts.com/uploa...1434660713.jpg
http://forums.pelicanparts.com/uploa...1434660724.jpg
http://forums.pelicanparts.com/uploa...1434660733.jpg
http://forums.pelicanparts.com/uploa...1434660743.jpg
http://forums.pelicanparts.com/uploa...1434660752.jpg
pu911 06-18-2015 08:29 PM
That is beautiful- I'm coming to Seattle for a ride-:D
Phil
kenikh 06-18-2015 08:31 PM
In September, perhaps? If you fly in, you're welcome to ride shotgun and maybe even take a spin or two.
Ronnie's.930 06-18-2015 10:00 PM
Looking sweet thar, Kenik (the engine, not you)! :D
Man, too funny about the "anti-performance" York - that truthful comment had me rolling!
Love the 934-like wastegate pipe - I run one like it, buttofcourse.
al lkosmal 06-18-2015 10:30 PM
Looking good Kenik.
regards,
al
boosted79 06-19-2015 07:21 AM
Looking good. Where did you end up on CR with those 8.5 JE's?
onboost 06-19-2015 07:49 AM
Is that Rarlyl8's wastegate dump pipe?
kenikh 06-19-2015 09:43 AM
CR ended up measuring out at 8.3:1, which is exactly what was expected after the material removed from twin plugging.
Yes, indeed. One thing I immediately noticed after installing it, is that the spacing between my Zork tube, a Fabspeed unit and the dump pipe is pretty wide. Because the Fabspeed is multi-part, it sticks out a bit further.
onboost 06-25-2015 10:55 AM
Yep.. I need to pick one of those up from Brian as well.. love the look!
kenikh 06-25-2015 10:57 AM
BTW, Zork and dump tube are both out for ceramic coating to satin black - details, details... :)
kenikh 06-25-2015 11:04 AM
Speaking of details, before heading out to the coater, we of course added the O2 sensor bung:
http://forums.pelicanparts.com/uploa...1435255405.jpg
We also trimmed the outlet of the dump tube to match the Zork:
http://forums.pelicanparts.com/uploa...1435255432.jpg
http://forums.pelicanparts.com/uploa...1435255464.jpg
onboost 06-25-2015 11:07 AM
Originally Posted by kenikh (Post 8683119)
Ahh yes, that does look proper.. and detailed! :)
kenikh 06-25-2015 11:13 AM
Here are some shots of the ECU, standalone PLX O2 module and harness getting fitted:
http://forums.pelicanparts.com/uploa...1435255741.jpg
http://forums.pelicanparts.com/uploa...1435255754.jpg
http://forums.pelicanparts.com/uploa...1435255781.jpg
http://forums.pelicanparts.com/uploa...1435255787.jpg
http://forums.pelicanparts.com/uploa...1435255797.jpg
Bye-Bye MSD sticker...
http://forums.pelicanparts.com/uploa...1435255880.jpg
kenikh 06-25-2015 12:21 PM
Another detail...the wiring harness will terminate into the engine bay using a few of these nifty Molex automotive quick disconnects:
http://forums.pelicanparts.com/uploa...1435256187.jpg
http://forums.pelicanparts.com/uploa...1435256201.jpg
