Are we using the wrong spark plugs?
Yes sir
1986 944 turbo -first car 1997 993 Cab 6 speed-sold 1992 964 C2 turbo SOLD, 911GT ,CIS, 428 fwhp 450 trq, Carrillo rods, 964 cams, TT retainers,7.5 comp 1.1 bar boost 320 ml black fuel head 009 injectors, 044 pumps, 60-1 T4/T3 dual scroll turbo |
930T Owner
Thanks for sharing. I will freely admit I have typically run Denso Iridium plugs in my cars. Clearly I need to rethink that approach.
Hams930T 2017 Turbo S |
Turbofrog
Switch/ E85, done.. I hate changing sparkplugs so I will stick to platiniums for durability. But if problems arise need to rethink this.
************************************************** ******************************* 10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg |
platinums dont always work best. i went from a bosch platinum to a cheap copper in my truck. it not only ran better but gas mileage went up alomst 5mpg.
use either copper or the bosch CS (silver).
Ingenieur
Seriously!? You are going to switch the plugs in your $100K cars based on YouTube dude?
LMAO |
3 restos WIP = psycho
The thermal conductivity part is true.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Chain fence eating turbo
I did a science experiment in middle school on spark plugs.
What I found is Bosch Platinums gave off a much weaker spark than good old copper Autolites. I did other plug types in between. I did this by using my lawnmower and a rig to hold the gaps for the spark to jump. I simply moved each plug further away until no spark. I know it was not totally controlled variable wise since me pulling the rope could have changed the magnetos strength, but I did it several times as an average. It was a drastic difference.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
They are tuners by trade......not exactly a rookie IMO.
Has this not been known for a while?
boosted/ nitrous should use normal plugs
'77 911S Coupe 3.2 Turbo '76 911S Coupe 3.0 964 cams...no sunroof '75 911S Cabbie 3.2 SS Web cams & 46mm Webers '73 914 1.7 Webers & Header ... sold '74 VW 1303S 1600cc DP Web 110 & Solex |
Ingenieur
Aren't the recommended W3DPO's platin?
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk |
My mechanic buddy uses NGK BR9IX - iridium - plugs in 930s. Waiting great back if he's noticed anything, at least in hindsight, in regard to different plug types.
You need Splitfire's or E3's, a quart of Slick 50, and a cool collar, then you're good to go!...............
![]() On a more serious note, here's a good read: http://www.ngksparkplugs.com/docs/tech/Racing_Spark_Plugs_Performance_Applications.pdf
1986 911 Turbo 3.3L, K27HFS, Tial 46mm, TurboKraft Intercooler, 964 Cams, Monty Muffler, MS3Pro Evo, M&W Ignition, Zietronix WBO2 Data Logger, Wevo shifter, coupler and motor mounts. |
Slick 50! It's Teflonated!
You betcha!
And if it's Teflon, it's got to be good for anything!..........
Interesting...back around 98 when I had my 3.2 I switched to platinum plugs. Car ran like crap. My mechanic at that time had me switch back to copper. Car ran great plus the copper ones were a lot cheaper.
Rey....77 930 "the Mistress" |
That'd top it off!
Wonder how much of that had to do with not being resistor plugs? For sure the spark would be weaker.
