-   -   TurboKraft Full Engine rebuild, EFI, + more - Build Thread (http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/905056-turbokraft-full-engine-rebuild-efi-more-build-thread.html)
dap930 06-01-2016 02:32 PM
Chris,
My bad, I realized I had some of the numbers backwards after I posted, but I figured most folks would figure it out.
One of the Garrett turbo's I considered was a GTX7635R, which may have performed well with my 3.0L engine. I had a GT3583R installed, but the low end response was too laggy for my 3.0L low compression motor.
AskewRSR 06-01-2016 06:24 PM
There are only a few people who have tested many of these turbos back to back with a dyno...
Internet experts with unfounded opinions are everywhere...... Sad
aschen 06-02-2016 11:36 AM
Loving this video series! I watched a few episodes last night and I am thinking about ditching work early to watch a few more.
gsxrken 06-08-2016 06:53 PM
I demand the next video damn it.
930/66 06-09-2016 02:31 AM
After my bad experience with my last Turbocharger i need a new one.
I`m looking forward for the results / difference GTX30 vs GTX35.
Also have 3.4 with alot of goodies. Just want now how the GTX30 run to reedline.
Rich76_911s 06-09-2016 06:05 AM
Ken,
Ask and Ye shall receive!
<iframe width="560" height="315" src="https://www.youtube.com/embed/KBve2yqdHME" frameborder="0" allowfullscreen></iframe>
I do have to say this series really has me running a fever, and the only cure is EFI.
aschen 06-09-2016 07:33 AM
Originally Posted by Rich76_911s (Post 9153505)
Ido have to say this series really has me running a fever, and the only cure is EFI.
I think its contagious
930/66 06-09-2016 07:54 AM
👍do you have a rpm/boost graph?!
Mr9146 06-09-2016 08:14 AM
What's with the heavy dip in the curve at 47/4800?
Did I hear you say it's "fuel pressure noise?" :confused:
quattrorunner 06-09-2016 12:40 PM
Nice.
TurboKraft 06-10-2016 05:10 PM
Sensor signal noise, which directly affects injector function.
Mr9146 06-10-2016 06:45 PM
That makes more sense. Are you pulling sensor signal from crank or camshaft?
Hams930T 06-10-2016 08:06 PM
As in - signal noise was causing a de-sync error right? Was it consistent in that spot or random de-sync errors? I presume this is what we were discussing on the phone the other day.
- Chris
Pat RUFBTR 06-10-2016 11:23 PM
Deeply the test with the GT35! :)
Dave 86 930 Fl 06-11-2016 01:27 PM
Nice build Pete, who did the head work on the motor?
dennywags 06-12-2016 03:29 AM
Why not drive it on the street?
smurfbus 06-12-2016 03:35 AM
Not safe at those speeds obviously. You know how long third gear is?
Tippy 06-12-2016 04:24 AM
In what regards?
930/66 06-12-2016 08:45 AM
RPM Boost curve
I have evaluated the video (hope i have see all right) rpm boost pressure build.
GTX 3076R
2000 rpm 0.14 bar
2500 rpm 0.29 bar
2750 rpm 0.41 bar
3000 rpm 0.62 bar
3250 rpm 0.76 bar
3500 rpm 0.85 bar
3750 rpm 0.95 bar
4000 rpm 0.96 bar
between 4000 and 5500 rpm over 14 psi (0.96 bar) after that drop to 0.94 bar till 6500 rpm
I made a comparison between the GTX 3076R and my K27/29
My Data are from my Dynotest (4gear with 98oct)
GTX 3076R K27/29
2000 rpm 0.14 bar 0.10 bar
2500 rpm 0.29 bar 0.20 bar
2750 rpm 0.41 bar 0.30 bar
3000 rpm 0.62 bar 0.40 bar
3250 rpm 0.76 bar 0.50 bar
3500 rpm 0.85 bar 0.77 bar
3750 rpm 0.95 bar 0.90 bar
4000 rpm 0.96 bar 1.00 bar (between 4000 till 7200 rpm drop to 0.94 restrective muffler)
Tippy 06-12-2016 08:50 AM
Deleted
