How low is too low?
Working on a new setup with all new suspension components. The shop is having trouble. Thinking about the weltmeister sway/away or elephant or any other of our esteemed established proven performers.
63 356 So Called Outlaw
76 930
Old 09-02-2014, 07:09 PM
Preferred pronoun:Maestro
Norm K's Avatar
IMHO, ^^^ that ^^^ is too low.
When in doubt, use overwhelming force.
Old 09-02-2014, 07:21 PM
Non User
infraredcalvin's Avatar
Ohhhh like the new wheels, much better than the old ones (twists?). As for low, can't quite see the rake (or lack thereof). I like a level stance, rear is a bit low for me, up it a 1/2 in and go level with the front and it'll be a nice mean stance...
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
‘71 914-6 GT 3.4L twin plug track car
'75 914 GT clone project
'71 914 track car, fresh 2165 FAT motor (for sale soon)
Old 09-02-2014, 07:37 PM
Here is how it was setup for the last 18 years. 25.25 ground to rear fender lip. The shop had it sitting at 24 inches. Misunderstanding. My question is what adjustable rear suspension is the most cost effective for a non tracked car?
76 930
Old 09-02-2014, 07:38 PM
jsveb's Avatar
I would raise the rear about half and inch maybe a bit more, and lower the front correspondingly.
Car looks great!
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 09-02-2014, 07:39 PM
beancounter
jwasbury's Avatar
This is too low
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 09-02-2014, 07:53 PM
Somewhere in between...
Old 09-02-2014, 08:09 PM
930T Owner
Hams930T's Avatar
Sorry - no direct reports I can give regarding the best adjustable spring plate. I went straight to full coilovers. I just wanted to note that you car looks really nice with the 17" Fuchs.
Chris.
Hams930T
2017 Turbo S
Old 09-02-2014, 08:31 PM
What wheels and tires are you running? Typical height is about 25" ground to fender lip front and 24.5" ground to fender lip rear. from there you set the rake depending on personal preference.
Rahl
Old 09-02-2014, 09:01 PM
gumba's Avatar
The least expensive are the factory adjustable spring plates, about 1" of adjustment. Next would be aftermarket adjustable plates.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 09-02-2014, 09:59 PM
3 restos WIP = psycho
kenikh's Avatar
I'd raise the rear .5" and leave the rest be. I think the wheels look best when the top of the tire sits plumb and flush with the fender lip.
Sahara Diamond Metallic? Could you share the paint code from the door still, please? World help me and my paint research a lot.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 09-02-2014, 10:35 PM
Groovie Ghoulie's Avatar
I run the rears right down on the top lip of the tire. no rubs, but I have an ER adjustable spring plate, polybronze, and big T-bars with Von shocks, so it is much stiffer than stock. you cannot get a finger in my wheel gap. I love it. any lower and the alignment shop will need a lot of camber to get the toe in spec. and it will rub. Mine did before. Brought it up 1/2 an inch and it was good to go.
Old 09-03-2014, 12:52 AM
speednme1's Avatar
At first when I saw mine after my suspension was complete, I thought is was too low but man was I wrong..she rides very well. Handles like on rails and absorbs the bumps with no issues.
suspension consist of
TRG coilovers..450lb Front and 500lb Rear springs
Smart racing bars
Rebel Racing 935 spring plates
Rebel racing rear bearings
Elephant Racing GT3 front suspension system
Elephant Racing Bump Steer Kit
Rey....77 930 "the Mistress"
Old 09-03-2014, 01:48 AM
For me this was too low..needed a 2x4 under the rear wheel to remove the floor jack.
adjusted and spot on:
Old 09-03-2014, 04:24 AM
Does the sway away adjustable work for the 76? It says it does but I've run in to other things like transmission mounts that are said to work and don't. Also since I am not tracking this car what size of rear torsion bar is better than stock?
76 930
Old 09-03-2014, 05:36 AM
crb07's Avatar
Bump steer kit for sure.
Chris
89 930, 87 930, 86 930 Ruf BTR tribute, 89 Ruf CTR tribute
Old 09-03-2014, 05:52 AM
onboost's Avatar
Yes, they will work for your car..
RGruppe #180
Old 09-03-2014, 06:37 AM
16Volt's Avatar
The only thing really wrong with your first pic is the reverse rake, I would come up a bit in the rear. Space out the fronts about 3mm..
Ride height is very subjective to ones tastes and what you want the car to do. I like it low with tops of tires very slightly tucked or level with the curve of the fender. As with anything there are sacrifices but with right amount of money applied in the right areas you can get pretty much any setup to "work".
Where the heck is FullQuack...King of Low?
- 86 Porsche 930 - Mr.Hyde
- 86 BMW 635CSi - Dr.Jeykell
- 2006 Infiniti M45 Sport
https://medium.com/@crashingdoor
Old 09-03-2014, 07:11 AM
Chain fence eating turbo
Is this a 4X4 forum or a sportscar forum?
I like them low with the rear tires gently tucked under the wheel well.
If you're not tracking, go low as you like IMO.
Old 09-03-2014, 07:25 AM
Smart racing bars
PORfect!
Old 09-03-2014, 07:27 AM
