Chain fence eating turbo
Dyno gurus, I have a question....VIDEO
So, I finally got to the dyno today, but it didn't work out.
From 4K to over 6K, the graph did not plot at all.
Question is, does ignition "flame-out" cause the Dynojet to not read out?
I've had a flame-out issue or ignition cutout since I went to 1.4 bar of boost probably linked to my 20+ year old coil pack.
This system only plots hp, so it makes sense that missing RPM from cutout would prevent the correct calculations for hp as the computer has nothing to work from.
Vid showing 1 of 3 runs.......all with similar readings missing and erratic readings.
3.4L BW S366 @ 20PSI - YouTube
Anyone experience this? Couldn't find anything on the web.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 11-09-2014, 04:40 PM
Evan Fullerton's Avatar
On any of the DynoJets I have used, loss of RPM signal would default to a torque vs. road speed graph. I would guess that they could be configured to do other things under those circumstance though. If you hunt around enough in the software, your torque vs. road speed data should be stored in there somewhere and you can interpolate it to RPM if you so desire.
Old 11-09-2014, 04:57 PM
Hello Evan, these guys just give you a printout. No real time to dig in as these guys go to our local cars and coffee and had many people waiting in line.
Hmmm, too bad it wasn't at a shop to try to figure out another method to generate the correct numbers.
Old 11-09-2014, 05:41 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
What's going on with that semi surge before full boost? Are your AFR's linear on boost? Your running wasted spark? Plug gap? This only started happening when running 20psi?
It changes from time to time.....
Old 11-09-2014, 05:52 PM
You know, I've wondered the same. I always wondered if it's the MAP getting maxed out. It's been awhile since I logged, but I believe the AFR's go richer fairly linear.
Wasted spark with Ford EDIS ignition.
Plug gap is 0.025".
And yes, once it ran a Holset HX40, I kicked up boost from 1 to 1.4. It happened (hard hitting surge) around this time IIRC.
Old 11-09-2014, 06:05 PM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
What are you running for fuel? And what size injectors? And what is it reading for AFR at 20? Did you ever load that timing map I sent you?
Old 11-09-2014, 07:02 PM
In order of questions:
93 octane, 80lb Dekas, 11.7 AFR, no I did not. Let me revisit.
Old 11-10-2014, 05:00 AM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
Try fattening it at 20 just a tad.
Old 11-10-2014, 05:21 AM
Low 11's?
Old 11-10-2014, 05:51 AM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
Just a tad 11.5, no need to flood her...
Old 11-10-2014, 05:53 AM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
Does it behave the same at 18psi or is it just 20?
Old 11-10-2014, 05:54 AM
LOL, ok
Old 11-10-2014, 06:05 AM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
I had a flame-out problem a while back it end up being the plugs were too cold (BKR9EIX I like these as they have 5/8 hex instead of 13/16). I had this happen running NGK iridium's but went back to Bosch Silvers. I think if I would have dropped the range to 8's in NGK it would have netted me the same results which is what I'll try next set BKR8EIX stk#2668
I believe it does not. Seemed to be pretty smooth at 15-17 with the 1 bar WG springs.
Old 11-10-2014, 06:06 AM
I can't remember if I'm running NGK or Bosch right now.
What do you recommend from NGK? I'm not a fan of the Bosch tax....
Old 11-10-2014, 06:07 AM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
What plug (stock number) are you running now? Your single plug?
Old 11-10-2014, 07:08 AM
Single plug. I believe I went one range colder over what the Pelicanites recommended for a stock Carrera 3.2.
Old 11-10-2014, 07:29 AM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
SKU: #BPR7EIX ITEM : # NGK4055 This is 1 range colder than stock. Typically 1 range for every 100 HP over stock. You could run 8's. 8's are equivalent to Bosch 3's
Old 11-10-2014, 07:47 AM
8's, I believe I'm running.
Old 11-10-2014, 08:42 AM
GJF GJF is offline
Slantnose from HELL
GJF's Avatar
BKR8EIX stk#2668 is the info for 8's. good for 200+ over stock. 9's are just too cold for even over 1100HP on toasty Florida days. I think even Goran had issues with 9's over on his side of the world. It is much cooler there. Either a crotch rocket shop typically stocks these but at a premium. Or buy off eBay for a song & dance.
Old 11-10-2014, 09:43 AM
