klefroid's Avatar
Are we using the wrong spark plugs?
I think I just bought the wrong spark plugs?
https://www.youtube.com/watch?v=dgFVN9iMnLg
Old 08-17-2015, 10:57 AM
Yes sir
1986 944 turbo -first car
1997 993 Cab 6 speed-sold
1992 964 C2 turbo
SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo
Old 08-17-2015, 06:53 PM
930T Owner
Hams930T's Avatar
Thanks for sharing. I will freely admit I have typically run Denso Iridium plugs in my cars. Clearly I need to rethink that approach.
Hams930T
2017 Turbo S
Old 08-17-2015, 07:08 PM
Turbofrog
smurfbus's Avatar
Switch/ E85, done.. I hate changing sparkplugs so I will stick to platiniums for durability. But if problems arise need to rethink this.
10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg
Old 08-17-2015, 09:57 PM
T77911S's Avatar
platinums dont always work best. i went from a bosch platinum to a cheap copper in my truck. it not only ran better but gas mileage went up alomst 5mpg.
use either copper or the bosch CS (silver).
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 08-18-2015, 05:37 AM
Ingenieur
Seriously!? You are going to switch the plugs in your $100K cars based on YouTube dude?
LMAO
Old 08-18-2015, 06:47 AM
3 restos WIP = psycho
kenikh's Avatar
The thermal conductivity part is true.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-18-2015, 07:56 AM
Chain fence eating turbo
I did a science experiment in middle school on spark plugs.
What I found is Bosch Platinums gave off a much weaker spark than good old copper Autolites. I did other plug types in between. I did this by using my lawnmower and a rig to hold the gaps for the spark to jump. I simply moved each plug further away until no spark.
I know it was not totally controlled variable wise since me pulling the rope could have changed the magnetos strength, but I did it several times as an average.
It was a drastic difference.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 08-18-2015, 07:59 AM
LMAO
They are tuners by trade......not exactly a rookie IMO.
Old 08-18-2015, 08:00 AM
Das Schnell Ei's Avatar
Has this not been known for a while?
boosted/ nitrous should use normal plugs
'77 911S Coupe 3.2 Turbo
'76 911S Coupe 3.0 964 cams...no sunroof
'75 911S Cabbie 3.2 SS Web cams & 46mm Webers
'73 914 1.7 Webers & Header ... sold
'74 VW 1303S 1600cc DP Web 110 & Solex
Old 08-18-2015, 08:01 AM
Ingenieur
Uh, no.
Old 08-18-2015, 09:09 AM
Uh, no.
So we should be using Iridium and Platinum?
Old 08-18-2015, 10:42 AM
jsveb's Avatar
Aren't the recommended W3DPO's platin?
Jesper
Carrera 3.0 1975
930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer
www.stauningwhisky.dk
Old 08-18-2015, 11:05 AM
kenikh's Avatar
My mechanic buddy uses NGK BR9IX - iridium - plugs in 930s. Waiting great back if he's noticed anything, at least in hindsight, in regard to different plug types.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-18-2015, 12:28 PM
You need Splitfire's or E3's, a quart of Slick 50, and a cool collar, then you're good to go!...............
On a more serious note, here's a good read:
http://www.ngksparkplugs.com/docs/tech/Racing_Spark_Plugs_Performance_Applications.pdf
1986 911 Turbo
3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts.
Old 08-18-2015, 12:38 PM
kenikh's Avatar
Slick 50! It's Teflonated!
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 08-18-2015, 12:39 PM
You betcha!
And if it's Teflon, it's got to be good for anything!..........
1986 911 Turbo
Old 08-18-2015, 12:42 PM
speednme1's Avatar
Interesting...back around 98 when I had my 3.2 I switched to platinum plugs. Car ran like crap. My mechanic at that time had me switch back to copper. Car ran great plus the copper ones were a lot cheaper.
Rey....77 930 "the Mistress"
Old 08-18-2015, 12:56 PM
HAHA, what was that stuff that they took the oil pan off the car and sprayed water on the crank as the engine ran?
That'd top it off!
Old 08-18-2015, 03:50 PM
Wonder how much of that had to do with not being resistor plugs? For sure the spark would be weaker.
Old 08-18-2015, 03:51 PM
