1.0 bar spring, why only 0.8 bar on the clock?
Stock CIS motor, K26, 1.0 bar spring in stock wategate. All new seals and O-rings, good hoses and elbow connections, hose clamps etc. New BOV seals.
Boot gauge goes smartly up to 0.8 bar and stops, never goes over.
Is there something I'm missing?
Old 10-01-2015, 10:40 AM
it can be your gauge is not measuring accurately.
get the calibrated to be sure
Old 10-01-2015, 10:47 AM
The list of possible reasons would be v e r y long.
Are you sure you have a K26?
More likely you have a 3ldz which is the original turbo in the car or a k27 which is the most popular upgrade.
The 3ldz is not a k26.
Old 10-01-2015, 10:59 AM
The factory boost gauge is not very accurate whatsoever.
Old 10-01-2015, 11:23 AM
930/66's Avatar
Maybe your K26 (3LDZ) cant support 1 Bar?!
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods
Old 10-01-2015, 11:34 AM
A K26 is not a 3ldz and either one will over spin and blow overheated air past 1 bar if the wastegate does not open.
Porsche put the 3K 3ldz on the 930 and they put the 3K K26 on the 944 turbo. I've heard they also put a version of the K26 on the 924 turbo.
FWIW, here's a 944 turbo K26 compressor map.
Old 10-01-2015, 11:53 AM
930/66's Avatar
Jim
Thanks for the clarification!
Cheers
Old 10-01-2015, 12:09 PM
T77911S's Avatar
i hate to admit it but that means absolutely NOTHING to me.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 10-01-2015, 04:33 PM
Tug68's Avatar
I have a 1 bar with a k-27 and my boost gauge pegs at 1.
Tim
87 930:G-50 5 Speed, Powerhaus Headers, K-27, Garretson Intercooler, RarlyL8 exhaust and 1 bar boost....
Gone: 85 911:Wevo shifter,full adjustable suspension,bigger torsion bars,Carbon fiber hood,930 brakes and rims.
Old 10-01-2015, 04:38 PM
Never to late to learn, and you do seem to know your electrical stuff
Non User
infraredcalvin's Avatar
Heh heh, me too
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
‘71 914-6 GT 3.4L twin plug track car
'75 914 GT clone project
'71 914 track car, fresh 2165 FAT motor (for sale soon)
Old 10-01-2015, 08:03 PM
proffighter's Avatar
My 1st thought
Roland
930 Turbo '81 Too many modifications to list
Old 10-02-2015, 04:14 AM
T77911S's Avatar
thanks always good to get a complement from you.
i am afraid this is one of those areas i will be happy to let someone else tell me what i need.
my turbo is on its way back from durabuilt now. its a 7006. i was trying to find out mods for it. i have heard of the k27/29 but not sure if that one is made from a 7200. i went with the stock rebuild trying to save money for a rarelyl8 header. i have a header now just not equal length.
RACE CAR:: sold
Old 10-02-2015, 05:21 AM
It is most definitely a k26. I have the original turbo in a box.
The gauge could be inaccurate. What the gauge actually reads is not that important, I just want to make sure everything is good and I haven't screwed anything up in the work I did recently. Previously the BOV seals were completely disintegrated and other seals were weak so I think it was leaking. Certainly it is performing much better and the turbo on-boost is night and day better.
both the turbo and waste gate will be replaced in a year or so anyway, just looking for pointers in case I messed up
Old 10-02-2015, 07:55 AM
mark houghton's Avatar
It sounds like you've adequately covered all the normally suspect areas re: low boost. If your car "feels" like it's getting full boost (per your comment "Certainly it is performing much better and the turbo on-boost is night and day better") then I would say you're gauge is off.
My current 930 struggles to reach .7 bar on the gauge, and I could just sign that off to bad gauge calibration, but I feel that the performance I'm getting is commensurate with the boost reading. In other words, I don't think I'm getting full boost. My BOV/boost recirculation manifold piston end seals are worn from the tell-tale sound of it clanking when on and off throttle, and I wouldn't doubt that that's my boost loss culprit.
I took delivery of this car 14 months ago and as we all know, each one takes a certain amount of effort to find all the gremlins. Currently running much better than on day one.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 10-02-2015, 10:41 AM
IMR-Merlin's Avatar
I have a 1.0 bar spring in my car and hit 1.3 all day long.
82 twin plugged, EFI, G50 930, RSR suspension (soon to be) GT35R...
Old 10-02-2015, 11:08 AM
My butt says the boost is much better :-) The needle moves up to 0.8 bar very smartly, then stops hard, its not like it creeps up to .8 bar. I doubt my butt is calibrated well enough to tell the difference between .8 and 1.0 bar.
Old 10-05-2015, 10:18 AM
930/66's Avatar
Sounds plaussibel if you have a Tial or similar
Tial Say:
NOTE: When ordering, if you have an aftermarket exhaust on your Porsche 930 you will want to order a spring ~.3 bar lower than your target boost level due to back pressure reduction
Old 10-05-2015, 10:53 AM
IMR-Merlin's Avatar
This might have something to do with it.
Old 10-05-2015, 03:31 PM
Slightly on, slightly off topic: Another reason I think my gauge is accurately reporting true boost (.7) is that I haven't heard the WG open....or it's so quietly muffled with the stock WG muffler. I'm accustomed to a pleasant roar, since my last 930 I had removed the muffler and I can't really recall how it sounded prior to the removal.
One way to find out: Yank that sucker off of there!
Old 10-05-2015, 05:05 PM
