Trans sensor ID help
Unfortunately the wires for this got hooked up on the axel of the way out and it was too late when I noticed.
I can't find any info on it or find it for sale anywhere. What is it for? Interesting thing is that the wires appear to not even have been connected anyway. I can easily solder the wire back into the connected but I don't know which wire connects to which side of the connector. Car in questions is an 85 930 Will post pic shortly. Sent from my iPhone using Tapatalk |
thats your reverse light switch. get a new one solder a new female end on and your done.polarity doesnt matter
Thank you very much!
Hah, we have identically broken switches.
- 86 Porsche 930 - Mr.Hyde - 86 BMW 635CSi - Dr.Jeykell - 2006 Infiniti M45 Sport https://medium.com/@crashingdoor |
I'm just going to try and solder it and hope for the best. I dont think the wires were even connected before. There looks like there was supposed to be a connector there and its def not on the floor under the car.
83 911 Production Cab #10
Unless someone tell you you back up light does not work, you would not know it.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
^^^ or, if you try to back up in the dark...
How often do you guys check into things like that - walk around the car... (i.e. headlights, turn signals, backup light, horn, tire pressure, look under the car before a spirited ride being sure there is nothing hanging down...)? |
I check normal things frequently.
But I honestly dont care at all about the reverse lights so I have never taken the time to check. |
