Dupont color for jaguar 1992-2000
code: SDL
Name:Rose Bronze Effect,
recept number H9831
Old 09-26-2014, 10:56 AM
Some porting for the heads. I donīt want make them bigger, just smooth.
This almost the strarting point.
This have better shape, but itīs not ready.
Old 09-28-2014, 09:18 AM
MikeD930's Avatar
It's good to see a 930 being rescued. I like the unique color of your car.
Good job cleaning up the ports!
MikeD '87 930
Old 09-28-2014, 02:46 PM
For E85 fuel and EFi I choose these Bosch Ev14 injectors. Type is 0280158040 , and flow is 980 cm3 / min( 3bar)
http://www.bosch-motorsport.de/media/catalog_resources/Injection_Valve_EV_14_Datasheet_51_en_2775993867pd f.pdf
Injector injecting head is in quite same position in this 3.2 manifold as it is with CIS system.
Fuel supply end of the injector is far away from orginal position. Anyway i need another fuel rails that canīt corrode so easily.
Old 10-02-2014, 03:21 AM
"New" fuel rails are made of Saab Biopower (2 pcs) stainelss steel fuelrails. Some cutting and TIG welding needed. Fuel regulators are integrated to fuelrail.
BMW TPS sensor and VW MAP sensor
Old 10-07-2014, 04:30 AM
Great project and it looks as though you are really attacking it. I must admit, I am envious of you, how do you find the time for such a project?
Keep up the good work, soon you will be rocking the highways and have done it with your hands/skills.
Old 10-08-2014, 03:17 AM
I let paint Car paint service make whole basework and painting. it was like 80 hours...
i am not updateing this in real time, So it seems to be faster than it is.
Soda blaster is not me. Main engine (long block) assmebly is done by professional. So i make EFi system and others and try to use already trusted solutions. This forum have been useful. Exhaust system is 993 headres+ custom connection + 2 pcs of "smart gates".
Igntion sytem layout (bosch controls(from Volvo) +034 motorsport coils)
Clewett wheel and my friend made a machined pulse wheel for the crank speed sensor.
Old 10-08-2014, 04:13 AM
oil tank cleaning+painting+new sensor seal.
Old 10-10-2014, 04:23 AM
Engine looks so nice. Chain housings were also machined to match lowered Heads.
993 headbolts were used and Pump drive added to SC cams. New sump cover was need, due the 964 oil pump.
Old 10-15-2014, 03:52 AM
993 headers used for this. One side flanges needed to rotate. Turbo should be on original place. Turbo is custom made HX35/40. Two pcs, of Turbosmart wastegates to keep optimum turbo spooling. Weldings are made by me, as you can see.
Old 10-27-2014, 12:08 PM
test fitting.
Old 11-02-2014, 10:41 AM
Brando
quattrorunner's Avatar
Nicely done
Old 11-02-2014, 10:52 AM
IMR-Merlin's Avatar
Nice work...
Subscribed.
Old 11-02-2014, 11:04 AM
Makeing of intercooler. I also put 993 air filter housing. It fits to 3.2 intake manifold.
Test fitting of a New oil separation system for breather.
Old 11-24-2014, 09:48 AM
Awesome work, what is original paint code. I was thinking the 3.0 turbo's and Carrera used a 9bolt crank and 2.7 crank was a 6 bolt, can these be swapped.
Phil
Old 11-24-2014, 06:30 PM
onboost's Avatar
Phil
3.0 turbo's use the same 6 bolt crank as the 2.7.. it gets it 3.0 displacement with larger cylinders. 3.3 turbo's & 84 and up Carrera use the same 9 bolt crank.
RGruppe #180
Old 11-24-2014, 07:04 PM
