front oil cooler deflector pan.
after some discussion with the supplier will bond in place and then add some sheet metal screws rather than weld.
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold
past the point of no return on this.
did the rough cut and now to do the finial trimming/fitting. talking to the supplier he said I needed to either cut out some of the battery tray or trim the panel. did not want to cut the battery tray so will trim the panel. also got the rear sway bar mounts cut off.
think I have the deflector pan trimmed to fit. will take another look and finish the fit. chose to not cut out part of the battery tray, so trimmed around it.
will initially just use a few sheet metal screws to hold it in place, then need to do the rest of the trimming of the tub opening to match. talked to the guy who will be doing some of the welding for me, this included. may be taking the tub to him soon, then off to the paint shop. my cousin was only hear for a week, did not have much time, and I could not borrow a tig.
got the front opening done. rather than cut back the front more, thinking of cutting metal plates to have welded over the end areas to close in those irregular areas. especially since I did not cut out the battery tray.
next, start working on the plates for the bolt in cage.
guy picked up the oil pan to weld the baffle and tube support bracket.
boxed up some more lines to ship to Len for rebuild/plating and Shaun for plating.... back to cleaning/grinding areas to be welded. guy will bring his kit to my shop, just a block down the street from him.
started fitting the cage. need to drill out holes for the captured nuts to fit down into the frame when the plates are welded in. and continued work on preping the areas where stuff will get welded.
got most of the holes cut to accommodate the captured nut on the plates.
weld plate to frame, bolt cage to plate.
not long ago I connected with another guy in the middle of a build. after a few discussions and looking at his thread I have become very interested in doing an LS3 or maybe an LS7 conversion.
so let the flaming and fireworks begin..... not unfamiliar with these conversions but had not originally though of doing this. maybe when I realized the engine needed a total rebuild.... so not researching info and am being drawn to the LS conversion...
Would be neat to investigate a Cayenne turbo swap... Still "naughty" but pretty unique and "keeping it in the family"
Of course I have ZERO idea if the swap can work, dimensionally.
Garen GNdesignLLC.com - Automotive Art & Sculpture |
I say, both of you need to put down the pipe.
I’m far from a purist but, I’d take a 3.3 T motor over either of those motors any day all day. Besides, don’t you already have the 3.3 with all the machine work done ?
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
I have the 3.3 motor and some stuff at a shop. not sure if the shop ever got to work on my parts. I just got an email from the shop yesterday saying they would call me first of the week. we'll see.
so, I am still facing a complete build of the engine, along with having a lot of other stuff rebuild such as the CIS fuel head, CIS AFM, turbo, etc. To be candid I am a little intimidated by the 3.3. not just to put it all back together properly, but then the 'black art' of CIS tuning is there. I do have local resources expert in this... from all I hear/read you install the LS3, and change oil each year. very low maintenance. have your ever driven/ridden in a LS conversion 911? I have ridden in one and the charater of the engines are completely different. 3.3 you wait of the boost and then manage the rush of power. the LS engine is very linear and has the low end torque the 3.3 does not. still a 911 but with a different feel/sound to the engine. from limited research I could get a new crate LS3 that would produce 400+ hp out of the box. and if I want to spend a little more the LS7/427 is over 500hp. I have been told getting to 400 with my 3.3 and CIS is probably the goal, and going to more HP usually requires going to EFI. and understand this car was not originally a 930, but a SC converted in 1989. so I am not destroying an original 930 but trying to make the car I want. but even if they have done some work on the engine parts, I could eventually build it or sell all the parts as a 'kit'. now to pick that pipe back up....
forgot to update the work.
while working on fitting the cage, had an epiphany. cut a piece of plywood in the shape/curve of the sunroof panel template. will screw this to a 2x2 and use to support the sunroof for welding. but still need to put in place and see if it will make it easier to get the roof flow restored.
got all the hole drilled for the cage plates. need to have the captured nuts spot welded.
took the wood template and screwed it to the end of a 2x2. with a little tweeking I think this will do a lot to getting the panel in correctly. had a long discussion with Steve Weiner yesterday. he has driven several LS 911s and a LS cayman. they were well built and sorted and incredible to drive. since my car is already a frankenstein modified, why not do LS. so here I go..... I'll be selling the complete 3.3 as a 'kit'? anyone interested?
Under the radar
You may want to read through a couple of threads where people have done this. It could add several years and $$$ to your project. http://forums.pelicanparts.com/porsche-911-technical-forum/461502-my-ls1-conversion-911-a.html 89 911 LS1 Conversion
I have made my decision, and think it is a good one for ME.
actually I can imagine spending a lot of $$$ finishing the engine and the time it would take me to do that. and being my first 911 engine rebuild what is the risk of my messing up and it gernading on me..... was talking to one of the guys in the shop across the street. he was telling me how he totally rebuilt the 454 in his truck. when they fired it up it immediately spun a rod bearing and blew it through the side of the block... ![]() I have all the parts for the engine, dismantled it myself. and have already had a bit of work done as shown in this thread. will be posting for sale and will start going through everything to inventory, take pics, and box up. I'll take a look at those threads for ideas and probably what not to do.
thanks again for those links. interesting builds.
talked to Steve Wiener and his estimate is about $10k for all the work and parts I would need to build the 3.3. then again the question of risk. so I would avoid those costs and add back whatever I get for the engine. so the LS swap may cost less in the long term. regarding time, I think this will actually reduce the time to complete. researching the cooling issue. I do not want to take the normal Renegade approach for radiator in the front. requesting dimensions of some 934 style front valances. stick 3 radiators behind it with fans should not be too hard to fab and should cool enough. and if not add another small radiator in the back under the tail.... but today get to work on the 951, picked up the rebuild cyl head yesterday. so much time so little to do.... stop, reverse that...
Even though I egged you on to get the Cayenne motor... I'm a flat-6 guy. But it's your car. End of story. And the Smithsonian ain't calling anytime soon since it's not the last-in-the-world, pristine, original, never-touched turbo.
But gotta say. They're cooler with the boxer in the bag as Ferry intended. 934 valance is straight up awesome.
I understand as I had an 85 911 for 27 yrs. and my original plan was to rebuild the 3.3
but after working on this in the 'background' for over 5 yrs I really want to get it done. and all things considered I am getting energized again about this project with the LS3 now in the plan. I almost have a modified 951 turbo motor rebuilt, looking forward to bringing the 951 out of the trailer and into the shop to get it back in. unfortunately I expect to miss the first of the DE events, they are filling up and after getting the engine back in will need to drive for a while to break it in. just got the cyl head back from the machine shop.
I hear ya... My own subtle project is creeping up on 6 years. With decent time to spend on it, would've been a 1 year job, max. But, crazy cool work project + life & family + job change and another really cool work project, and we're 6 years deep. Really starting to effect my mood!!!
Nice cylinder head why the way.
got the captive nuts welded to the plates for the cage. but now that I have all the parts will focus on finishing the engine rebuild for my 951 and get the car back on the road to go through engine break-in before I head to a track event.
