1.0 bar spring, why only 0.8 bar on the clock?
Stock CIS motor, K26, 1.0 bar spring in stock wategate. All new seals and O-rings, good hoses and elbow connections, hose clamps etc. New BOV seals.
Boot gauge goes smartly up to 0.8 bar and stops, never goes over. Is there something I'm missing? |
it can be your gauge is not measuring accurately.
get the calibrated to be sure |
The list of possible reasons would be v e r y long.
Are you sure you have a K26? More likely you have a 3ldz which is the original turbo in the car or a k27 which is the most popular upgrade. The 3ldz is not a k26. |
The factory boost gauge is not very accurate whatsoever.
Maybe your K26 (3LDZ) cant support 1 Bar?!
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods |
A K26 is not a 3ldz and either one will over spin and blow overheated air past 1 bar if the wastegate does not open.
Porsche put the 3K 3ldz on the 930 and they put the 3K K26 on the 944 turbo. I've heard they also put a version of the K26 on the 924 turbo. FWIW, here's a 944 turbo K26 compressor map.
Jim
Thanks for the clarification! Cheers
i hate to admit it but that means absolutely NOTHING to me.
I have a 1 bar with a k-27 and my boost gauge pegs at 1.
Tim 87 930:G-50 5 Speed, Powerhaus Headers, K-27, Garretson Intercooler, RarlyL8 exhaust and 1 bar boost.... Gone: 85 911:Wevo shifter,full adjustable suspension,bigger torsion bars,Carbon fiber hood,930 brakes and rims. |
Non User
Heh heh, me too
Infraredcalvin - AKA Pat '76 Turbo Carrera #311 - Factory LSD, Sport Seats ‘71 914-6 GT 3.4L twin plug track car '75 914 GT clone project '71 914 track car, fresh 2165 FAT motor (for sale soon) |
My 1st thought
Roland 930 Turbo '81 Too many modifications to list |
i am afraid this is one of those areas i will be happy to let someone else tell me what i need. my turbo is on its way back from durabuilt now. its a 7006. i was trying to find out mods for it. i have heard of the k27/29 but not sure if that one is made from a 7200. i went with the stock rebuild trying to save money for a rarelyl8 header. i have a header now just not equal length.
The gauge could be inaccurate. What the gauge actually reads is not that important, I just want to make sure everything is good and I haven't screwed anything up in the work I did recently. Previously the BOV seals were completely disintegrated and other seals were weak so I think it was leaking. Certainly it is performing much better and the turbo on-boost is night and day better. both the turbo and waste gate will be replaced in a year or so anyway, just looking for pointers in case I messed up |
It sounds like you've adequately covered all the normally suspect areas re: low boost. If your car "feels" like it's getting full boost (per your comment "Certainly it is performing much better and the turbo on-boost is night and day better") then I would say you're gauge is off.
My current 930 struggles to reach .7 bar on the gauge, and I could just sign that off to bad gauge calibration, but I feel that the performance I'm getting is commensurate with the boost reading. In other words, I don't think I'm getting full boost. My BOV/boost recirculation manifold piston end seals are worn from the tell-tale sound of it clanking when on and off throttle, and I wouldn't doubt that that's my boost loss culprit. I took delivery of this car 14 months ago and as we all know, each one takes a certain amount of effort to find all the gremlins. Currently running much better than on day one.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
I have a 1.0 bar spring in my car and hit 1.3 all day long.
82 twin plugged, EFI, G50 930, RSR suspension (soon to be) GT35R... |
Sounds plaussibel if you have a Tial or similar
Tial Say: NOTE: When ordering, if you have an aftermarket exhaust on your Porsche 930 you will want to order a spring ~.3 bar lower than your target boost level due to back pressure reduction
This might have something to do with it.
Slightly on, slightly off topic: Another reason I think my gauge is accurately reporting true boost (.7) is that I haven't heard the WG open....or it's so quietly muffled with the stock WG muffler. I'm accustomed to a pleasant roar, since my last 930 I had removed the muffler and I can't really recall how it sounded prior to the removal.
One way to find out: Yank that sucker off of there!
