3.0 to be converted to 3.2 Twin turbo
Hallo!
I wanna make a tread of my engine project. The engine is a 3.0 -77 case 03. Have bought a new set of cylinder and pistons from Mahle Motorsport. This is a 98mm set for 74,4 crank and 23mm wrist pin. Pauter has manufactured rods who works with 70,4 crank and 23mm pin and they are 1,8mm longer to remain 7.5:1 comp. K16 Turbo´s from 993/996 as a start and will be changed for 24/26 later. 3.2 intake manifolds and I´m going to use this EFI system: http://www.maxxtuning.eu/maxxecu/ Will post pictures during the process ![]() So here is the very beginning, not that clean yet....... ![]()
Mr. C
Thanx for sharing your turbo project. I thoroughly enjoy the assembly process .
Uber VW ![]()
" Mr.C " Six = Sex |
Hey!
Nice picture
any updates?
Chain fence eating turbo
Cool project! Will be watching....
Testing the brand new 993TT oil pump with the new sump.
At last the engine building has started.
First step is to do a little better breather job ![]() ![]() And some parts waiting for the crankshaft returning from the balancing job.
I thought I was good with a die grinder, but your scallops on the webs look machined.
Great job. |
New turbo squirters mounted
![]() ![]() Engine case closed ![]() ![]()
Looking good, what heads are you going to use?
75 930, 76 930, 83 SC EFI turbo |
3 restos WIP = psycho
You'll like those bigger ports!
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Before and after.
Matching the intake ports for the 3.2 inlet system ![]() P&C ready for assembly ![]() Checking deck height ![]()
![]() ![]() Timing of cams just for checking valve clearense to piston. And then deassembly for mounting of gasket etc.
Very nice !!!! What cams did you install in your engine?
Have you looked at UMW K16/24 hybrid turbos?
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
No, I'm gonna use ordinary K16 from 993/996 as a start.
Because I have those for a long time. They are almost like new. But later I'm gonna change to hybrid 24/26 turbos. The have the same flange as K16 so I don't need to modify the exhaust system. I will start with those just to start with smaller turbos and the grow later. |
