3 restos WIP = psycho
AAR operation - can anyone explain how it works?
What does the electrical lead for the AAR do? I always thought it was a non electrical item that used a bi-metallic strip, that when warm enough, adjusted airflow via expansion differential, to drop idle down. So what's the electrical connection do?
I am trying to figure out if the and EMS can control the AAR like an a IACV, to control idle speed.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
It's the resistance wire heater element on the bimetalic strip. Same thing on and inside the WUR.
These are ancient mechanical CIS devices that will not heat up and work properly without that 12 volt supply plug plugged in. They are not heated to operating temperature by heat transfer absorbtion from the engine they are heated by the 12 volt heat element wrapped around the flat bimetallic strip. |
Kenik,
I believe that the electrical connection is for a heater that warms the bimetallic strip, as in the WUR. I can't help with your second question. Tom |
That would be cool being able to bin the AAR and control it by the EMS instead.
1980 SC Flatnose, Euro 3.0, LW Flywheel, 993 Cams, Port & Polish Heads, RS Cut Valves, Magnacor Leads, Boxster Brakes, WEVO Mounts, TRG Roll Bars, Rollcage, RSR rear fenders, WEVO Shifter, K27 7200 Turbo, OBX Headers, Tial Wastegate, Omex 710 ECU, 3.2 Intake, Full Bay Intercooler.....400HP |
If I read you right then, there's a thermotime switch somewhere that tells the heater when to turn on/off and thus cause the bi-metallic strip to open/close the AAR. If so, then using the EMS to manipulate the AAR using duty cycle control should be easy peasy.
Am I reading you right?
You wouldn't want to interrupt power to it once the car is fully warm, which would cause it to open back up and cause a high idle. You can experience the same effect a couple minutes after starting a car back up which had been shut down when fully warm. The AAR will slowly open while you're in the store buying a 6 pack or some cigs, and the car will idle really high the first minute or so on startup.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ. |
Well, my car idles high for 15 minutes. I've tried two different AARs, so either my 12v supply isn't working or my EMS is doing some crazy $#!t to fight the AAR. Which means I should probably just take a voltage meter to the AAR power leads and see what the reading is...
I would rather be driving
Kenik,
how do you have it connected? You should see about 35-38Ohms across the terminals of the AAR. It only needs static 12V. No PWM needed. you can test on the bench. apply 12V and then wait. The half moon disc should close off in about 3-4min. Its relatively slow. If it moves, it is working. It could be sticking inside and you can drill the 4 rivets to clean out. Then replace with screws. I don't really see the need to connect to an EMS since it operates independently.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks Last edited by jpnovak; 11-04-2015 at 03:07 PM.. |
Go here Idle is high and look at the picture I posted at post #28...pict of a cold AAR. The resistance values will tell you if the internal heating element is open, and if checking for voltage at the plug be sure that your pumps are running or you'll read zippo volts.
Turbofrog
I installed a hand throttle to replace the AAR. Simplicity and looks FTW. I think EMS needs an idle motor if you skip the AAR.
************************************************** ******************************* 10/78 930: HX40Super, MS3pro+IDX1050+044+E85, ITB, 12 Denso COPs, TrueSplit-BB/2*38WGs, Weight<1100kg |
So is the AAR a timed device, meaning that the 12V heater is supposed to expand the bimetallic strip and thus move the AAR plug over a fixed period of time, based on calculation of the coefficients of thermal expansion? Is there no actual input or feedback in the equation? If so, that is just WEIRD!
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 Last edited by kenikh; 11-04-2015 at 09:51 PM.. |
Banned
The colder the strip is to begin with, such as if the ambient temp is cold, the longer it takes for the strip to heat, and thus, the high idle lasts longer. Last edited by Ronnie's.930; 11-05-2015 at 12:16 AM.. |
I've concluded the AAR is a ridiculous device.
it is a very crude device but it works for what it is intended to do, raise the RPM's ONLY when cold.
it is a slow acting device so it can not react fast enough to REALLY control the idle. the only timing it has is the amount of time it takes it to heat up an lower the idle. testing is apply 12v and see if it closes. check for 12v at the connector. the great thing about this and CIS is it is very reliable. go with a euro setup like me and i have no electronic crap that can break.
My 77 has a hand throttle, which suggests that Porsche lacked confidence in the AAR.
Kenik,
You could replace it with a 2-wire Bosch IAC valve. Then use the ECU to pwm control warmup via warmup table. But, you would have to do some wiring and add a "coolant" temperature sensor to engine.
-Dennis 1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R Last edited by dap930; 11-05-2015 at 09:20 AM.. |
Not sure if tech has improved but PWM control of a IAC is not an easy setup in terms of programming. Been there done that, no thanks.
Like I said Kenik, try isolating the idle zones on your ignition map. If you are stubbornly dedicated to making your life hard I have a few IACs laying around you can toy with.
- 86 Porsche 930 - Mr.Hyde - 86 BMW 635CSi - Dr.Jeykell - 2006 Infiniti M45 Sport https://medium.com/@crashingdoor |
^ you know me.
