Yet another SC Turbo conversion! :)
I guess i just officially joined the 911 Turbo club! I have been working the last few weeks to do a turbo swap on my SC 3.0(3.1 actually) Im the type of person, if i decide i want to do something, i have to do it as quickly as possible. What i first started to do was replace some broken axle boots, valve adjustment, and new spark plugs , morphed into a complete turbo swap. I started accumulating parts for the swap about 3 months ago, searching, and looking for parts on the forums, Ebay, cragislist, etc. Just got it together on friday, and was able to do a rough tune on it to get it running fairly good.
79 911SC widebody conversion Here is my Mods factory 3.1 block(97mm pistons, and 97mm turbo cylinders) 9.5:1 compression Carrera heads. SC cams Carrera intake carrera oil cooler Factory J pipe sourced from Ebay KKK K27 7200 High flow Tial F41 wastegate(.60 Bar spring) straight through exhaust with a high flow cat Siemens/DEKA 60 lb hr fuel injectors Aeromotive rising rate fuel pressure regulator Greddy type FV BOV Microsquirt V3 ECU Ford EDIS ignition knocksense knock system Flex fuel sensor from Ford Ranger Big Ass full bay intercooler(Thanks Tippy) I have owned several single turbo RX-7s in my earlier years, and an 02 911 Turbo, so this isnt my first Turbo car. I have missed the sound of the turbo spooling up, and the sound of the BOV, and wastegate opening up, and the feel of the turbo building boost as you blast off like a rocket! Such a great feeling! I am going to be running E85 most of the time, and started the transition today, just hoping that Microsquirt automatically compensates for the change in the Gasoline/ethanol mixture like it is supposed to. I copied someones timing table to get me started. Does anyone have a timing table from a 9.5:1 compression car that i could look over to make sure i am in the right ballpark? Also, was planning to keep it at at .60 Bar, am i running safe here with 9.5:1 compression? Here are some pics of the car, and some engine porn! not sure why the intercooler looks sideways, its pretty straight ![]() ![]() ![]()
Chain fence eating turbo
Wow, had no idea you had such a looker!
If I'm getting away with 1.4 bar with 7.5 CR, 0.6 with 9.5 CR should be safe. That IC will keep the turbo temps at or just above ambient easily. As far as timing, I believe there's quite a few 3.0 turbo guys that should be able to give you something. 3.2 heads, cams, and intake breathe pretty good. Bet it's a rocket! |
Cool Build
![]() " I am going to be running E85 most of the time" No Bueno, seen way to many failures on E85........
10.76@139-1/4 mile 0-1 mile 193MPH I Love to Shine Cars
Thanks Tippy for the kind words. Its kind of a 10 footer right now. Paint and body work is next!
Juan, can you elaborate on the e85 comment? I was thinking that E85 was a bit safer for a high compression motor? Not really planning on upping the boost with E85. |
Banned
cool build, came out good - looks fun
enjoy |
On a positive note, I think Frank around here runs E85 and so far so good so maybe he can chime in.
Scavenge pump
hi nice car - i have a question for you i in a middle of conversion a SC a well and i am using the same idea for the free fall for the oil from the turbo to the bottom of the engine and 2 turbo died from lack of oil . one of the turbo technician told me that the suction from the cartridge is too high and i need to use a Scavenge pump instead
is it true?do you have this issue with your car ?does it smoke? THX
I've heard these mixtures aren't perfectly consistent too. You have 2 maps per fuel and ignition, 1 for E10/straight gasoline, and 1 for E85. The sensor detects the % of ethanol and interpolates between the 2 maps. |
That's a nice build
1980 SC Flatnose, Euro 3.0, LW Flywheel, 993 Cams, Port & Polish Heads, RS Cut Valves, Magnacor Leads, Boxster Brakes, WEVO Mounts, TRG Roll Bars, Rollcage, RSR rear fenders, WEVO Shifter, K27 7200 Turbo, OBX Headers, Tial Wastegate, Omex 710 ECU, 3.2 Intake, Full Bay Intercooler.....400HP |
Looks great! We need some videos of it running. I think EDIS is my next move in the near future...
Who makes that intercooler?
Kyle - 1980 RoW non-sunroof 911sc - 3.2 Turbo, Mahle P&C, Carrillo Rods, Megasquirt II (Fuel Only for now), re-geared 3rd and 4th 930 gearbox, 2350lbs |
3 restos WIP = psycho
On e85, that thing is going to be barnstormer.
For fail mode or when using gasoline only, if you plan to run knock control, your default fallback should be a max of .5 BAR, which will play nice with the 7200. Without knock control, your fail mode on premium gas should be full dump (no boost), as the motor won't tolerate any amount of boost within the efficiency range of the 7200.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
I ran my oil supply from the rear oil pressure switch, and used the 930 factory hard oil supply line. I seem to be getting a good amount of oil to keep the turbo happy. I would think a scavenge pump would move the oil out of the turbo faster, so i don't think that will take care of your problem. |
EDIS was a fairly easy affair for me. I used the goingsuperfast crank pulley, and the toothed wheel. I sourced all of the EDIS stuff from my local Pull-a-part for about $25. Came off of a Ford Explorer. I also found some plug wires off of a 96 Ford Crown Victoria that worked out quite well. I had no problems getting it dialed in. I guess this is the easiest way to go distributorless. I may try coil on plug one day, but only because i think it looks sweet. Still not sure how to do COP with wasted spark either. Not sure who built the intercooler... I bought it secondhand off of Tippy. Seems to be pretty well made. Had to make a few modifications to it to make it fit how i wanted it to. It seems to do its job. I guess we will see this summer as to how efficient it will be. I will see if i can't get some video of pulling second and third gear in the next few days! Last edited by scottrx7tt; 01-04-2016 at 12:35 PM.. |
Not sure the make either, came on the car when bought from PO who bought it from Miami.
Scott, it'll keep the outlet temps at bay easily in summer. The worst it's "allowed" was 15° over ambient in a 105° day. No worries there! |
Guess the compressor map will tell if it's going to he OK or running hot. I suspect no problem since it's nearly half the boost as most. |
I'd say you are very conservative.
But, one thing that jumps out to me is your low RPM high load cells. 35° is way too high. In the 450 RPM/100kPa cell, I'd put 0°. This is the cell where the engine is starting in. It'll help the starter to spin the motor and reduce kickback. Once it fires off, the timing jumps up due to vacuum to help keep it running. What Sal pointed out, too high of timing at low RPM makes for a situation where the piston is literally being pushed backwards, making for difficult running. Last edited by Tippy; 01-04-2016 at 01:20 PM.. |
These guys here know a lot about the 3K turbos and can help you out immensely.
